Shiboken broken.
davecoventry
Shiboken broken.
Post by davecoventry »
Just reinstalled my Ubuntu installation to KDE neon as I was havng a few issues.
I've installed git and pulled the repositories, but I'm getting an error:
-- Shiboken2Config: Using default python: .cpython-38-x86_64-linux-gnu
CMake Error at /usr/lib/x86_64-linux-gnu/cmake/Shiboken2-5.15.2/Shiboken2Targets.cmake:81 (message):
  The imported target "Shiboken2::shiboken2" references the file
     "/workspace/usr/bin/shiboken2"
  but this file does not exist.  Possible reasons include:
~ Dave
davecoventry
Re: Shiboken broken.
Okay.
I installed libshiboken2-py3-5.14 which removed libshiboken2-dev and a few other dependencies and tried agains.
This time cmake worked and FreeCAD compiled.
~ Dave
rsa4046
Re: [Solved] Shiboken broken.
Post by rsa4046 »
davecoventry wrote: Tue Oct 19, 2021 1:02 pm Just reinstalled my Ubuntu installation to KDE neon as I was havng a few issues.
It seems this bug is still present -- am also on KDE Neon 20.04 release (focal). Regressing to libshiboken2-py3-5.14 indeed removes libshiboken2-dev, but also removes shiboken2 (see below), pyside2, and pivy:
libsoqt520
shiboken2
libpyside2-dev
libpyside2-py3-5.15
libshiboken2-py3-5.15
pyside2-tools
python3-pivy
python3-pyside2.qtcore
python3-pyside2.qtgui
python3-pyside2.qtnetwork
python3-pyside2.qtopengl
python3-pyside2.qtsvg
python3-pyside2.qtwidgets
The original error (/workspace/usr/bin/shiboken2 not found) seems to be a bug in the shiboken2's CMake finder, as it fails even in a generic barebones CMake test. E.g.,:
$ mkdir test/build -p
$ cd test/build
$ cat > ../CMakeLists.txt
project(ProjectName)
find_package(Shiboken2)
^D
$ cmake  -Wno-dev ../
-- The C compiler identification is GNU 9.3.0
-- The CXX compiler identification is GNU 9.3.0
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /usr/bin/cc - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
  * The file was deleted, renamed, or moved to another location.
  * An install or uninstall procedure did not complete successfully.
  * The installation package was faulty and contained
     "/usr/lib/x86_64-linux-gnu/cmake/Shiboken2-5.15.2/Shiboken2Targets.cmake"
  but not all the files it references.
  /usr/lib/x86_64-linux-gnu/cmake/Shiboken2-5.15.2/Shiboken2Config.cpython-38-x86_64-linux-gnu.cmake:40 (include)
  /usr/lib/x86_64-linux-gnu/cmake/Shiboken2-5.15.2/Shiboken2Config.cmake:5 (include)
  CMakeLists.txt:2 (find_package)
-- Configuring incomplete, errors occurred!
The message itself originates from the file, Shiboken2Targets-relwithdebinfo.cmake (on my box, /usr/lib/x86_64-linux-gnu/cmake/Shiboken2-5.15.2/Shiboken2Targets-relwithdebinfo.cmake), in which IMPORTED_LOCATION_RELWITHDEBINFO is set to "/workspace/usr/bin/shiboken2" (line 21):
# Import target "Shiboken2::shiboken2" for configuration "RelWithDebInfo"
set_property(TARGET Shiboken2::shiboken2 APPEND PROPERTY IMPORTED_CONFIGURATIONS RELWITHDEBINFO)
set_target_properties(Shiboken2::shiboken2 PROPERTIES
  IMPORTED_LOCATION_RELWITHDEBINFO "/workspace/usr/bin/shiboken2"
list(APPEND _IMPORT_CHECK_TARGETS Shiboken2::shiboken2 )
list(APPEND _IMPORT_CHECK_FILES_FOR_Shiboken2::shiboken2 "/workspace/usr/bin/shiboken2" )
It seems odd to me the "workspace" is hardcoded here, but I am no expert. Can anyone shed any light here?
davecoventry
This issue has raised its ugly head again.
This time the remedy above does not work, libshiboken2-5.14 is no longer available and libshiboken2-5.15 fails to resolve the error.
~ Dave
davecoventry
I solved the issue by creating a directory in root.
sudo mkdir /workspace
Then symlinking to shiboken2
cd /workspace
sudo ln -s /usr usr
Obviously, this kludge is not ideal, but it solves the problem.
~ Dave
