error: invalid use of incomplete type 'PyFrameObject' {aka 'struct _frame'}
hobbes1069
Post by hobbes1069 »
Fedora Linux - Rawhide
FreeCAD 0.20
gcc 12.1.1
Python 3.11
[ 40%] Building CXX object src/Base/CMakeFiles/FreeCADBase.dir/ConsoleObserver.cpp.o
cd /builddir/build/BUILD/FreeCAD-0.20/redhat-linux-build/src/Base && /usr/bin/g++ -DBOOST_ATOMIC_DYN_LINK -DBOOST_ATOMIC_NO_LIB -DBOOST_DATE_TIME_DYN_LINK -DBOOST_DATE_TIME_NO_LIB -DBOOST_FILESYSTEM_DYN_LINK -DBOOST_FILESYSTEM_NO_LIB -DBOOST_PROGRAM_OPTIONS_DYN_LINK -DBOOST_PROGRAM_OPTIONS_NO_LIB -DBOOST_REGEX_DYN_LINK -DBOOST_REGEX_NO_LIB -DBOOST_SYSTEM_DYN_LINK -DBOOST_SYSTEM_NO_LIB -DBOOST_THREAD_DYN_LINK -DBOOST_THREAD_NO_LIB -DFreeCADBase_EXPORTS -DHAVE_CONFIG_H -DHAVE_SWIG=1 -DPYCXX_6_2_COMPATIBILITY -DPYCXX_PYTHON_2TO3 -DQT_CORE_LIB -DQT_NO_DEBUG -D_OCC64 -I/builddir/build/BUILD/FreeCAD-0.20/redhat-linux-build/src/Base/FreeCADBase_autogen/include -I/builddir/build/BUILD/FreeCAD-0.20/redhat-linux-build -I/builddir/build/BUILD/FreeCAD-0.20/redhat-linux-build/src -I/builddir/build/BUILD/FreeCAD-0.20/src -I/builddir/build/BUILD/FreeCAD-0.20/redhat-linux-build/src/Base -I/builddir/build/BUILD/FreeCAD-0.20/src/Base -I/usr/include/python3.11 -isystem /usr/include/qt5 -isystem /usr/include/qt5/QtCore -isystem /usr/lib64/qt5/mkspecs/linux-g++ -Wall -Wextra -Wno-write-strings -O2 -flto=auto -ffat-lto-objects -fexceptions -g -grecord-gcc-switches -pipe -Wall -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -Wp,-D_GLIBCXX_ASSERTIONS -specs=/usr/lib/rpm/redhat/redhat-hardened-cc1 -fstack-protector-strong -specs=/usr/lib/rpm/redhat/redhat-annobin-cc1  -m64  -mtune=generic -fasynchronous-unwind-tables -fstack-clash-protection -fcf-protection -fPIC -fPIC -std=gnu++17 -MD -MT src/Base/CMakeFiles/FreeCADBase.dir/ConsoleObserver.cpp.o -MF CMakeFiles/FreeCADBase.dir/ConsoleObserver.cpp.o.d -o CMakeFiles/FreeCADBase.dir/ConsoleObserver.cpp.o -c /builddir/build/BUILD/FreeCAD-0.20/src/Base/ConsoleObserver.cpp
/builddir/build/BUILD/FreeCAD-0.20/src/Base/ConsoleObserver.cpp: In member function 'std::stringstream& Base::LogLevel::prefix(std::stringstream&, const char*, int)':
/builddir/build/BUILD/FreeCAD-0.20/src/Base/ConsoleObserver.cpp:269:41: error: invalid use of incomplete type 'PyFrameObject' {aka 'struct _frame'}
  269 |             src = PyUnicode_AsUTF8(frame->f_code->co_filename);
Perhaps something has changed in Python 3.11?
Full build logs can be provided if helpful.
Thanks,
Richard
Founder
Re: error: invalid use of incomplete type 'PyFrameObject' {aka 'struct _frame'}
Post by wmayer »
git commit 1ae55905ba
Make FreeCAD to compile with Py3.11. But it immediately crashes at start...
Why does Fedora use a beta version of Python? The latest stable is still 3.10
hobbes1069
If no one is first, then the problems don't get fixed :)
But more seriously, testing in Fedora Rawhide (rolling development) problems are found before the full release instead of after. We find most of the GCC bugs too.
