Ticket #6274 - Source code installation failed
jack9603301
Post by jack9603301 »
I compiled freecad 0.20-dev in release mode, but I can't make the compiled and installed program work normally.
I use the following command to compile:
sudo make install
After starting freecad, it reports an error:
No module named 'StartGui'
I use Kubuntu 21.04 to do the above
Syres
Re: Source code installation failed
Post by Syres »
This old post still looks relevant today with regard to paths, see https://forum.freecadweb.org/viewtopic. ... 239#p59239
jack9603301
My setup doesn't seem to load any modules
jack9603301
Please don't show such information as screenshot. output of report view is usually put in code tags directly in the post.
jack9603301
This is the search path for Python3 and the path where the Mod is located
/usr/Mod
/home/jack/SourceCode/FreeCAD/build
/usr/lib/python39.zip
/usr/lib/python3.9
/usr/lib/python3.9/lib-dynload
/home/jack/.local/lib/python3.9/site-packages
/usr/local/lib/python3.9/dist-packages
/usr/lib/python3/dist-packages
/usr/lib/python3.9/dist-packages
>>> exit()
ls /usr/Mod
AddonManager  Draft    Fem  Image   Inspection  Measure  MeshPart  Part        Path  Points      ReverseEngineering  Show      Spreadsheet  Surface   Test  Web
Arch          Drawing  Idf  Import  Material    Mesh     OpenSCAD  PartDesign  Plot  Raytracing  Robot               Sketcher  Start        TechDraw  Tux
jack9603301
I noticed that the Gui directory was missing from the specific /usr/Mod/Start/ directory
chennes
Post by chennes »
Can you show us your cMake command?
Chris Hennes
Pioneer Library System
jack9603301
chennes wrote: Mon Oct 18, 2021 2:44 pm Can you show us your cMake command?
cmake .. -DCMAKE_INSTALL_PREFIX=/usr -DPYTHON_EXECUTABLE=/usr/bin/python3 -DFREECAD_USE_PCL=ON -DFREECAD_USE_PYBIND11=ON -DCMAKE_BUILD_TYPE=Release
I'm recompiling.
jack9603301
