Here's the info about the build in question:
OS: Windows 10 Version 2009
Version: 0.21.29331 (Git)
Build type: Debug
Hash: d13db0ea4c19a985a73a7bc30a24fe0598a21f6b
Installed mods:
* FC_TabbedBoxWorkbench
I am using the latest version of VS2019. I ensure that C++17 is the compiler version being used. The source was checked out this morning (9AM CDT) from master using TortoiseGit. It is built with LibPack-OCC76-V2-6. I did a clean and then build on the project, with no errors reported.
I opened the Dependency Walker application and opened _PARTDESIGN_D.PYD to check it. When the processing completed I had the following errors reported:
Error: At least one required implicit or forwarded dependency was not found.
Error: At least one module has an unresolved import due to a missing export function in an implicitly dependent module.
Error: A circular dependency was detected.
Warning: At least one delay-load dependency module was not found.
Warning: At least one module has an unresolved import due to a missing export function in a delay-load dependent module.
API-MS-WIN-CORE-APIQUERY-L1-1-0.DLL
API-MS-WIN-CORE-APIQUERY-L1-1-1.DLL
API-MS-WIN-CORE-APPCOMPAT-L1-1-0.DLL
API-MS-WIN-CORE-APPCOMPAT-L1-1-1.DLL
API-MS-WIN-CORE-COMM-L1-1-0.DLL
API-MS-WIN-CORE-CONSOLE-L1-2-1.DLL
API-MS-WIN-CORE-CONSOLE-L2-1-0.DLL
API-MS-WIN-CORE-CONSOLE-L2-2-0.DLL
API-MS-WIN-CORE-CONSOLE-L3-2-0.DLL
API-MS-WIN-CORE-CRT-L1-1-0.DLL
API-MS-WIN-CORE-CRT-L2-1-0.DLL
API-MS-WIN-CORE-DATETIME-L1-1-1.DLL
API-MS-WIN-CORE-DATETIME-L1-1-2.DLL
API-MS-WIN-CORE-DEBUG-L1-1-1.DLL
API-MS-WIN-CORE-DELAYLOAD-L1-1-0.DLL
API-MS-WIN-CORE-DELAYLOAD-L1-1-1.DLL
API-MS-WIN-CORE-ERRORHANDLING-L1-1-2.DLL
API-MS-WIN-CORE-ERRORHANDLING-L1-1-3.DLL
API-MS-WIN-CORE-FIBERS-L1-1-0.DLL
API-MS-WIN-CORE-FIBERS-L2-1-0.DLL
API-MS-WIN-CORE-FIBERS-L2-1-1.DLL
API-MS-WIN-CORE-FILE-L1-2-1.DLL
API-MS-WIN-CORE-FILE-L1-2-2.DLL
API-MS-WIN-CORE-FILE-L2-1-1.DLL
API-MS-WIN-CORE-FILE-L2-1-2.DLL
API-MS-WIN-CORE-FILE-L2-1-3.DLL
API-MS-WIN-CORE-HEAP-L2-1-0.DLL
API-MS-WIN-CORE-IO-L1-1-0.DLL
API-MS-WIN-CORE-IO-L1-1-1.DLL
API-MS-WIN-CORE-JOB-L1-1-0.DLL
API-MS-WIN-CORE-LARGEINTEGER-L1-1-0.DLL
API-MS-WIN-CORE-LIBRARYLOADER-L1-2-0.DLL
API-MS-WIN-CORE-LIBRARYLOADER-L1-2-1.DLL
API-MS-WIN-CORE-LIBRARYLOADER-L1-2-2.DLL
API-MS-WIN-CORE-LIBRARYLOADER-L2-1-0.DLL
API-MS-WIN-CORE-LOCALIZATION-L2-1-0.DLL
API-MS-WIN-CORE-LOCALIZATION-PRIVATE-L1-1-0.DLL
API-MS-WIN-CORE-MEMORY-L1-1-1.DLL
API-MS-WIN-CORE-MEMORY-L1-1-2.DLL
API-MS-WIN-CORE-MISC-L1-1-0.DLL
API-MS-WIN-CORE-NAMEDPIPE-L1-2-1.DLL
API-MS-WIN-CORE-NAMEDPIPE-L1-2-2.DLL
API-MS-WIN-CORE-NAMESPACE-L1-1-0.DLL
API-MS-WIN-CORE-NORMALIZATION-L1-1-0.DLL
API-MS-WIN-CORE-PCW-L1-1-0.DLL
API-MS-WIN-CORE-PROCESSENVIRONMENT-L1-2-0.DLL
API-MS-WIN-CORE-PROCESSSNAPSHOT-L1-1-0.DLL
API-MS-WIN-CORE-PROCESSTHREADS-L1-1-2.DLL
API-MS-WIN-CORE-PROCESSTHREADS-L1-1-3.DLL
API-MS-WIN-CORE-PROCESSTOPOLOGY-L1-1-0.DLL
API-MS-WIN-CORE-PSAPI-ANSI-L1-1-0.DLL
API-MS-WIN-CORE-PSAPI-L1-1-0.DLL
API-MS-WIN-CORE-REALTIME-L1-1-0.DLL
API-MS-WIN-CORE-REGISTRY-L1-1-0.DLL
API-MS-WIN-CORE-REGISTRY-L1-1-1.DLL
API-MS-WIN-CORE-REGISTRY-L1-1-2.DLL
API-MS-WIN-CORE-SIDEBYSIDE-L1-1-0.DLL
API-MS-WIN-CORE-SYNCH-L1-2-1.DLL
API-MS-WIN-CORE-SYSINFO-L1-2-0.DLL
API-MS-WIN-CORE-SYSINFO-L1-2-1.DLL
API-MS-WIN-CORE-SYSINFO-L1-2-3.DLL
API-MS-WIN-CORE-SYSTEMTOPOLOGY-L1-1-0.DLL
API-MS-WIN-CORE-SYSTEMTOPOLOGY-L1-1-1.DLL