Founder
Post by wmayer »
git commit 6820e0a9ec fixes the crash. The function Py_SET_TYPE() doesn't handle types that are inherited (in C++) from PyObject and thus produces a dangling pointer. So, the trick is to directly set the ob_type member.
hobbes1069
Thanks! Test building now.
Post by Kunda1 »
@hobbes1069, any news ?
hobbes1069
I need to try running it, but all builds for Fedora 35, 36, and Rawhide have built and been submitted to the testing repositories.
hobbes1069
Loading one of the preinstalled examples works but there's a lot of output related to coin...
07:25:13  Traceback (most recent call last):
  File "/usr/lib64/freecad/Mod/Draft/draftviewproviders/view_dimension.py", line 368, in attach
    self.text.string = "d"
  File "/usr/lib64/python3.10/site-packages/pivy/coin.py", line 3998, in __setattr__
    field = self.getField(name)
  File "/usr/lib64/python3.10/site-packages/pivy/coin.py", line 3873, in getField
    return _coin.SoFieldContainer_getField(self, name)
<class 'SystemError'>: <built-in function SoFieldContainer_getField> returned a result with an exception set
  File "/usr/lib64/freecad/Mod/Draft/draftviewproviders/view_wire.py", line 89, in attach
    col.rgb.setValue(vobj.LineColor[0],vobj.LineColor[1],vobj.LineColor[2])
  File "/usr/lib64/python3.10/site-packages/pivy/coin.py", line 3989, in __getattr__
  File "/usr/lib64/freecad/Mod/Arch/ArchSectionPlane.py", line 1052, in attach
    fs.coordIndex.setValues(0,7,[0,1,2,-1,0,2,3])
  File "/usr/lib64/freecad/Mod/Arch/ArchSectionPlane.py", line 1104, in updateData
    self.txtcoords.rotation.setValue(obj.Placement.Rotation.Q)
<class 'AttributeError'>: '_ViewProviderSectionPlane' object has no attribute 'txtcoords'
  File "/usr/lib64/freecad/Mod/Arch/ArchSectionPlane.py", line 1121, in onChanged
    self.mat2.transparency.setValue(vobj.Transparency/100.0)
  File "/usr/lib64/freecad/Mod/Arch/ArchWall.py", line 1604, in attach
    tex.image = image
  File "/usr/lib64/freecad/Mod/Arch/ArchWall.py", line 1696, in setDisplayMode
    self.fset.coordIndex.deleteValues(0)
<class 'AttributeError'>: '_ViewProviderWall' object has no attribute 'fset'
07:25:13  SketchObject::onChanged(): Unmanaged change of Constraint Property results in invalid constraint indices
  File "/usr/lib64/freecad/Mod/Draft/draftviewproviders/view_dimension.py", line 702, in onChanged
    self.font.size = vobj.FontSize.Value * vobj.ScaleMultiplier
07:25:13  v0.19, Dimension, added view property 'ScaleMultiplier'
07:25:13  ----------------
07:25:13  Unset style
07:25:13  v0.19, Dimension001, added view property 'ScaleMultiplier'
07:25:13  v0.19, Dimension002, added view property 'ScaleMultiplier'
07:25:13  v0.19, Dimension003, added view property 'ScaleMultiplier'
07:25:13  v0.19, Dimension004, added view property 'ScaleMultiplier'
07:25:13  v0.19, Dimension005, added view property 'ScaleMultiplier'
07:25:13  v0.19, Dimension006, added view property 'ScaleMultiplier'
07:25:13  v0.19, Dimension007, added view property 'ScaleMultiplier'
07:25:13  v0.19, Dimension008, added view property 'ScaleMultiplier'
07:25:13  v0.19, Dimension009, added view property 'ScaleMultiplier'
07:25:13  v0.19, Dimension010, added view property 'ScaleMultiplier'
07:25:13  v0.19, Dimension011, added view property 'ScaleMultiplier'
07:25:13  v0.19, Dimension012, added view property 'ScaleMultiplier'
07:25:13  v0.19, Dimension013, added view property 'ScaleMultiplier'
07:25:13  v0.19, Dimension014, added view property 'ScaleMultiplier'
adrianinsaval
Post by adrianinsaval »
what version of pivy is it using?
Founder
Post by wmayer »
pivy seems to be built with the wrong Python version. It uses 3.10 instead of 3.11.
