unfortunately I can not compile the current FreeCad Master due to the following issue:
I am not so familiar with compiling and could not find any related topics or issues across the net. Do you have an idea what might be the problem?/usr/bin/ld: /usr/lib/libxerces-c.so: undefined reference to `curl_global_cleanup@CURL_OPENSSL_4'
/usr/bin/ld: /usr/lib/libxerces-c.so: undefined reference to `curl_easy_getinfo@CURL_OPENSSL_4'
/usr/bin/ld: /usr/lib/libxerces-c.so: undefined reference to `curl_multi_cleanup@CURL_OPENSSL_4'
/usr/bin/ld: /usr/lib/libxerces-c.so: undefined reference to `curl_multi_perform@CURL_OPENSSL_4'
/usr/bin/ld: /usr/lib/libxerces-c.so: undefined reference to `curl_global_init@CURL_OPENSSL_4'
/usr/bin/ld: /usr/lib/libxerces-c.so: undefined reference to `curl_easy_init@CURL_OPENSSL_4'
/usr/bin/ld: /usr/lib/libxerces-c.so: undefined reference to `curl_multi_add_handle@CURL_OPENSSL_4'
/usr/bin/ld: /usr/lib/libxerces-c.so: undefined reference to `curl_multi_remove_handle@CURL_OPENSSL_4'
/usr/bin/ld: /usr/lib/libxerces-c.so: undefined reference to `curl_multi_info_read@CURL_OPENSSL_4'
/usr/bin/ld: /usr/lib/libxerces-c.so: undefined reference to `curl_slist_free_all@CURL_OPENSSL_4'
/usr/bin/ld: /usr/lib/libxerces-c.so: undefined reference to `curl_easy_setopt@CURL_OPENSSL_4'
/usr/bin/ld: /usr/lib/libxerces-c.so: undefined reference to `curl_multi_fdset@CURL_OPENSSL_4'
/usr/bin/ld: /usr/lib/libxerces-c.so: undefined reference to `curl_slist_append@CURL_OPENSSL_4'
/usr/bin/ld: /usr/lib/libxerces-c.so: undefined reference to `curl_easy_cleanup@CURL_OPENSSL_4'
/usr/bin/ld: /usr/lib/libxerces-c.so: undefined reference to `curl_multi_init@CURL_OPENSSL_4'
/usr/bin/ld: /usr/lib/libxerces-c.so: undefined reference to `curl_multi_timeout@CURL_OPENSSL_4'
make[2]: *** [src/Main/CMakeFiles/FreeCADMainCmd.dir/build.make:126: bin/FreeCADCmd] Error 1
make[1]: *** [CMakeFiles/Makefile2 src/Main/CMakeFiles/FreeCADMainCmd.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs....
[ 56%] Built target FreeCADGui
make: *** [Makefile:136: all] Error 2
My system information is:
Operating System: Manjaro Linux
KDE Plasma Version: 5.23.3
KDE Frameworks Version: 5.88.0
Qt Version: 5.15.2
Kernel Version: 5.10.79-1-MANJARO (64-bit)
Graphics Platform: X11
Processors: 4 × Intel® Core™ i5-5300U CPU @ 2.30GHz
Memory: 7,5 GiB of RAM
Graphics Processor: Mesa Intel® HD Graphics 5500
Python 3.7.6
FreeCad
Hash: e4ca3d29719600238171c15959a629813bf5e194