API-MS-WIN-CORE-THREADPOOL-L1-2-0.DLL
API-MS-WIN-CORE-THREADPOOL-LEGACY-L1-1-0.DLL
API-MS-WIN-CORE-THREADPOOL-PRIVATE-L1-1-0.DLL
API-MS-WIN-CORE-WINDOWSERRORREPORTING-L1-1-0.DLL
API-MS-WIN-CORE-WINDOWSERRORREPORTING-L1-1-1.DLL
API-MS-WIN-CORE-WINDOWSERRORREPORTING-L1-1-2.DLL
API-MS-WIN-CORE-WINDOWSERRORREPORTING-L1-1-3.DLL
API-MS-WIN-CORE-WOW64-L1-1-0.DLL
API-MS-WIN-CORE-WOW64-L1-1-1.DLL
API-MS-WIN-CORE-WOW64-L1-1-3.DLL
API-MS-WIN-CORE-XSTATE-L2-1-0.DLL
API-MS-WIN-CORE-XSTATE-L2-1-1.DLL
API-MS-WIN-EVENTING-CONSUMER-L1-1-0.DLL
API-MS-WIN-EVENTING-CONSUMER-L1-1-1.DLL
API-MS-WIN-EVENTING-CONTROLLER-L1-1-0.DLL
API-MS-WIN-EVENTING-PROVIDER-L1-1-0.DLL
API-MS-WIN-SECURITY-APPCONTAINER-L1-1-0.DLL
API-MS-WIN-SECURITY-AUDIT-L1-1-0.DLL
API-MS-WIN-SECURITY-AUDIT-L1-1-1.DLL
API-MS-WIN-SECURITY-BASE-L1-1-0.DLL
API-MS-WIN-SECURITY-BASE-L1-2-0.DLL
API-MS-WIN-SECURITY-BASE-PRIVATE-L1-1-0.DLL
API-MS-WIN-SERVICE-CORE-L1-1-0.DLL
API-MS-WIN-SERVICE-CORE-L1-1-1.DLL
API-MS-WIN-SERVICE-CORE-L1-1-2.DLL
API-MS-WIN-SERVICE-MANAGEMENT-L1-1-0.DLL
API-MS-WIN-SERVICE-MANAGEMENT-L2-1-0.DLL
API-MS-WIN-SERVICE-PRIVATE-L1-1-0.DLL
API-MS-WIN-SERVICE-PRIVATE-L1-1-2.DLL
API-MS-WIN-SERVICE-PRIVATE-L1-1-3.DLL
API-MS-WIN-SERVICE-PRIVATE-L1-1-4.DLL
API-MS-WIN-SERVICE-WINSVC-L1-1-0.DLL
FREECADAPP_D.DLL
FREECADBASE_D.DLL
PART_D.PYD
PYTHON38_D.DLL
TKBO.DLL
TKBOOL.DLL
TKBREP.DLL
TKERNEL.DLL
TKFEAT.DLL
TKFILLET.DLL
TKG2D.DLL
TKG3D.DLL
TKGEOMALGO.DLL
TKGEOMBASE.DLL
TKIGES.DLL
TKMATH.DLL
TKOFFSET.DLL
TKPRIM.DLL
TKSHHEALING.DLL
TKTOPALGO.DLL
TKXSBASE.DLL
API-MS-WIN-APPMODEL-IDENTITY-L1-2-0.DLL
API-MS-WIN-APPMODEL-RUNTIME-INTERNAL-L1-1-1.DLL
API-MS-WIN-APPMODEL-RUNTIME-INTERNAL-L1-1-2.DLL
API-MS-WIN-APPMODEL-RUNTIME-INTERNAL-L1-1-3.DLL
API-MS-WIN-APPMODEL-RUNTIME-INTERNAL-L1-1-7.DLL
API-MS-WIN-APPMODEL-RUNTIME-L1-1-0.DLL
API-MS-WIN-APPMODEL-RUNTIME-L1-1-1.DLL
API-MS-WIN-APPMODEL-STATE-L1-2-0.DLL
API-MS-WIN-APPMODEL-UNLOCK-L1-1-0.DLL
API-MS-WIN-BASE-UTIL-L1-1-0.DLL
API-MS-WIN-CONTAINERS-CMCLIENT-L1-1-0.DLL
API-MS-WIN-CONTAINERS-CMCLIENT-L1-2-0.DLL
API-MS-WIN-CORE-APIQUERY-L2-1-0.DLL
API-MS-WIN-CORE-APPINIT-L1-1-0.DLL
API-MS-WIN-CORE-ATOMS-L1-1-0.DLL
API-MS-WIN-CORE-CALENDAR-L1-1-0.DLL
API-MS-WIN-CORE-COM-L1-1-0.DLL
API-MS-WIN-CORE-COM-L1-1-1.DLL
API-MS-WIN-CORE-COM-L1-1-2.DLL
API-MS-WIN-CORE-COM-L2-1-1.DLL
API-MS-WIN-CORE-COM-MIDLPROXYSTUB-L1-1-0.DLL
API-MS-WIN-CORE-COM-PRIVATE-L1-1-0.DLL
API-MS-WIN-CORE-COM-PRIVATE-L1-1-1.DLL
API-MS-WIN-CORE-COM-PRIVATE-L1-2-0.DLL
API-MS-WIN-CORE-COM-PRIVATE-L1-3-0.DLL
API-MS-WIN-CORE-DEBUG-MINIDUMP-L1-1-0.DLL
API-MS-WIN-CORE-FEATURESTAGING-L1-1-0.DLL
API-MS-WIN-CORE-FIBERS-L1-1-1.DLL
API-MS-WIN-CORE-HEAP-OBSOLETE-L1-1-0.DLL
API-MS-WIN-CORE-JOB-L2-1-0.DLL
API-MS-WIN-CORE-KERNEL32-LEGACY-L1-1-0.DLL
API-MS-WIN-CORE-KERNEL32-LEGACY-L1-1-1.DLL
API-MS-WIN-CORE-KERNEL32-LEGACY-L1-1-2.DLL
API-MS-WIN-CORE-KERNEL32-PRIVATE-L1-1-0.DLL
API-MS-WIN-CORE-KERNEL32-PRIVATE-L1-1-1.DLL
API-MS-WIN-CORE-KERNEL32-PRIVATE-L1-1-2.DLL
API-MS-WIN-CORE-LOCALIZATION-L1-1-0.DLL
API-MS-WIN-CORE-LOCALIZATION-L1-2-2.DLL
API-MS-WIN-CORE-LOCALIZATION-OBSOLETE-L1-2-0.DLL
API-MS-WIN-CORE-LOCALREGISTRY-L1-1-0.DLL
API-MS-WIN-CORE-MARSHAL-L1-1-0.DLL
API-MS-WIN-CORE-MEMORY-L1-1-3.DLL
API-MS-WIN-CORE-MEMORY-L1-1-5.DLL
API-MS-WIN-CORE-PATH-L1-1-0.DLL
API-MS-WIN-CORE-PRIVATEPROFILE-L1-1-0.DLL
API-MS-WIN-CORE-PRIVATEPROFILE-L1-1-1.DLL
