Unreponsive Toolbar and Glitching Display - Version 0.20
Bebopity
Post by Bebopity »
Hi everyone, I'm trying to run FreeCAD after installing and building it in a docker container. I am able to launch FreeCAD, but currently I am running into a problem when I try to create a new file and just navigate FreeCAD in general. It seems that the rest of the toolbar is unresponsive; so, essentially I cannot do anything on the app. Also, when I try to resize the window, it glitches out. You can see what I'm talking about in the image I attached to this post.
I've compiled and built FreeCAD out of source using an ubuntu 22.04 docker container on an Ubuntu 22.04 machine.
I'm not sure where to start looking for potential resolutions. Any assistance is appreciated, thanks.
Build files
This is my docker-compose.yml file
version: "3"
services:
  app:
    image: freecad-ubuntu
    build: .
    environment:
      DISPLAY: ${DISPLAY}
      GITLAB_REPOS: ${GITLAB_REPOS}
    volumes:
      - /tmp/.X11-unix:/tmp/.X11-unix
      - $GITLAB_REPOS/eliotkh12/freecad/:/builds
    network_mode: host
volumes:
  .X11-unix:
  freecad:
This is my dockerfile
FROM ubuntu:rolling
ENV DEBIAN_FRONTEND=noninteractive
ENV TZ=Etc/UTC
ENV UTC=true
ENV ARC=false
COPY ubuntu.sh /tmp
COPY xauth_list /tmp # file that contains host x socket info (user@hostname:1 MIT-MAGIC-COOKIE-1 [32-character hexadecimal])
RUN apt-get update && \
    apt-get upgrade --yes && \
    sh /tmp/ubuntu.sh && \
    mkdir /builds && \
    touch ~/.Xauthority && \
    xauth add $(cat /tmp/xauth_list)
WORKDIR /builds
VOLUME [ "/builds" ]
CMD [ "bash" ]
Screenshot from 2022-05-27 22-55-16.png (586.65 KiB) Viewed 1273 times
Re: Unreponsive Toolbar and Glitching Display - Version 0.20
Post by Kunda1 »
Do you get the same results running the nightly snap package?
Bebopity
Post by Bebopity »
Nope. Running FreeCAD 0.19 on snap works just fine.
Although, I am getting this error:
Adding snap-specific PYTHONPATH to sys.path: /home/eliot/snap/freecad/common/.local/lib/python3.8/site-packages:/snap/freecad/29/lib/python3.8/site-packages:/snap/freecad/29/usr/lib/python3/dist-packages
connect failed: No such file or directory
It doesn't seem to affect the app.
Post by Kunda1 »
connect failed: No such file or directory is not error and it's unrelated (it's related to 3dsconnexion spacemouse stuff).
The snap Path stuff is just a heads up (not an error). Try testing the Snap 'edge' to see if you have an issue. The 3dsconnexion warning doesn't exist in 'edge'
nightly = 'edge'
snap install --edge freecad
Edit: See Snap
Edit2: correction
Bebopity
Post by Bebopity »
No issue with Snap edge. I'm going to try installing and building FreeCAD 0.19 in another docker container and see if there are any issues.
Edit 1: Clarification: running freecad 'edge' gave this warning message but launched and functions without any problems:
Bebopity
Post by Bebopity »
I tried disabling Wayland to fix this issue by following this post: https://forum.freecadweb.org/viewtopic.php?f=4&t=68839
No luck... Specifically, I disabled wayland in my /etc/gdm3/custom.conf on my host machine, not in the docker container. Now that I think about it, the docker container probably never had Wayland as an option. Anyway...
The post made me consider that my nvidia driver was the issue. I was using
Using NVIDIA driver metapackage from nvidia-driver-510 (proprietary, tested)
, but I tried to switching drivers to:
Using NVIDIA Server Driver metapackage from nvidia-driver-470-server (proprietary)
After restarting my PC, I lost the ability to detect network interfaces and lost internet connection... No idea what happened. When reinstalling Ubuntu (lol) I chose the option to automatically install drivers and now I am using a manually installed driver.
Screenshot from 2022-06-07 20-45-50.png (62.27 KiB) Viewed 731 times
... which is strange because last time I chose that install option it chose
for me.
I assume my original driver was the root of my problem since freecad in my docker container is now functioning properly: no glitching display; app doesn't hang on 'new file'.
