My build pipeline on macOS arm46 is broken as well. I don't know the reason or fix yet.
Using my setup with Python 3.9 reports some errors during the cmake setup in regards to Pivy and Pyside2. Yet the setup finishes with OK:
-- Coin3D libraries found
AttributeError: module 'pivy' has no attribute '__version__'
-- Could NOT find Spnav (missing: SPNAV_LIBRARY SPNAV_INCLUDE_DIR)
-- Shiboken2Config: Using default python: .abi3
-- Found PythonInterp: /opt/homebrew/Frameworks/Python.framework/Versions/3.9/bin/python3.9 (found suitable version "3.9.13", minimum required is "3")
-- Found PythonLibs: /opt/homebrew/opt/python@3.9/Frameworks/Python.framework/Versions/3.9/lib/libpython3.9.dylib (found suitable version "3.9.13", minimum required is "3")
-- SHIBOKEN_PYTHON_INCLUDE_DIRS computed to value: '/opt/homebrew/opt/python@3.9/Frameworks/Python.framework/Versions/3.9/include/python3.9'
-- SHIBOKEN_PYTHON_LIBRARIES computed to value: '-undefined dynamic_lookup'
-- libshiboken built for Release
File "/opt/homebrew/Cellar/python@3.9/3.9.13_1/Frameworks/Python.framework/Versions/3.9/lib/python3.9/posixpath.py", line 152, in dirname
p = os.fspath(p)
TypeError: expected str, bytes or os.PathLike object, not NoneType
PySide2 Python module not found.
This results in weird errors with
Py_complex and
Py_UNIcODE during build:
In file included from /Users/dirkolbrich/FreeCAD/freecad-source/src/CXX/Objects.hxx:42:
/Users/dirkolbrich/FreeCAD/freecad-source/src/CXX/Python3/Objects.hxx:1026:18: error: unknown type name 'Py_complex'; did you mean '_Complex'?
operator Py_complex() const
_Complex
/Users/dirkolbrich/FreeCAD/freecad-source/src/CXX/Python3/Objects.hxx:1026:18: warning: '_Complex' is a C99 extension [-Wc99-extensions]
/Users/dirkolbrich/FreeCAD/freecad-source/src/CXX/Python3/Objects.hxx:1026:18: warning: plain '_Complex' requires a type specifier; assuming '_Complex double'
double
/Users/dirkolbrich/FreeCAD/freecad-source/src/CXX/Python3/Objects.hxx:1031:35: error: unknown type name 'Py_complex'; did you mean '_Complex'?
Complex &operator=( const Py_complex &v )
_Complex
/Users/dirkolbrich/FreeCAD/freecad-source/src/CXX/Python3/Objects.hxx:1031:35: warning: '_Complex' is a C99 extension [-Wc99-extensions]
/Users/dirkolbrich/FreeCAD/freecad-source/src/CXX/Python3/Objects.hxx:1031:35: warning: plain '_Complex' requires a type specifier; assuming '_Complex double'
double
/Users/dirkolbrich/FreeCAD/freecad-source/src/CXX/Python3/Objects.hxx:1028:20: error: use of undeclared identifier 'PyComplex_AsCComplex'
return PyComplex_AsCComplex( ptr() );
/Users/dirkolbrich/FreeCAD/freecad-source/src/CXX/Python3/Objects.hxx:1033:18: error: use of undeclared identifier 'PyComplex_FromCComplex'
set( PyComplex_FromCComplex( v ), true );
/Users/dirkolbrich/FreeCAD/freecad-source/src/CXX/Python3/Objects.hxx:1793:31: error: use of undeclared identifier 'Py_UNICODE'
typedef std::basic_string<Py_UNICODE> unicodestring;
/Users/dirkolbrich/FreeCAD/freecad-source/src/CXX/Python3/Objects.hxx:1794:12: error: unknown type name 'Py_UNICODE'
extern Py_UNICODE unicode_null_string[1];
/Users/dirkolbrich/FreeCAD/freecad-source/src/CXX/Python3/Objects.hxx:1983:15: error: unknown type name 'Py_UNICODE'
Char( Py_UNICODE v )
/Users/dirkolbrich/FreeCAD/freecad-source/src/CXX/Python3/Objects.hxx:2021:26: error: unknown type name 'Py_UNICODE'