API-MS-WIN-CORE-PROCESSTOPOLOGY-OBSOLETE-L1-1-0.DLL
API-MS-WIN-CORE-PSM-APP-L1-1-0.DLL
API-MS-WIN-CORE-PSM-APPNOTIFY-L1-1-0.DLL
API-MS-WIN-CORE-PSM-KEY-L1-1-0.DLL
API-MS-WIN-CORE-QUIRKS-L1-1-0.DLL
API-MS-WIN-CORE-REALTIME-L1-1-1.DLL
API-MS-WIN-CORE-REGISTRY-L2-1-0.DLL
API-MS-WIN-CORE-REGISTRY-PRIVATE-L1-1-0.DLL
API-MS-WIN-CORE-REGISTRYUSERSPECIFIC-L1-1-0.DLL
API-MS-WIN-CORE-SHLWAPI-LEGACY-L1-1-0.DLL
API-MS-WIN-CORE-SHLWAPI-OBSOLETE-L1-1-0.DLL
API-MS-WIN-CORE-SHUTDOWN-L1-1-0.DLL
API-MS-WIN-CORE-STRING-L2-1-0.DLL
API-MS-WIN-CORE-STRING-L2-1-1.DLL
API-MS-WIN-CORE-STRING-OBSOLETE-L1-1-0.DLL
API-MS-WIN-CORE-STRINGANSI-L1-1-0.DLL
API-MS-WIN-CORE-SYNCH-ANSI-L1-1-0.DLL
API-MS-WIN-CORE-SYSINFO-L2-1-0.DLL
API-MS-WIN-CORE-TEXTINPUT-CLIENT-L1-1-0.DLL
API-MS-WIN-CORE-TEXTINPUT-CLIENT-L1-1-1.DLL
API-MS-WIN-CORE-TOOLHELP-L1-1-0.DLL
API-MS-WIN-CORE-URL-L1-1-0.DLL
API-MS-WIN-CORE-VERSION-L1-1-0.DLL
API-MS-WIN-CORE-VERSION-L1-1-1.DLL
API-MS-WIN-CORE-VERSION-PRIVATE-L1-1-0.DLL
API-MS-WIN-CORE-VERSIONANSI-L1-1-0.DLL
API-MS-WIN-CORE-VERSIONANSI-L1-1-1.DLL
API-MS-WIN-CORE-WINRT-ERROR-L1-1-0.DLL
API-MS-WIN-CORE-WINRT-ERROR-L1-1-1.DLL
API-MS-WIN-CORE-WINRT-ERRORPRIVATE-L1-1-0.DLL
API-MS-WIN-CORE-WINRT-L1-1-0.DLL
API-MS-WIN-CORE-WINRT-PROPERTYSETPRIVATE-L1-1-0.DLL
API-MS-WIN-CORE-WINRT-PROPERTYSETPRIVATE-L1-1-1.DLL
API-MS-WIN-CORE-WINRT-REGISTRATION-L1-1-0.DLL
API-MS-WIN-CORE-WINRT-ROBUFFER-L1-1-0.DLL
API-MS-WIN-CORE-WINRT-STRING-L1-1-0.DLL
API-MS-WIN-COREUI-SECRUNTIME-L1-1-0.DLL
API-MS-WIN-DEVICES-CONFIG-L1-1-1.DLL
API-MS-WIN-DEVICES-QUERY-L1-1-0.DLL
API-MS-WIN-DOWNLEVEL-ADVAPI32-L1-1-0.DLL
API-MS-WIN-DOWNLEVEL-ADVAPI32-L2-1-0.DLL
API-MS-WIN-DOWNLEVEL-KERNEL32-L1-1-0.DLL
API-MS-WIN-DOWNLEVEL-KERNEL32-L2-1-0.DLL
API-MS-WIN-DOWNLEVEL-NORMALIZ-L1-1-0.DLL
API-MS-WIN-DOWNLEVEL-OLE32-L1-1-0.DLL
API-MS-WIN-DOWNLEVEL-SHELL32-L1-1-0.DLL
API-MS-WIN-DOWNLEVEL-SHLWAPI-L1-1-0.DLL
API-MS-WIN-DOWNLEVEL-SHLWAPI-L2-1-0.DLL
API-MS-WIN-DOWNLEVEL-USER32-L1-1-0.DLL
API-MS-WIN-DOWNLEVEL-VERSION-L1-1-0.DLL
API-MS-WIN-DWMAPI-L1-1-0.DLL
API-MS-WIN-DX-D3DKMT-L1-1-0.DLL
API-MS-WIN-DX-D3DKMT-L1-1-1.DLL
API-MS-WIN-DX-D3DKMT-L1-1-3.DLL
API-MS-WIN-DX-D3DKMT-L1-1-4.DLL
API-MS-WIN-EVENTING-CLASSICPROVIDER-L1-1-0.DLL
API-MS-WIN-EVENTING-LEGACY-L1-1-0.DLL
API-MS-WIN-EVENTING-OBSOLETE-L1-1-0.DLL
API-MS-WIN-EVENTING-TDH-L1-1-0.DLL
API-MS-WIN-EVENTLOG-LEGACY-L1-1-0.DLL
API-MS-WIN-GDI-DPIINFO-L1-1-0.DLL
API-MS-WIN-GDI-INTERNAL-UAP-L1-1-0.DLL
API-MS-WIN-HTTP-TIME-L1-1-0.DLL
API-MS-WIN-MM-MISC-L1-1-0.DLL
API-MS-WIN-MM-MISC-L2-1-0.DLL
API-MS-WIN-MM-MME-L1-1-0.DLL
API-MS-WIN-MM-TIME-L1-1-0.DLL
API-MS-WIN-NETWORKING-INTERFACECONTEXTS-L1-1-0.DLL
API-MS-WIN-NTUSER-RECTANGLE-L1-1-0.DLL
API-MS-WIN-NTUSER-SYSPARAMS-L1-1-0.DLL
API-MS-WIN-OLE32-IE-L1-1-0.DLL
API-MS-WIN-OOBE-NOTIFICATION-L1-1-0.DLL
API-MS-WIN-POWER-BASE-L1-1-0.DLL
API-MS-WIN-POWER-SETTING-L1-1-0.DLL
API-MS-WIN-RO-TYPERESOLUTION-L1-1-0.DLL
API-MS-WIN-RTCORE-NTUSER-CLIPBOARD-L1-1-0.DLL
API-MS-WIN-RTCORE-NTUSER-PRIVATE-L1-1-0.DLL
API-MS-WIN-RTCORE-NTUSER-PRIVATE-L1-1-1.DLL
API-MS-WIN-RTCORE-NTUSER-PRIVATE-L1-1-2.DLL
API-MS-WIN-RTCORE-NTUSER-PRIVATE-L1-1-4.DLL
API-MS-WIN-RTCORE-NTUSER-PRIVATE-L1-1-7.DLL
API-MS-WIN-RTCORE-NTUSER-PRIVATE-L1-1-9.DLL
API-MS-WIN-RTCORE-NTUSER-SHELL-L1-1-0.DLL
API-MS-WIN-RTCORE-NTUSER-SYNCH-L1-1-0.DLL
API-MS-WIN-RTCORE-NTUSER-WINDOW-L1-1-0.DLL
