After compiling then launching freecad 0.20.0 from terminal using win 7-64 with msys2 and clang
it gives these lines with an error
Sheet Metal workbench loaded
Coin warning in cc_glglue_instance(): Error when setting up the GL context. This can happen if there is no current context, or if the context has been set up incorrectly.
Segmentation fault
thanx.
