Running FreeCAD from a Network Drive?
mprowe.freecad
Post by mprowe.freecad »
I would like to run FreeCAD from a network drive so that I can do the main design work on a PC in the office, then go to the workshop an use a Notebook to monitor the CNC output.
I have trawled through the forum and "tried" to follow what has been said about [SOLVED] Portable FreeCAD(user.cfg, system.cfg and Addon Manager). But, no matter what I do, I can not:
Set the environment variable FREECAD_USER_HOME
Is this an AppImage thing?
Regards, Martin
OS: openSUSE Leap 15.3 (KDE//usr/share/xsessions/default)
Version: 0.19.24291 (Git) AppImage
Python version: 3.8.8
Qt version: 5.12.9
OCC version: 7.4.0
Re: Running FreeCAD from a Network Drive?
mprowe.freecad wrote: Tue Oct 26, 2021 8:01 am I would like to run FreeCAD from a network drive so that I can do the main design work on a PC in the office, then go to the workshop an use a Notebook to monitor the CNC output.
I don't think so. In Linux you have set it with
export FREECAD_USER_HOME=/path/to/your/network/drive
Then start FreeCAD from the same shell.
mprowe.freecad
[SOLVED] Re: Running FreeCAD from a Network Drive?
Thanks Chris,
That worked a treat!
Regards, M.
Good to hear - it was a blind flight, because I couldn't currently test.