API-MS-WIN-RTCORE-NTUSER-WINEVENT-L1-1-0.DLL
API-MS-WIN-RTCORE-NTUSER-WMPOINTER-L1-1-0.DLL
API-MS-WIN-SECURITY-ACCESSHLPR-L1-1-0.DLL
API-MS-WIN-SECURITY-ACTIVEDIRECTORYCLIENT-L1-1-0.DLL
API-MS-WIN-SECURITY-ACTIVEDIRECTORYCLIENT-L1-1-1.DLL
API-MS-WIN-SECURITY-BASE-L1-2-1.DLL
API-MS-WIN-SECURITY-BASE-PRIVATE-L1-1-1.DLL
API-MS-WIN-SECURITY-CAPABILITY-L1-1-0.DLL
API-MS-WIN-SECURITY-CREDENTIALS-L1-1-0.DLL
API-MS-WIN-SECURITY-CREDENTIALS-L2-1-0.DLL
API-MS-WIN-SECURITY-CRYPTOAPI-L1-1-0.DLL
API-MS-WIN-SECURITY-GROUPPOLICY-L1-1-0.DLL
API-MS-WIN-SECURITY-ISOLATEDCONTAINER-L1-1-0.DLL
API-MS-WIN-SECURITY-ISOLATIONPOLICY-L1-2-0.DLL
API-MS-WIN-SECURITY-LOGON-L1-1-0.DLL
API-MS-WIN-SECURITY-LOGON-L1-1-1.DLL
API-MS-WIN-SECURITY-LSALOOKUP-ANSI-L2-1-0.DLL
API-MS-WIN-SECURITY-LSALOOKUP-L1-1-0.DLL
API-MS-WIN-SECURITY-LSALOOKUP-L1-1-1.DLL
API-MS-WIN-SECURITY-LSALOOKUP-L1-1-2.DLL
API-MS-WIN-SECURITY-LSALOOKUP-L2-1-0.DLL
API-MS-WIN-SECURITY-LSAPOLICY-L1-1-0.DLL
API-MS-WIN-SECURITY-PROVIDER-L1-1-0.DLL
API-MS-WIN-SECURITY-SDDL-L1-1-0.DLL
API-MS-WIN-SECURITY-SDDLPARSECOND-L1-1-0.DLL
API-MS-WIN-SECURITY-SYSTEMFUNCTIONS-L1-1-0.DLL
API-MS-WIN-SERVICE-CORE-L1-1-4.DLL
API-MS-WIN-SHCORE-COMHELPERS-L1-1-0.DLL
API-MS-WIN-SHCORE-OBSOLETE-L1-1-0.DLL
API-MS-WIN-SHCORE-PATH-L1-1-0.DLL
API-MS-WIN-SHCORE-REGISTRY-L1-1-0.DLL
API-MS-WIN-SHCORE-REGISTRY-L1-1-1.DLL
API-MS-WIN-SHCORE-SCALING-L1-1-0.DLL
API-MS-WIN-SHCORE-SCALING-L1-1-1.DLL
API-MS-WIN-SHCORE-STREAM-L1-1-0.DLL
API-MS-WIN-SHCORE-STREAM-WINRT-L1-1-0.DLL
API-MS-WIN-SHCORE-SYSINFO-L1-1-0.DLL
API-MS-WIN-SHCORE-TASKPOOL-L1-1-0.DLL
API-MS-WIN-SHCORE-THREAD-L1-1-0.DLL
API-MS-WIN-SHCORE-UNICODEANSI-L1-1-0.DLL
API-MS-WIN-SHELL-ASSOCIATIONS-L1-1-1.DLL
API-MS-WIN-SHELL-CHANGENOTIFY-L1-1-0.DLL
API-MS-WIN-SHELL-NAMESPACE-L1-1-0.DLL
API-MS-WIN-SHELL-SHDIRECTORY-L1-1-0.DLL
API-MS-WIN-SHELL-SHELLCOM-L1-1-0.DLL
API-MS-WIN-SHELL-SHELLFOLDERS-L1-1-0.DLL
API-MS-WIN-SHLWAPI-IE-L1-1-0.DLL
API-MS-WIN-SHLWAPI-WINRT-STORAGE-L1-1-1.DLL
API-MS-WIN-STATESEPARATION-HELPERS-L1-1-0.DLL
API-MS-WIN-STORAGE-EXPORTS-EXTERNAL-L1-1-0.DLL
API-MS-WIN-STORAGE-EXPORTS-INTERNAL-L1-1-0.DLL
EXT-MS-MF-PAL-L2-1-0.DLL
EXT-MS-ONECORE-APPDEFAULTS-L1-1-0.DLL
EXT-MS-ONECORE-APPMODEL-STATEREPOSITORY-CACHE-L1-1-0.DLL
EXT-MS-ONECORE-APPMODEL-STATEREPOSITORY-CACHE-L1-1-2.DLL
EXT-MS-ONECORE-APPMODEL-STATEREPOSITORY-INTERNAL-L1-1-1.DLL
EXT-MS-ONECORE-APPMODEL-STATEREPOSITORY-INTERNAL-L1-1-3.DLL
EXT-MS-ONECORE-APPMODEL-STATEREPOSITORY-INTERNAL-L1-1-4.DLL
EXT-MS-ONECORE-DCOMP-L1-1-0.DLL
EXT-MS-ONECORE-HLINK-L1-1-0.DLL
EXT-MS-ONECORE-ORIENTATION-L1-1-0.DLL
EXT-MS-ONECORE-SERVICE-DEVICEDIRECTORY-CLAIMS-L1-1-0.DLL
EXT-MS-ONECORE-SHELLCHROMEAPI-L1-1-0.DLL
EXT-MS-WIN-ADSI-ACTIVEDS-L1-1-0.DLL
EXT-MS-WIN-ADVAPI32-ENCRYPTEDFILE-L1-1-0.DLL
EXT-MS-WIN-ADVAPI32-LSA-L1-1-0.DLL
EXT-MS-WIN-ADVAPI32-MSI-L1-1-0.DLL
EXT-MS-WIN-ADVAPI32-NPUSERNAME-L1-1-0.DLL
EXT-MS-WIN-ADVAPI32-NTMARTA-L1-1-0.DLL
EXT-MS-WIN-ADVAPI32-PSM-APP-L1-1-0.DLL
EXT-MS-WIN-ADVAPI32-REGISTRY-L1-1-0.DLL
EXT-MS-WIN-ADVAPI32-REGISTRY-L1-1-1.DLL
EXT-MS-WIN-ADVAPI32-SAFER-L1-1-0.DLL
EXT-MS-WIN-APPCOMPAT-AEINV-L1-1-0.DLL
EXT-MS-WIN-APPCOMPAT-AEPIC-L1-1-0.DLL
EXT-MS-WIN-APPCOMPAT-APPHELP-L1-1-0.DLL
EXT-MS-WIN-APPMODEL-APPEXECUTIONALIAS-L1-1-0.DLL
EXT-MS-WIN-APPMODEL-APPEXECUTIONALIAS-L1-1-1.DLL
EXT-MS-WIN-APPMODEL-APPEXECUTIONALIAS-L1-1-2.DLL
EXT-MS-WIN-APPMODEL-DAXCORE-L1-1-0.DLL
