[Solved] Broken Copr (Fedora rpms) nightlies
zippy
Post by zippy »
Hello, not sure where to post this. The Copr nightlies have been broken for a while, seems there's a new plugin the packaging doesn't know about.
Latest failed build:
https://copr.fedorainfracloud.org/coprs ... d/3257449/
Full build log:
https://download.copr.fedorainfracloud. ... ive.log.gz
Re: Broken Copr (Fedora rpms) nightlies
Hi and welcome to the forum! It's the right forum you posted to.
Can you use the AppImage from the FreeCAD website?
zippy
Post by zippy »
Thanks. I did miss this section and a kind mod has moved the topic :)
I'm not really interested in the AppImage in general, I'd like to stick with rpms. But I've just checked the FreeCAD AppImage and it's 976MB, that alone is a no, thanks :?
Is the Copr repo maintained (as opposed to abandoned) and is it maintained by someone on the forum?
FWIW the fix shouldn't be hard.
Post by Kunda1 »
PrzemoF wrote::bell:
@PrzemoF care to weigh in on this? ;)
PrzemoF
Post by PrzemoF »
The fix should be very easy - it's a missing module, I think. I'll take a look, but patches are welcome.
PrzemoF
Post by PrzemoF »
There is a bit more in it as the COPR system has been changed. Test build in progress...
zippy
Post by zippy »
Thanks a lot, the last build has succeeded, it installs and runs.
PrzemoF
Re: [Solved] Broken Copr (Fedora rpms) nightlies
Post by PrzemoF »
Thank you for the feedback! Did you run the test suite or FreeCAD -t 0 to confirm all works as expected?
zippy
Post by zippy »
Not sure how I'd run the test suite, but I've just run `FreeCAD -t0`, it did a bunch of stuff and finished successfully. I think all is good 8-)
