Hello!
This is not a question, but a solution. I post it in case somebody has the same problem.
I have setup a new machine with the latest Ubuntu version (22.04).
I have downloaded the latest FreeCad app image.
After running chmod 755 to make it executable, it didn't run by double-click
I retried from the terminal just in case there are error messages, and the program replied that
fuse library cannot be found.
On the other hand, checking fuse revealed that it was installed.
Just in case, I ran apt-get install fuse, and this time it fixed everything, it just works.
R
Freecad AppImage run
Re: Freecad AppImage run
Full About info please?
There is fuse3 in the Ubuntu 22.04. You can't just install fuse, it breaks another packages.
- Screenshot_20220526_210830.png (10.79 KiB) Viewed 511 times
