FreeCAD Application Execution Aborted [SOLVED]
Hi everyone, I'm trying to run FreeCAD in the freecad-build/bin/ directory. Currently, I am running into a problem when I try to actually execute the application. It seems it can't boot the application and aborts immediately. You can see the message I get in the .png file I attached to this post.
I've compiled and built FreeCAD out of source using an ubuntu docker container on WSL-2 (Ubuntu 20.04). I reached 100% build but I may have missed some error/warning messages throughout the build process.
So far, I have tried executing the application in the same manner outside of the container, on WSL-2, but have had no luck. This time, however, I get an actual error message, here it is:
./FreeCAD: error while loading shared libraries: libFreeCADGui.so: cannot open shared object file: No such file or directory
I located libFreeCADGui.so in the freecad-build/lib/ directory. It seems like the issue is rooted at this "missing" shared object file but I'm not sure, can anyone here provide any assistance?
I am following the build guide for Ubuntu found in freecad-source/tools/build/README.rst.
- FreeCADExecuteAborted.PNG (33.02 KiB) Viewed 2456 times
Re: FreeCAD Application Execution Aborted
Hi and welcome to the forum!
You may get additional information by starting FreeCAD with the additional parameter --write-log, which creates a log file in your FreeCAD directory.
What does ldd FreeCAD say? In case it says that libFreeCADGui.so cannot be found you have to set LD_LIBRARY_PATH before running FreeCAD.
I've now set the LD_LIBRARY_PATH and I've resolved the missing dependencies; thanks for the ldd command. I've posted a txt file of the ldd FreeCAD message log to show that I have in fact linked all of the dependencies to LD_LIBRARY_PATH; yet, I am still getting aborted when I try to launch FreeCAD.
I have to launch FreeCAD from within the docker container, correct? I mean, why else would I have made it...
I am looking back into the errors, warnings, and missing components I saw being logged during the build process, so that may have to do with it. Here are a few of them after running make -j$(nproc --ignore=2):
1.
/bin/sh: 1: bzr: not found
/bin/sh: 1: svnversion: not found
/bin/sh: 1: svn: not found
Unknown version control
2.
[ 45%] Building CXX object src/App/CMakeFiles/FreeCADApp.dir/GeoFeatureGroupExtension.cpp.o
In file included from /builds/freecad-source/src/App/Expression.cpp
ExpressionParser.tab.c: In function 'int App::ExpressionParser::ExpressionParser_yyparse()':
ExpressionParser.tab.c18: warning: 'void free(void*)' called on unallocated object 'yyssa' [-Wfree-nonheap-object]
ExpressionParser.tab.c18: note: declared here
3.
I'm currently looking into these. Do you think these, or similar warnings, are the cause of the issue? Thanks.
1.
2.
3.
- ldd FreeCAD.txt
- (7.71 KiB) Downloaded 37 times
I wonder why it doesn't mention git here. But nevertheless, it's only about showing a version number in the About dialog. Nothing serious.1.
Can be ignored.2.
Same here.3.
The txt file mentions the Python version 3.10
A Debian user has reported a problem recently because his shiboken/PySide version is built against an older Python version. Can you double-check that your shiboken version depends on Python 3.10?libpython3.10.so.1.0 => /usr/lib/x86_64-linux-gnu/libpython3.10.so.1.0 (0x00007f7dffa7f000)
ldd /usr/lib/x86_64-linux-gnu/libshiboken2.cpython-310-x86_64-linux-gnu.so.5.15
ldd /usr/lib/x86_64-linux-gnu/libpyside2.cpython-310-x86_64-linux-gnu.so.5.15
Next thing to try is starting FreeCAD in a debugger because this may give us some clue where exactly it crashes.
gdb ./FreeCAD
run
bt
- adrianinsaval
are you trying to run the FreeCAD GUI? do other GUI apps run successfully from the docker container? in other words, do you have a properly configured and connected X server?
Out of curiosity, are you running docker for windows with the WSL backend or are you running docker inside WSL?
Thank you for the quick replies.
I believe I am running docker for windows with the WSL backend. I installed docker for windows (Docker Desktop) and now my docker commands work in WSL. The Docker Desktop app's displayed containers, images, and volumes are consistent with what I see on WSL, and in the general settings the "Use the WSL 2 based engine (Windows Home can only run the WSL 2 backend)" checkbox is checked.
I will try to run a different GUI app and get back to you. I'm going to dive into the windows x-server, VcXsrv.
I believe that my shiboken version does depend on Python 3.10.
I ran the gdb debugger and it seems I'm missing ./nptl/pthread_kill.c. I can't find it anywhere in my container.
I've got a lot of debugging to do so I probably won't update ya'll for a while. Thanks for the help!
Command Message Logs
This is the latest change log for libshiboken (/usr/share/doc/libshiboken2-dev/changelog.Debian.gz)
Here is the result of running
Here is what I get when I "run" the app in gdb and then "bt"
pyside2 (5.15.2-2build2) jammy; urgency=medium
* No-change rebuild against Qt 5.15.3.
