Lots of errors when activate Draft
_AndreaS_
Post by _AndreaS_ »
I write here because I think this is an install issue. I installed FreeCad under Ubuntu 22.04 using `apt`:
OS: Ubuntu 22.04 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.
Python version: 3.10.2
Qt version: 5.15.2
OCC version: 7.5.1
Locale: Italian/Italy (it_IT)
When I activate the Draft workbench I get the following errors:
15:17:35  Persistent toolbars: Snapper toolbar not managed.
15:17:35  <built-in function SoFieldContainer_getField> returned a result with an exception set
15:17:35  Traceback (most recent call last):
  File "<string>", line 132, in Activated
  File "/usr/share/freecad/Mod/Draft/draftguitools/gui_snapper.py", line 1635, in show
    self.setTrackers()
  File "/usr/share/freecad/Mod/Draft/draftguitools/gui_snapper.py", line 1679, in setTrackers
    self.grid = trackers.gridTracker()
  File "/usr/share/freecad/Mod/Draft/draftguitools/gui_trackers.py", line 974, in __init__
    pick.style.setValue(coin.SoPickStyle.UNPICKABLE)
  File "/usr/lib/python3/dist-packages/pivy/coin.py", line 3989, in __getattr__
    field = self.getField(name)
  File "/usr/lib/python3/dist-packages/pivy/coin.py", line 3873, in getField
    return _coin.SoFieldContainer_getField(self, name)
if I try to click any function, like scale:
15:19:55  Running the Python command 'Draft_Scale' failed:
  File "/usr/share/freecad/Mod/Draft/draftguitools/gui_scale.py", line 77, in Activated
    super(Scale, self).Activated(name=self.name)
  File "/usr/share/freecad/Mod/Draft/draftguitools/gui_base_original.py", line 154, in Activated
    Gui.Snapper.setTrackers()
Is it a known behavior? How to fix it?
adrianinsaval
Re: Lots of errors when activate Draft
Post by adrianinsaval »
Ubuntu's build is broken IIRC, please install and test with another method, there are appimage, flatpak and snap available and a ppa but I think the ppa doesn't have 22.04 builds yet. These alternative methods also have the advantage of letting you update to 0.20 which is about to be released as stable.
dpward
Post by dpward »
Fix released for pivy package in Ubuntu 22.04 LTS (and Ubuntu 22.10).
https://bugs.launchpad.net/ubuntu/+sour ... ug/2000840