Char &operator=( Py_UNICODE v )
/Users/dirkolbrich/FreeCAD/freecad-source/src/CXX/Python3/Objects.hxx:1990:79: error: unknown type name 'Py_UNICODE'
: Object( PyUnicode_FromKindAndData( PyUnicode_4BYTE_KIND, const_cast<Py_UNICODE*>( v.data() ),1 ), true )
/Users/dirkolbrich/FreeCAD/freecad-source/src/CXX/Python3/Objects.hxx:1990:94: error: member reference base type 'const Py::unicodestring' (aka 'const int') is not a structure or union
/Users/dirkolbrich/FreeCAD/freecad-source/src/CXX/Python3/Objects.hxx:1990:46: error: use of undeclared identifier 'PyUnicode_4BYTE_KIND'
/Users/dirkolbrich/FreeCAD/freecad-source/src/CXX/Python3/Objects.hxx:2010:78: error: unknown type name 'Py_UNICODE'
set( PyUnicode_FromKindAndData( PyUnicode_4BYTE_KIND, const_cast<Py_UNICODE*>( v.data() ), 1 ), true );
/Users/dirkolbrich/FreeCAD/freecad-source/src/CXX/Python3/Objects.hxx:2010:93: error: member reference base type 'const Py::unicodestring' (aka 'const int') is not a structure or union
/Users/dirkolbrich/FreeCAD/freecad-source/src/CXX/Python3/Objects.hxx:2010:45: error: use of undeclared identifier 'PyUnicode_4BYTE_KIND'
/Users/dirkolbrich/FreeCAD/freecad-source/src/CXX/Python3/Objects.hxx:2016:13: error: unknown type name 'Py_UNICODE'
Py_UNICODE v( v_ );
/Users/dirkolbrich/FreeCAD/freecad-source/src/CXX/Python3/Objects.hxx:2017:45: error: use of undeclared identifier 'PyUnicode_4BYTE_KIND'
set( PyUnicode_FromKindAndData( PyUnicode_4BYTE_KIND, &v, 1 ), true );
/Users/dirkolbrich/FreeCAD/freecad-source/src/CXX/Python3/Objects.hxx:2023:45: error: use of undeclared identifier 'PyUnicode_4BYTE_KIND'
/Users/dirkolbrich/FreeCAD/freecad-source/src/CXX/Python3/Objects.hxx:2116:23: error: unknown type name 'Py_UNICODE'
String( const Py_UNICODE *s, int length )
/Users/dirkolbrich/FreeCAD/freecad-source/src/CXX/Python3/Objects.hxx:2117:53: error: use of undeclared identifier 'PyUnicode_4BYTE_KIND'
: SeqBase<Char>( PyUnicode_FromKindAndData( PyUnicode_4BYTE_KIND, s, length ), true )
fatal error: too many errors emitted, stopping now [-ferror-limit=]
4 warnings and 20 errors generated.
Using Python 3.10 results in an error on the Boost library:
-- Could NOT find Boost: missing: python310 (found /opt/homebrew/lib/cmake/Boost-1.79.0/BoostConfig.cmake (found version "1.79.0"))
-- Could NOT find Boost: missing: python3 (found /opt/homebrew/lib/cmake/Boost-1.79.0/BoostConfig.cmake (found version "1.79.0"))
CMake Error at /opt/homebrew/lib/cmake/Boost-1.79.0/BoostConfig.cmake:141 (find_package):
Found package configuration file:
/opt/homebrew/lib/cmake/boost_python-1.79.0/boost_python-config.cmake
but it set boost_python_FOUND to FALSE so package "boost_python" is
considered to be NOT FOUND. Reason given by package:
No suitable build variant has been found.
The following variants have been tried and rejected:
* libboost_python39-mt.dylib (3.9, Boost_PYTHON_VERSION=3.10)
* libboost_python39-mt.a (3.9, Boost_PYTHON_VERSION=3.10)
* libboost_python39.dylib (3.9, Boost_PYTHON_VERSION=3.10)
* libboost_python39.a (3.9, Boost_PYTHON_VERSION=3.10)
/opt/homebrew/lib/cmake/Boost-1.79.0/BoostConfig.cmake:262 (boost_find_component)
/opt/homebrew/Cellar/cmake/3.23.2/share/cmake/Modules/FindBoost.cmake:594 (find_package)
src/Mod/Path/libarea/CMakeLists.txt:26 (find_package)
-- Configuring incomplete, errors occurred!
Either way, I'm out of ideas.