-- Dmitry Shachnev <mitya57@ubuntu.com> Sat, 19 Mar 2022 21:58:20 +0300
pyside2 (5.15.2-2build1) jammy; urgency=medium
* No-change rebuild with Python 3.10 only.
-- Matthias Klose <doko@ubuntu.com> Thu, 17 Mar 2022 15:07:19 +0100
pyside2 (5.15.2-2) unstable; urgency=medium
* Backport upstream patches for Python 3.10 support (closes: #999369).
* Backport upstream patch to adapt for LLVM 12.01.
* Run build-time tests with all supported Python versions.
- Add a patch to make the tests find the matching build directory.
-- Dmitry Shachnev <mitya57@debian.org> Tue, 16 Nov 2021 12:16:14 +0300
root@7d8ce0a84ddd:/# ldd /usr/lib/x86_64-linux-gnu/libshiboken2.cpython-310-x86_64-linux-gnu.so.5.15
linux-vdso.so.1 (0x00007ffc2dd5f000)
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f0609e4d000)
libgcc_s.so.1 => /usr/lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f0609e2d000)
libc.so.6 => /usr/lib/x86_64-linux-gnu/libc.so.6 (0x00007f0609c05000)
libm.so.6 => /usr/lib/x86_64-linux-gnu/libm.so.6 (0x00007f0609b1e000)
/lib64/ld-linux-x86-64.so.2 (0x00007f060a0c7000)
root@7d8ce0a84ddd:/# ldd /usr/lib/x86_64-linux-gnu/libpyside2.cpython-310-x86_64-linux-gnu.so.5.15
linux-vdso.so.1 (0x00007ffc3369f000)
libshiboken2.cpython-310-x86_64-linux-gnu.so.5.15 => /usr/lib/x86_64-linux-gnu/libshiboken2.cpython-310-x86_64-linux-gnu.so.5.15 (0x00007f2f7160e000)
libQt5Qml.so.5 => /usr/lib/x86_64-linux-gnu/libQt5Qml.so.5 (0x00007f2f71184000)
libQt5Core.so.5 => /usr/lib/x86_64-linux-gnu/libQt5Core.so.5 (0x00007f2f70c25000)
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f2f709f9000)
libgcc_s.so.1 => /usr/lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f2f709d7000)
libc.so.6 => /usr/lib/x86_64-linux-gnu/libc.so.6 (0x00007f2f707af000)
libQt5Network.so.5 => /usr/lib/x86_64-linux-gnu/libQt5Network.so.5 (0x00007f2f705fe000)
libm.so.6 => /usr/lib/x86_64-linux-gnu/libm.so.6 (0x00007f2f70517000)
libz.so.1 => /usr/lib/x86_64-linux-gnu/libz.so.1 (0x00007f2f704fb000)
libdouble-conversion.so.3 => /usr/lib/x86_64-linux-gnu/libdouble-conversion.so.3 (0x00007f2f704e6000)
libicui18n.so.70 => /usr/lib/x86_64-linux-gnu/libicui18n.so.70 (0x00007f2f701b5000)
libicuuc.so.70 => /usr/lib/x86_64-linux-gnu/libicuuc.so.70 (0x00007f2f6ffba000)
libpcre2-16.so.0 => /usr/lib/x86_64-linux-gnu/libpcre2-16.so.0 (0x00007f2f6ff31000)
libzstd.so.1 => /usr/lib/x86_64-linux-gnu/libzstd.so.1 (0x00007f2f6fe62000)
libglib-2.0.so.0 => /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0 (0x00007f2f6fd28000)
/lib64/ld-linux-x86-64.so.2 (0x00007f2f7168d000)
libgssapi_krb5.so.2 => /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2 (0x00007f2f6fcd2000)
libicudata.so.70 => /usr/lib/x86_64-linux-gnu/libicudata.so.70 (0x00007f2f6e0b4000)
libpcre.so.3 => /usr/lib/x86_64-linux-gnu/libpcre.so.3 (0x00007f2f6e03e000)
libkrb5.so.3 => /usr/lib/x86_64-linux-gnu/libkrb5.so.3 (0x00007f2f6df73000)
libk5crypto.so.3 => /usr/lib/x86_64-linux-gnu/libk5crypto.so.3 (0x00007f2f6df44000)
libcom_err.so.2 => /usr/lib/x86_64-linux-gnu/libcom_err.so.2 (0x00007f2f6df3e000)
libkrb5support.so.0 => /usr/lib/x86_64-linux-gnu/libkrb5support.so.0 (0x00007f2f6df2e000)
libkeyutils.so.1 => /usr/lib/x86_64-linux-gnu/libkeyutils.so.1 (0x00007f2f6df27000)
libresolv.so.2 => /usr/lib/x86_64-linux-gnu/libresolv.so.2 (0x00007f2f6df13000)
(gdb) run
Starting program: /builds/Dev/freecad-build/bin/FreeCAD
warning: Error disabling address space randomization: Operation not permitted
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/usr/lib/x86_64-linux-gnu/libthread_db.so.1".
FreeCAD 0.20, Libs: 0.20RUnknown
© Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2022
FreeCAD is free and open-source software licensed under the terms of LGPL2+ license.