EXT-MS-WIN-APPMODEL-DEPLOYMENT-L1-1-0.DLL
EXT-MS-WIN-APPMODEL-RESTRICTEDAPPCONTAINER-INTERNAL-L1-1-0.DLL
EXT-MS-WIN-APPMODEL-STATE-EXT-L1-2-0.DLL
EXT-MS-WIN-APPMODEL-USERCONTEXT-L1-1-0.DLL
EXT-MS-WIN-APPMODEL-VIEWSCALEFACTOR-L1-1-0.DLL
EXT-MS-WIN-APPXDEPLOYMENTCLIENT-APPXDEPLOY-L1-1-0.DLL
EXT-MS-WIN-APPXDEPLOYMENTCLIENT-APPXDEPLOYONECORE-L1-1-0.DLL
EXT-MS-WIN-AUDIOCORE-PAL-L1-2-0.DLL
EXT-MS-WIN-AUDIOCORE-SPATIAL-L1-1-0.DLL
EXT-MS-WIN-AUTHZ-CONTEXT-L1-1-0.DLL
EXT-MS-WIN-AUTHZ-REMOTE-L1-1-0.DLL
EXT-MS-WIN-BIOMETRICS-WINBIO-CORE-L1-1-0.DLL
EXT-MS-WIN-COM-APARTMENTRESTRICTION-L1-1-0.DLL
EXT-MS-WIN-COM-CLBCATQ-L1-1-0.DLL
EXT-MS-WIN-COM-COML2-L1-1-1.DLL
EXT-MS-WIN-COM-OLE32-L1-1-0.DLL
EXT-MS-WIN-COM-OLE32-L1-1-1.DLL
EXT-MS-WIN-COM-OLE32-L1-1-2.DLL
EXT-MS-WIN-COM-OLE32-L1-1-3.DLL
EXT-MS-WIN-COM-OLE32-L1-1-4.DLL
EXT-MS-WIN-COM-OLE32-L1-1-5.DLL
EXT-MS-WIN-COM-PSMREGISTER-L1-1-0.DLL
EXT-MS-WIN-COM-SUSPENDRESILIENCY-L1-1-0.DLL
EXT-MS-WIN-CONTAINERS-POLICYMANAGERCLI-L1-1-0.DLL
EXT-MS-WIN-CORE-PKEYHELPER-L1-1-0.DLL
EXT-MS-WIN-CORE-RESOURCEPOLICY-L1-1-0.DLL
EXT-MS-WIN-CORE-WINRT-REMOTE-L1-1-0.DLL
EXT-MS-WIN-DESKTOPAPPX-L1-1-0.DLL
EXT-MS-WIN-DESKTOPAPPX-L1-1-3.DLL
EXT-MS-WIN-DEVMGMT-DM-L1-1-0.DLL
EXT-MS-WIN-DEVMGMT-DM-L1-1-1.DLL
EXT-MS-WIN-DEVMGMT-DM-L1-1-2.DLL
EXT-MS-WIN-DEVMGMT-POLICY-L1-1-0.DLL
EXT-MS-WIN-DEVMGMT-POLICY-L1-1-1.DLL
EXT-MS-WIN-DIRECT2D-DESKTOP-L1-1-0.DLL
EXT-MS-WIN-DOMAINJOIN-NETJOIN-L1-1-0.DLL
EXT-MS-WIN-DRIVER-SETUP-L1-1-0.DLL
EXT-MS-WIN-DWMAPI-EXT-L1-1-0.DLL
EXT-MS-WIN-DWMAPIDXGI-EXT-L1-1-0.DLL
EXT-MS-WIN-DWMAPIDXGI-EXT-L1-1-1.DLL
EXT-MS-WIN-DX-D3DKMT-DXCORE-L1-1-0.DLL
EXT-MS-WIN-DX-D3DKMT-GDI-L1-1-0.DLL
EXT-MS-WIN-DXCORE-INTERNAL-L1-1-0.DLL
EXT-MS-WIN-DXCORE-L1-1-0.DLL
EXT-MS-WIN-EDPUTIL-POLICY-L1-1-0.DLL
EXT-MS-WIN-EDPUTIL-POLICY-L1-1-1.DLL
EXT-MS-WIN-ELS-ELSCORE-L1-1-0.DLL
EXT-MS-WIN-EVENTING-RUNDOWN-L1-1-0.DLL
EXT-MS-WIN-FAMILYSAFETY-CHILDACCOUNT-L1-1-0.DLL
EXT-MS-WIN-FECLIENT-ENCRYPTEDFILE-L1-1-0.DLL
EXT-MS-WIN-FECLIENT-ENCRYPTEDFILE-L1-1-1.DLL
EXT-MS-WIN-FECLIENT-ENCRYPTEDFILE-L1-1-2.DLL
EXT-MS-WIN-FECLIENT-ENCRYPTEDFILE-L1-1-3.DLL
EXT-MS-WIN-FIREWALLAPI-WEBPROXY-L1-1-0.DLL
EXT-MS-WIN-FVEAPI-QUERY-L1-1-0.DLL
EXT-MS-WIN-GDI-CLIPPING-L1-1-0.DLL
EXT-MS-WIN-GDI-DC-CREATE-L1-1-0.DLL
EXT-MS-WIN-GDI-DC-L1-2-0.DLL
EXT-MS-WIN-GDI-DC-L1-2-1.DLL
EXT-MS-WIN-GDI-DEVCAPS-L1-1-0.DLL
EXT-MS-WIN-GDI-DRAW-L1-1-0.DLL
EXT-MS-WIN-GDI-DRAW-L1-1-1.DLL
EXT-MS-WIN-GDI-DRAW-L1-1-2.DLL
EXT-MS-WIN-GDI-DRAW-L1-1-3.DLL
EXT-MS-WIN-GDI-FONT-L1-1-0.DLL
EXT-MS-WIN-GDI-FONT-L1-1-1.DLL
EXT-MS-WIN-GDI-FONT-L1-1-2.DLL
EXT-MS-WIN-GDI-FONT-L1-1-3.DLL
EXT-MS-WIN-GDI-GDIPLUS-L1-1-0.DLL
EXT-MS-WIN-GDI-INTERNAL-DESKTOP-L1-1-0.DLL
EXT-MS-WIN-GDI-INTERNAL-DESKTOP-L1-1-1.DLL
EXT-MS-WIN-GDI-INTERNAL-DESKTOP-L1-1-2.DLL
EXT-MS-WIN-GDI-INTERNAL-DESKTOP-L1-1-3.DLL
EXT-MS-WIN-GDI-METAFILE-L1-1-0.DLL
EXT-MS-WIN-GDI-METAFILE-L1-1-1.DLL
EXT-MS-WIN-GDI-METAFILE-L1-1-2.DLL
EXT-MS-WIN-GDI-PATH-L1-1-0.DLL
EXT-MS-WIN-GDI-PRINT-L1-1-0.DLL
EXT-MS-WIN-GDI-PRIVATE-L1-1-0.DLL
EXT-MS-WIN-GDI-RENDER-L1-1-0.DLL
EXT-MS-WIN-GDI-WCS-L1-1-0.DLL
EXT-MS-WIN-GPAPI-GROUPPOLICY-L1-1-0.DLL
EXT-MS-WIN-GUI-DUI70-L1-1-0.DLL
EXT-MS-WIN-IMM-L1-1-0.DLL
EXT-MS-WIN-KERNEL32-APPCOMPAT-L1-1-0.DLL
EXT-MS-WIN-KERNEL32-DATETIME-L1-1-0.DLL
EXT-MS-WIN-KERNEL32-ERRORHANDLING-L1-1-0.DLL
EXT-MS-WIN-KERNEL32-FILE-L1-1-0.DLL
EXT-MS-WIN-KERNEL32-LOCALIZATION-L1-1-0.DLL
