Ticket #4815: [Proposal] Run script (bash) for FreeCAD
Post by Kunda1 »
Discussion thread for issue #4815: [Proposal] Run script (bash) for FreeCAD
mcgiwer wrote: Hello. I had wrote a script in bash that (after placing in the same folder as for example bin) would allow to launch FreeCAD directly from it and with creates a log file.
I hope that it becomes included to the base FreeCAD. I also hope to recieve a upload permission on GitHub to be able to contribute as well.
#!/bin/bash
# Fix for the XCB issue #
sudo xhost +si:localuser:${USER}
export DISPLAY=:0
# End of the XCB fix #
## Supportive function to get app directory
function getpwd
    lnk="$(readlink -f $0)"
    ln="$(basename ${lnk})"
    ls=${#ln}
    ((ls=${ls}+1))
    ((ls=-${ls}))
    echo ${lnk::$ls}
## End of function
## Get the root folder
root="$(gwtpwd)"
# Create the link to the user home dir
if [ ! -d "${HOME}/.FreeCAD" -o ! -h "${HOME}/.FreeCAD" ]; then ln -vfs ${root} ${HOME}/.FreeCAD; fi
#  TODO: Automatical discovery of the avaliable Python version #
export PYTHONHOME=${root}
# Qt
export QT_XKB_CONFIG_ROOT=${LD_LIBRARY_PATH}:${root}/lib
# export QT_QPA_PLATFORM_PLUGIN_PATH=plugins
# export QTWEBENGINEPROCESS_PATH=libexec/QtWebEngineProcess
# Support for launching other applications from /usr/bin ( https://github.com/FreeCAD/FreeCAD-AppImage/issues/30)
if [ ! -z "$1" ] && [ -e "bin/$1" ] ; then
    MAIN="bin/$1" ; shift
else
    MAIN="bin/freecad"
fi
nice -n19 ${MAIN} "$@" &> ${root}/freecad.log &
Re: Ticket #4815: [Proposal] Run script (bash) for FreeCAD
Post by Kunda1 »
bump
Post by Kunda1 »
Can the community weigh in on this?
flachyjoe
Post by flachyjoe »
I don't understand what is this script for.
It seems only run freecad with a modified nice value (useless in most case, user based niceness is good) and write a log.
freecad can already and properly save a log with -l [ --write-log ] or --log-file arguments
See
freecad --help
- Flachy Joe -