FreeCAD wouldn't be possible without FreeCAD community.
Program received signal SIGABRT, Aborted.
__pthread_kill_implementation (no_tid=0, signo=6, threadid=140023025111936) at ./nptl/pthread_kill.c:44
44 ./nptl/pthread_kill.c: No such file or directory.
(gdb) bt
#0 __pthread_kill_implementation (no_tid=0, signo=6, threadid=140023025111936) at ./nptl/pthread_kill.c:44
#1 __pthread_kill_internal (signo=6, threadid=140023025111936) at ./nptl/pthread_kill.c:78
#2 __GI___pthread_kill (threadid=140023025111936, signo=signo@entry=6) at ./nptl/pthread_kill.c:89
#3 0x00007f59ab8d4476 in __GI_raise (sig=sig@entry=6) at ../sysdeps/posix/raise.c:26
#4 0x00007f59ab8ba7f3 in __GI_abort () at ./stdlib/abort.c:79
#5 0x00007f59abd96ba3 in QMessageLogger::fatal(char const*, ...) const () from /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
#6 0x00007f59ac39d713 in QGuiApplicationPrivate::createPlatformIntegration() () from /usr/lib/x86_64-linux-gnu/libQt5Gui.so.5
#7 0x00007f59ac39dc08 in QGuiApplicationPrivate::createEventDispatcher() () from /usr/lib/x86_64-linux-gnu/libQt5Gui.so.5
#8 0x00007f59abfc6b07 in QCoreApplicationPrivate::init() () from /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
#9 0x00007f59ac3a0b70 in QGuiApplicationPrivate::init() () from /usr/lib/x86_64-linux-gnu/libQt5Gui.so.5
#10 0x00007f59acab4ced in QApplicationPrivate::init() () from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
#11 0x00007f59afc49c3d in Gui::GUIApplicationNativeEventAware::GUIApplicationNativeEventAware(int&, char**) () from /builds/Dev/freecad-build/lib/libFreeCADGui.so
#12 0x00007f59afc46f7b in Gui::GUIApplication::GUIApplication(int&, char**) () from /builds/Dev/freecad-build/lib/libFreeCADGui.so
#13 0x00007f59afc479ff in Gui::GUISingleApplication::GUISingleApplication(int&, char**) () from /builds/Dev/freecad-build/lib/libFreeCADGui.so
#14 0x00007f59afaf0154 in Gui::Application::runApplication() () from /builds/Dev/freecad-build/lib/libFreeCADGui.so
#15 0x000055b74ca13b6c in main ()
(gdb) exit
That's the actual problem.
What's the output of?
And is the environment variable QT_QPA_PLATFORM set? You can check it with
In order to run the GUI of Qt you need a plugin to support your platform. What's the display protocol that you use on that system? Wayland or X Window?#4 0x00007f59ab8ba7f3 in __GI_abort () at ./stdlib/abort.c:79
ls /usr/lib/x86_64-linux-gnu/qt5/plugins/platforms/
echo $QT_QPA_PLATFORM
- adrianinsaval
Does this mean you had not installed and configured vcxsrv before? If not that is a prerequisite for running GUI apps on WSL on windows 10 (11 I think has built-in support for wayland but I have not tried win11 yet). IIRC setting up an x-server for WSL2 is more complicated than WSL1 so pay attention to find tutorials corresponding to your WSL version.
Re: FreeCAD Application Execution Aborted - WSL 2 - [SOLVED]
You guys have been crazy helpful. I managed to get FreeCAD up and running after installing and configuring Windows X Server, VcXSrv.
Check out the attachment for a photo of a cool rocket engine injector I designed (using SolidWorks) in university that I loaded into FreeCAD!
Unfortunately, it is running at like < 5 fps. This, in addition to taking 45 minutes on my laptop to build the source files, seems like developing the code is going to be impossible. I am going to give it a shot on my beefed up gaming desktop pc, but, do you have any software development tips, generally speaking and pertaining to FreeCAD, that I can implement to modify the source code and debug efficiently?
Additional Debug Info
I followed this guide to set-up VcXSrv for WSL-2:
https://stackoverflow.com/questions/667 ... -with-wsl2
I get this warning after launching FreeCAD, doesn't seem like a big deal. I installed the packages nonetheless.
Result of running ls /usr/lib/x86_64-linux-gnu/qt5/plugins/platforms/
Result of running echo $QT_QPA_PLATFORM
^ No response
Addon Manager Warning: Could not import QtWebEngineWidgets, it seems to be missing from your system.
Please use your system's package manager to install the python3-pyside2.qtwebengine* and
python3-pyside2.qtwebchannel packages, and if possible alert your package creator to the missing dependency.
Display of package README will be limited until this dependency is resolved.
root@1598ddfc5e2c:/builds/freecad-build/bin# ls /usr/lib/x86_64-linux-gnu/qt5/plugins/platforms/
libqeglfs.so libqlinuxfb.so libqminimal.so libqminimalegl.so libqoffscreen.so libqvnc.so libqxcb.so
root@1598ddfc5e2c:/builds/freecad-build/bin# echo $QT_QPA_PLATFORM