EXT-MS-WIN-KERNEL32-PACKAGE-CURRENT-L1-1-0.DLL
EXT-MS-WIN-KERNEL32-PACKAGE-L1-1-0.DLL
EXT-MS-WIN-KERNEL32-PACKAGE-L1-1-2.DLL
EXT-MS-WIN-KERNEL32-QUIRKS-L1-1-0.DLL
EXT-MS-WIN-KERNEL32-QUIRKS-L1-1-1.DLL
EXT-MS-WIN-KERNEL32-REGISTRY-L1-1-0.DLL
EXT-MS-WIN-KERNEL32-SIDEBYSIDE-L1-1-0.DLL
EXT-MS-WIN-KERNELBASE-PROCESSTHREAD-L1-1-0.DLL
EXT-MS-WIN-KERNELBASE-PROCESSTHREAD-L1-1-1.DLL
EXT-MS-WIN-MININPUT-INPUTHOST-L1-1-0.DLL
EXT-MS-WIN-MPR-MULTIPLEPROVIDERROUTER-L1-1-0.DLL
EXT-MS-WIN-MRMCORER-RESMANAGER-L1-1-0.DLL
EXT-MS-WIN-NETWORKING-WCMAPI-L1-1-0.DLL
EXT-MS-WIN-NETWORKING-WLANAPI-L1-1-0.DLL
EXT-MS-WIN-NETWORKING-WLANSTORAGE-L1-1-0.DLL
EXT-MS-WIN-NTDSAPI-ACTIVEDIRECTORYCLIENT-L1-1-0.DLL
EXT-MS-WIN-NTDSAPI-ACTIVEDIRECTORYCLIENT-L1-1-1.DLL
EXT-MS-WIN-NTUSER-DC-ACCESS-EXT-L1-1-0.DLL
EXT-MS-WIN-NTUSER-DIALOGBOX-L1-1-0.DLL
EXT-MS-WIN-NTUSER-DRAW-L1-1-0.DLL
EXT-MS-WIN-NTUSER-DRAW-L1-1-1.DLL
EXT-MS-WIN-NTUSER-DRAW-L1-1-2.DLL
EXT-MS-WIN-NTUSER-GUI-L1-1-0.DLL
EXT-MS-WIN-NTUSER-KEYBOARD-L1-1-0.DLL
EXT-MS-WIN-NTUSER-MENU-L1-1-2.DLL
EXT-MS-WIN-NTUSER-MESSAGE-L1-1-0.DLL
EXT-MS-WIN-NTUSER-MESSAGE-L1-1-1.DLL
EXT-MS-WIN-NTUSER-MESSAGE-L1-1-2.DLL
EXT-MS-WIN-NTUSER-MISC-L1-1-0.DLL
EXT-MS-WIN-NTUSER-MISC-L1-2-0.DLL
EXT-MS-WIN-NTUSER-MISC-L1-5-0.DLL
EXT-MS-WIN-NTUSER-MISC-L1-5-1.DLL
EXT-MS-WIN-NTUSER-MOUSE-L1-1-0.DLL
EXT-MS-WIN-NTUSER-PRIVATE-L1-1-0.DLL
EXT-MS-WIN-NTUSER-PRIVATE-L1-1-1.DLL
EXT-MS-WIN-NTUSER-PRIVATE-L1-2-0.DLL
EXT-MS-WIN-NTUSER-PRIVATE-L1-3-1.DLL
EXT-MS-WIN-NTUSER-PRIVATE-L1-3-2.DLL
EXT-MS-WIN-NTUSER-PRIVATE-L1-3-3.DLL
EXT-MS-WIN-NTUSER-RECTANGLE-EXT-L1-1-0.DLL
EXT-MS-WIN-NTUSER-ROTATIONMANAGER-L1-1-0.DLL
EXT-MS-WIN-NTUSER-SERVER-L1-1-0.DLL
EXT-MS-WIN-NTUSER-STRING-L1-1-0.DLL
EXT-MS-WIN-NTUSER-SYNCH-L1-1-0.DLL
EXT-MS-WIN-NTUSER-UICONTEXT-EXT-L1-1-0.DLL
EXT-MS-WIN-NTUSER-WINDOW-L1-1-0.DLL
EXT-MS-WIN-NTUSER-WINDOW-L1-1-1.DLL
EXT-MS-WIN-NTUSER-WINDOW-L1-1-2.DLL
EXT-MS-WIN-NTUSER-WINDOW-L1-1-3.DLL
EXT-MS-WIN-NTUSER-WINDOWCLASS-L1-1-0.DLL
EXT-MS-WIN-NTUSER-WINDOWSTATION-L1-1-0.DLL
EXT-MS-WIN-ODBC-ODBC32-L1-1-0.DLL
EXT-MS-WIN-OLE32-BINDCTX-L1-1-0.DLL
EXT-MS-WIN-OLE32-IE-EXT-L1-1-0.DLL
EXT-MS-WIN-OLE32-OLEAUTOMATION-L1-1-0.DLL
EXT-MS-WIN-OLEACC-L1-1-1.DLL
EXT-MS-WIN-OOBE-QUERY-L1-1-0.DLL
EXT-MS-WIN-PRINTER-PRNTVPT-L1-1-0.DLL
EXT-MS-WIN-PROFILE-EXTENDER-L1-1-0.DLL
EXT-MS-WIN-PROFILE-USERENV-L1-1-0.DLL
EXT-MS-WIN-PROFILE-USERENV-L1-1-1.DLL
EXT-MS-WIN-RAS-RASAPI32-L1-1-0.DLL
EXT-MS-WIN-RAS-TAPI32-L1-1-1.DLL
EXT-MS-WIN-RDR-DAVHLPR-L1-1-0.DLL
EXT-MS-WIN-REINFO-QUERY-L1-1-0.DLL
EXT-MS-WIN-RESOURCEMANAGER-CRM-L1-2-0.DLL
EXT-MS-WIN-RESOURCES-DEPLOYMENT-L1-1-0.DLL
EXT-MS-WIN-RESOURCES-LANGUAGEOVERLAY-L1-1-0.DLL
EXT-MS-WIN-RESOURCES-LANGUAGEOVERLAY-L1-1-1.DLL
EXT-MS-WIN-RO-TYPERESOLUTION-L1-1-0.DLL
EXT-MS-WIN-RPC-SSL-L1-1-0.DLL
EXT-MS-WIN-RTCORE-GDI-DEVCAPS-L1-1-0.DLL
EXT-MS-WIN-RTCORE-GDI-OBJECT-L1-1-0.DLL
EXT-MS-WIN-RTCORE-GDI-RGN-L1-1-0.DLL
EXT-MS-WIN-RTCORE-GDI-RGN-L1-1-1.DLL
EXT-MS-WIN-RTCORE-MINUSER-INPUT-L1-1-1.DLL
EXT-MS-WIN-RTCORE-MINUSER-INTERNAL-L1-1-0.DLL
EXT-MS-WIN-RTCORE-MINUSER-PRIVATE-EXT-L1-1-0.DLL
EXT-MS-WIN-RTCORE-MINUSER-PRIVATE-EXT-L1-1-1.DLL
EXT-MS-WIN-RTCORE-NTUSER-CURSOR-L1-1-0.DLL
EXT-MS-WIN-RTCORE-NTUSER-DC-ACCESS-L1-1-0.DLL
EXT-MS-WIN-RTCORE-NTUSER-DPI-L1-1-0.DLL
EXT-MS-WIN-RTCORE-NTUSER-DPI-L1-2-0.DLL
EXT-MS-WIN-RTCORE-NTUSER-DPI-L1-2-1.DLL
EXT-MS-WIN-RTCORE-NTUSER-IAM-L1-1-0.DLL
