Thank you for detailed Linux comment @onekk
I am happy to report that updating nvidia drivers seem to have sorted the problem
Thank you for your help guys.
problem installing 0.20 appimage (solved)
Re: problem installing 0.20 appimage (solved)
Another day, another version of 0.20 appimage instaled.... and the same problem.
Runs fine and then crashes almost immediately afterwards.
Not always immediately, sometimes stays up long enough to open file, but never lasts very long
Managed to grab version info:
and the error message when tried running from terminal:
Can anybody knowledgeable, please comment as to what is going on? and what can I do to sort this out?
OS: elementary OS 6.1 Jalnir (Pantheon/pantheon)
Version: 0.20.26720 (Git) AppImage
Branch: (HEAD detached at 7bca26e)
Hash: 7bca26e7c14d4d43374ff7e0c8582735b249cbfd
Python version: 3.9.9
Qt version: 5.12.9
OCC version: 7.5.3
#0 /lib/x86_64-linux-gnu/libc.so.6(+0x46210) [0x7f94c9833210]
#1 /tmp/.mount_FreeCAkDye4Z/usr/plugins/designer/../../lib/libQt5WebEngineCore.so.5(+0x283efe4) [0x7f9497867fe4]
#2 /tmp/.mount_FreeCAkDye4Z/usr/plugins/designer/../../lib/libQt5WebEngineCore.so.5(+0x3a7b524) [0x7f9498aa4524]
#3 /tmp/.mount_FreeCAkDye4Z/usr/plugins/designer/../../lib/libQt5WebEngineCore.so.5(+0x3a7b657) [0x7f9498aa4657]
#4 /tmp/.mount_FreeCAkDye4Z/usr/plugins/designer/../../lib/libQt5WebEngineCore.so.5(+0x1db1330) [0x7f9496dda330]
#5 /tmp/.mount_FreeCAkDye4Z/usr/plugins/designer/../../lib/libQt5WebEngineCore.so.5(+0x1dd16e1) [0x7f9496dfa6e1]
#6 /tmp/.mount_FreeCAkDye4Z/usr/plugins/designer/../../lib/libQt5WebEngineCore.so.5(+0x1dd23ff) [0x7f9496dfb3ff]
#7 /tmp/.mount_FreeCAkDye4Z/usr/plugins/designer/../../lib/libQt5WebEngineCore.so.5(+0x1dd26b4) [0x7f9496dfb6b4]
#8 /tmp/.mount_FreeCAkDye4Z/usr/plugins/designer/../../lib/libQt5WebEngineCore.so.5(+0x1dd0188) [0x7f9496df9188]
#9 /tmp/.mount_FreeCAkDye4Z/usr/plugins/designer/../../lib/libQt5WebEngineCore.so.5(+0x1df265f) [0x7f9496e1b65f]
#10 /tmp/.mount_FreeCAkDye4Z/usr/plugins/designer/../../lib/libQt5WebEngineCore.so.5(+0x1e255fe) [0x7f9496e4e5fe]
#11 /tmp/.mount_FreeCAkDye4Z/usr/plugins/designer/../../lib/libQt5WebEngineCore.so.5(+0x1e565af) [0x7f9496e7f5af]
#12 /lib/x86_64-linux-gnu/libpthread.so.0(+0x9609) [0x7f94c8ddc609]
#13 /lib/x86_64-linux-gnu/libc.so.6(clone+0x43) [0x7f94c990f293]
Re: problem installing 0.20 appimage (back again with another release)
This is the message when it crashes while trying to load:
Looks like it is familiar Nvidia card issue, but it is totally puzzling especially since an earlier version I also have (FreeCAD_weekly-builds-26202-Linux-Conda_glibc2.12-x86_64.Appimage) is running perfectly fine
later edit:
(for my record, and when referring to this thread in future)
found this https://forum.freecadweb.org/viewtopic.php?t=63680
and managed to keep things open long enough to change display settings as advised.
Let's hope this is it???
./FreeCAD_weekly-builds-26720-Linux-Conda_glibc2.12-x86_64.AppImage
FreeCAD 0.20, Libs: 0.20R26720 (Git)
... clipped...
nouveau: kernel rejected pushbuf: No such file or directory
nouveau: ch5: krec 0 pushes 0 bufs 1 relocs 0
nouveau: ch5: buf 00000000 00000002 00000004 00000004 00000000 0x7f2c0812b000 0x30000 0x80000
#0 /lib/x86_64-linux-gnu/libc.so.6(+0x46210) [0x7f2c122a6210]
/tmp/.mount_FreeCAYIY0GE/AppRun: line 41: 6296 Segmentation fault ${MAIN} "$@"
later edit:
later edit:
Final edit (01.01.2022):
changing to "Use Software OpenGL" solved the problem
... clipped...
later edit:
