FreeCAD 0.20 bulid with Win11 VS2022
djxiaoaa
Post by djxiaoaa »
Hello everyone,
I'm new here. I have clone the last official 0.20 version from git and build it with the new LibPack on window 11.
Everything is ok. But when I run FreeCAD and try to open an existing file, the application has got a CD at "src\vcruntime\delete_scalar.cpp".
Here is the stack:
 	ntdll.dll!00007ff9bdc0726e()	Unknown
 	ntdll.dll!00007ff9bdbcdef6()	Unknown
 	ntdll.dll!00007ff9bdb7bc91()	Unknown
 	KernelBase.dll!00007ff9bb67cd7b()	Unknown
 	ucrtbased.dll!00007ff91a7ce852()	Unknown
 	ucrtbased.dll!00007ff91a7cca91()	Unknown
 	ucrtbased.dll!00007ff91a7d0275()	Unknown
>	Part_d.pyd!operator delete(void * block) Line 38	C++
 	Part_d.pyd!operator delete[](void * block) Line 32	C++
 	Part_d.pyd!NCollection_Array1<int>::~NCollection_Array1<int>() Line 435	C++
 	[External Code]
 	Part_d.pyd!Part::Tools::getPointNormals(const TopoDS_Face & theFace, opencascade::handle<Poly_Triangulation> aPolyTri, NCollection_Array1<gp_Dir> & theNormals) Line 577	C++
 	PartGui_d.pyd!PartGui::ViewProviderPartExt::updateVisual() Line 1080	C++
 	PartGui_d.pyd!PartGui::ViewProviderPartExt::onChanged(const App::Property * prop) Line 367	C++
 	PartDesignGui_d.pyd!PartDesignGui::ViewProviderBody::onChanged(const App::Property * prop) Line 398	C++
 	FreeCADApp_d.dll!App::Property::hasSetValue() Line 232	C++
I have built the 0.19 version, there was no problem. Does anyone can help? Thanks in advance.
djxiaoaa
Re: FreeCAD 0.20 bulid with Win11 VS2022
Post by djxiaoaa »
Update for this topic. The CD is only reproduceable with Debug Build.
And everything is ok for the moment with Release Build.
void __CRTDECL operator delete(void* const block) noexcept
    #ifdef _DEBUG
    _free_dbg(block, _UNKNOWN_BLOCK);
    #else
    free(block);
    #endif
adrianinsaval
Post by adrianinsaval »
@wmayer check this out, is the debug code wrong?
Founder
Post by wmayer »
Something with OCC must be wrong. I had exactly the same problem some years ago with a debug build but I cannot remember if I found the root problem. I had the problem with a pre-built OCC version of the LibPack but a locally built OCC version worked fine.
Are you sure that you use the OCC debug build for the FreeCAD debug build?
djxiaoaa
Post by djxiaoaa »
Thank you for the information.
I just followed the step on the wiki page to build the FreeCAD 0.20 with the new version LibPack (https://github.com/FreeCAD/FreeCAD-LibP ... es/tag/2.6).
What do you mean OCC debug build, is there an option in cmake configuration ?
wangzijun77
Post by wangzijun77 »
Yes, this is a problem related to occ 7.6+, it will be gone if you use those libpacks with occ7.5.3
djxiaoaa
Post by djxiaoaa »
wangzijun77 wrote: Tue Jul 26, 2022 9:51 am Yes, this is a problem related to occ 7.6+, it will be gone if you use those libpacks with occ7.5.3
Thanks. That means I can build the 0.20 with the old LibPack 1.x version?
To be honest, I'm a bit curious as to how their FreeCAD programmers work when it comes to 0.20 with 2.x version LibPack. Compiling without debug mode is a real pain.
laien1900
Post by laien1900 »
I fix this by copying LibPack-OCC76-V2\bind into the build path bin(debug) folder. I think you should gengerate [debug] and [release] to different folder