EXT-MS-WIN-RTCORE-NTUSER-INTEGRATION-L1-1-0.DLL
EXT-MS-WIN-RTCORE-NTUSER-RAWINPUT-L1-1-0.DLL
EXT-MS-WIN-RTCORE-NTUSER-SYNCH-EXT-L1-1-0.DLL
EXT-MS-WIN-RTCORE-NTUSER-SYSCOLORS-L1-1-0.DLL
EXT-MS-WIN-RTCORE-NTUSER-SYSPARAMS-L1-1-0.DLL
EXT-MS-WIN-RTCORE-NTUSER-WINDOW-EXT-L1-1-0.DLL
EXT-MS-WIN-RTCORE-NTUSER-WINDOW-EXT-L1-1-1.DLL
EXT-MS-WIN-SECUR32-TRANSLATENAME-L1-1-0.DLL
EXT-MS-WIN-SECURITY-AUTHZ-HELPER-L1-1-0.DLL
EXT-MS-WIN-SECURITY-CAPAUTHZ-L1-1-0.DLL
EXT-MS-WIN-SECURITY-CAPAUTHZ-L1-1-1.DLL
EXT-MS-WIN-SECURITY-CHAMBERS-L1-1-0.DLL
EXT-MS-WIN-SECURITY-CREDUI-INTERNAL-L1-1-0.DLL
EXT-MS-WIN-SECURITY-CREDUI-L1-1-0.DLL
EXT-MS-WIN-SECURITY-CREDUI-L1-1-1.DLL
EXT-MS-WIN-SECURITY-CRYPTUI-L1-1-0.DLL
EXT-MS-WIN-SECURITY-CRYPTUI-L1-1-1.DLL
EXT-MS-WIN-SECURITY-EFS-L1-1-0.DLL
EXT-MS-WIN-SECURITY-EFSWRT-L1-1-0.DLL
EXT-MS-WIN-SECURITY-EFSWRT-L1-1-1.DLL
EXT-MS-WIN-SECURITY-NGC-LOCAL-L1-1-0.DLL
EXT-MS-WIN-SECURITY-SLC-L1-1-0.DLL
EXT-MS-WIN-SECURITY-WINSCARD-L1-1-0.DLL
EXT-MS-WIN-SECURITY-WINSCARD-L1-1-1.DLL
EXT-MS-WIN-SESSION-USERMGR-L1-1-0.DLL
EXT-MS-WIN-SESSION-USERTOKEN-L1-1-0.DLL
EXT-MS-WIN-SESSION-WINSTA-L1-1-0.DLL
EXT-MS-WIN-SESSION-WTSAPI32-L1-1-0.DLL
EXT-MS-WIN-SETUPAPI-INF-L1-1-0.DLL
EXT-MS-WIN-SETUPAPI-INF-L1-1-1.DLL
EXT-MS-WIN-SHELL-DIRECTORY-L1-1-0.DLL
EXT-MS-WIN-SHELL-EMBEDDEDMODE-L1-1-0.DLL
EXT-MS-WIN-SHELL-FILEPLACEHOLDER-L1-1-0.DLL
EXT-MS-WIN-SHELL-SHELL32-L1-2-0.DLL
EXT-MS-WIN-SHELL-SHLWAPI-L1-1-0.DLL
EXT-MS-WIN-SHELL32-SHELLCOM-L1-1-0.DLL
EXT-MS-WIN-SHELL32-SHELLFOLDERS-L1-1-0.DLL
EXT-MS-WIN-SMBSHARE-BROWSERCLIENT-L1-1-0.DLL
EXT-MS-WIN-STORAGE-SENSE-L1-1-0.DLL
EXT-MS-WIN-STORAGE-SENSE-L1-2-0.DLL
EXT-MS-WIN-SXS-OLEAUTOMATION-L1-1-0.DLL
EXT-MS-WIN-TSF-MSCTF-L1-1-0.DLL
EXT-MS-WIN-TSF-MSCTF-L1-1-1.DLL
EXT-MS-WIN-UI-VIEWMANAGEMENT-L1-1-0.DLL
EXT-MS-WIN-USP10-L1-1-0.DLL
EXT-MS-WIN-WER-UI-L1-1-0.DLL
EXT-MS-WIN-WER-XBOX-L1-1-0.DLL
EXT-MS-WIN-WEVTAPI-EVENTLOG-L1-1-0.DLL
EXT-MS-WIN-WINRT-DEVICE-ACCESS-L1-1-0.DLL
EXT-MS-WIN-WINRT-STORAGE-L1-1-0.DLL
EXT-MS-WIN-WLAN-ONEXUI-L1-1-0.DLL
EXT-MS-WIN-WLAN-SCARD-L1-1-0.DLL
EXT-MS-WIN-WPC-WEBFILTER-L1-1-0.DLL
EXT-MS-WIN-WWAN-WWAPI-L1-1-0.DLL
EXT-MS-WIN-WWAN-WWAPI-L1-1-1.DLL
EXT-MS-WIN32-SUBSYSTEM-QUERY-L1-1-0.DLL
EXT-MS-WINDOWSCORE-DEVICEINFO-L1-1-0.DLL
HVSIFILETRUST.DLL
IESHIMS.DLL
API-MS-WIN-CORE-FILE-L1-1-0.DLL
API-MS-WIN-CORE-LIBRARYLOADER-L1-1-0.DLL
API-MS-WIN-CORE-PROCESSTHREADS-L1-1-0.DLL
API-MS-WIN-CORE-PROCESSTHREADS-L1-1-1.DLL
API-MS-WIN-CORE-SYNCH-L1-1-0.DLL
API-MS-WIN-CORE-SYNCH-L1-2-0.DLL
API-MS-WIN-CORE-SYSINFO-L1-1-0.DLL
API-MS-WIN-CORE-TIMEZONE-L1-1-0.DLL
KERNEL32.DLL
API-MS-WIN-CRT-PRIVATE-L1-1-0.DLL
IEFRAME.DLL
SHCORE.DLL
SHLWAPI.DLL
_PARTDESIGN_D.PYD
ADVAPI32.DLL
API-MS-WIN-CORE-CONSOLE-L1-1-0.DLL
API-MS-WIN-CORE-CONSOLE-L1-2-0.DLL
API-MS-WIN-CORE-DATETIME-L1-1-0.DLL
API-MS-WIN-CORE-DEBUG-L1-1-0.DLL
API-MS-WIN-CORE-ERRORHANDLING-L1-1-0.DLL
API-MS-WIN-CORE-FILE-L1-2-0.DLL
API-MS-WIN-CORE-FILE-L2-1-0.DLL
API-MS-WIN-CORE-HANDLE-L1-1-0.DLL
API-MS-WIN-CORE-HEAP-L1-1-0.DLL
API-MS-WIN-CORE-INTERLOCKED-L1-1-0.DLL
API-MS-WIN-CORE-LOCALIZATION-L1-2-0.DLL
API-MS-WIN-CORE-MEMORY-L1-1-0.DLL
API-MS-WIN-CORE-NAMEDPIPE-L1-1-0.DLL
API-MS-WIN-CORE-PROCESSENVIRONMENT-L1-1-0.DLL
API-MS-WIN-CORE-PROFILE-L1-1-0.DLL
API-MS-WIN-CORE-RTLSUPPORT-L1-1-0.DLL
API-MS-WIN-CORE-STRING-L1-1-0.DLL
API-MS-WIN-CORE-UTIL-L1-1-0.DLL
KERNELBASE.DLL
MSVCP140D.DLL
MSVCRT.DLL
NTDLL.DLL
