Help building API docs, please
falviani
Post by falviani »
I need to build the API documentation (I am working on a workbench and need to find out how to enable commands after activating it). I build the git version using CMake and VS2019. I have tried to follow the wiki page on building, creating a separated directory for the generated HTML, but I don't have make as a command installed on my machine. When I cd into the html output directory and run CMake (using the existing source directory that I use to build normally), it generates a configuration file - but I don't know how to tell it to just build the docs using Doxygen, which I do have installed. What should I do?
Thanks in advance,
Frank