RPCRT4.DLL
SECHOST.DLL
UCRTBASED.DLL
VCRUNTIME140_1D.DLL
VCRUNTIME140D.DLL
ACLUI.DLL
ACTIVEDS.DLL
ADSLDPC.DLL
ADVPACK.DLL
AEPIC.DLL
API-MS-WIN-CRT-CONVERT-L1-1-0.DLL
API-MS-WIN-CRT-ENVIRONMENT-L1-1-0.DLL
API-MS-WIN-CRT-FILESYSTEM-L1-1-0.DLL
API-MS-WIN-CRT-HEAP-L1-1-0.DLL
API-MS-WIN-CRT-LOCALE-L1-1-0.DLL
API-MS-WIN-CRT-MATH-L1-1-0.DLL
API-MS-WIN-CRT-PROCESS-L1-1-0.DLL
API-MS-WIN-CRT-RUNTIME-L1-1-0.DLL
API-MS-WIN-CRT-STDIO-L1-1-0.DLL
API-MS-WIN-CRT-STRING-L1-1-0.DLL
API-MS-WIN-CRT-TIME-L1-1-0.DLL
API-MS-WIN-CRT-UTILITY-L1-1-0.DLL
APPHELP.DLL
AUDIOSES.DLL
AUTHZ.DLL
AVRT.DLL
BCD.DLL
BCP47LANGS.DLL
BCP47MRM.DLL
BCRYPT.DLL
BCRYPTPRIMITIVES.DLL
BROWCLI.DLL
CABINET.DLL
CERTCA.DLL
CERTENROLL.DLL
CFGMGR32.DLL
CHAKRA.DLL
CHARTV.DLL
CLDAPI.DLL
COMBASE.DLL
COMCTL32.DLL
COMCTL32.DLL
COMDLG32.DLL
COML2.DLL
COMPPKGSUP.DLL
CONTACTACTIVATION.DLL
COREMESSAGING.DLL
COREUICOMPONENTS.DLL
CREDUI.DLL
CRYPT32.DLL
CRYPTBASE.DLL
CRYPTNET.DLL
CRYPTNGC.DLL
CRYPTSP.DLL
CRYPTTPMEKSVC.DLL
CRYPTUI.DLL
CRYPTXML.DLL
CSCAPI.DLL
D2D1.DLL
D3D11.DLL
D3D11ON12.DLL
D3D12.DLL
D3DSCACHE.DLL
DAVHLPR.DLL
DBGCORE.DLL
DBGENG.DLL
DBGHELP.DLL
DBGMODEL.DLL
DCOMP.DLL
DEVMGR.DLL
DEVOBJ.DLL
DEVRTL.DLL
DFSCLI.DLL
DHCPCSVC.DLL
DHCPCSVC6.DLL
DMCMNUTILS.DLL
DMENTERPRISEDIAGNOSTICS.DLL
DMPUSHPROXY.DLL
DNSAPI.DLL
DPAPI.DLL
DRVSETUP.DLL
DRVSTORE.DLL
DSCLIENT.DLL
DSPARSE.DLL
DSREG.DLL
DSROLE.DLL
DUI70.DLL
DUSER.DLL
DWMAPI.DLL
DWRITE.DLL
DXGI.DLL
DXILCONV.DLL
EAPPCFG.DLL
EAPPPRXY.DLL
EDGEISO.DLL
EDPAUDITAPI.DLL
EDPUTIL.DLL
EFSADU.DLL
EFSCORE.DLL
EFSUTIL.DLL
EFSWRT.DLL
ELSCORE.DLL
ESENT.DLL
FECLIENT.DLL
FIREWALLAPI.DLL
FLTLIB.DLL
FMS.DLL
FVEAPI.DLL
FVECERTS.DLL
FVESKYBACKUP.DLL
FWBASE.DLL
FWPOLICYIOMGR.DLL
GDI32.DLL
GDIPLUS.DLL
HID.DLL
HTTPAPI.DLL
ICU.DLL
ICUIN.DLL
ICUUC.DLL
IEADVPACK.DLL
IEAPFLTR.DLL
IERTUTIL.DLL
IEUI.DLL
IMAGEHLP.DLL
IMGUTIL.DLL
IMM32.DLL
INETCOMM.DLL
IPHLPAPI.DLL
IRI.DLL
LINKINFO.DLL
LOGONCLI.DLL
MDMREGISTRATION.DLL
MFC42U.DLL
MI.DLL
MIUTILS.DLL
MLANG.DLL
MMDEVAPI.DLL
MPR.DLL
MPRMSG.DLL
MRMCORER.DLL
MSASN1.DLL
MSCTF.DLL
MSFEEDS.DLL
MSHTML.DLL
MSI.DLL
MSILTCFG.DLL
MSIMG32.DLL
MSISO.DLL
MSLS31.DLL
MSOERT2.DLL
MSVCP110_WIN.DLL
MSVCP_WIN.DLL
NCRYPT.DLL
NETAPI32.DLL
NETUTILS.DLL
NEWDEV.DLL
NGCRECOVERY.DLL
NSI.DLL
NTASN1.DLL
NTDSAPI.DLL
NTSHRUI.DLL
OCCACHE.DLL
OLE32.DLL
OLEACC.DLL
OLEAUT32.DLL
OLEDLG.DLL
OMADMAPI.DLL
ONEX.DLL
POLICYMANAGER.DLL
POWRPROF.DLL
PRINTUI.DLL
PROFAPI.DLL
PROPSYS.DLL
PUIAPI.DLL
RASAPI32.DLL
RASMAN.DLL
REGAPI.DLL
RMCLIENT.DLL
RTUTILS.DLL
SAMCLI.DLL
SAMLIB.DLL
SCECLI.DLL
SECUR32.DLL
SETUPAPI.DLL
SHDOCVW.DLL
SHELL32.DLL
SLC.DLL
SPFILEQ.DLL
SPINF.DLL
SPPC.DLL
SRPAPI.DLL
SRVCLI.DLL
SSPICLI.DLL
TBS.DLL
TEXTINPUTFRAMEWORK.DLL
TEXTSHAPING.DLL
TOKENBINDING.DLL
TPMCOREPROVISIONING.DLL
TWINAPI.APPCORE.DLL
TWINAPI.DLL
UCRTBASE.DLL
UIAUTOMATIONCORE.DLL
UMPDC.DLL
URLMON.DLL
USER32.DLL
USERDATATYPEHELPERUTIL.DLL
USERENV.DLL
UXTHEME.DLL
VAULTCLI.DLL
VERSION.DLL
VIRTDISK.DLL
W32TOPL.DLL
WEBAUTHN.DLL
WEBIO.DLL
WEBSERVICES.DLL
WEBSOCKET.DLL
WER.DLL
WEVTAPI.DLL
WFDSCONMGR.DLL
WIN32U.DLL
WINBRAND.DLL
WINDOWSCODECS.DLL
WINDOWSPERFORMANCERECORDERCONTROL.DLL
WINHTTP.DLL
WININET.DLL
WINIPCFILE.DLL
WINMM.DLL
WINMMBASE.DLL
WINMSIPC.DLL
WINNSI.DLL
WINSPOOL.DRV
WINSTA.DLL
WINTRUST.DLL
WKSCLI.DLL
WLANAPI.DLL
WLDAP32.DLL
WLDP.DLL
WMICLNT.DLL
WPAXHOLDER.DLL
WS2_32.DLL
WTSAPI32.DLL
WUCEFFECTS.DLL
XMLLITE.DLL
Thanks in advance,
Frank Alviani
