0.21 topo build
drmacro
0.21 topo build
Post by drmacro »
When I do a git pull on the toponaming branch I get the following:
remote: Enumerating objects: 48, done.
remote: Counting objects: 100% (48/48), done.
remote: Compressing objects: 100% (22/22), done.
remote: Total 48 (delta 31), reused 40 (delta 26), pack-reused 0
Unpacking objects: 100% (48/48), 88.80 KiB | 1.34 MiB/s, done.
From https://github.com/FreeCAD/FreeCAD
   19a69df0fc..a88f69a9f0  master     -> origin/master
fatal: Not possible to fast-forward, aborting.
Does the fatal message mean I'm not getting the latest source of the branch?
onekk
Re: 0.21 topo build
Post by onekk »
drmacro wrote: Sat Jul 02, 2022 2:16 pm ...
[/code]
Probably is telling you that "fast forwarding" is not feasible, so you must use another way of "pulling and merging".
I'm not a git expert, usually this is caused by some incompatibilities with local version and remote version, but usually git will tell you also what has gone wrong.
Usually in the worse case, if I have not modified locally some files, i simply delete "local directory" and clone again, some bandwidth will be wasted, but usually it will save some time, as if you have to "manual merge" many files it is time consuming.
Hope it helps
Regards
Carlo D.
- Various other stuffs.
adrianinsaval
Re: 0.21 topo build
Post by adrianinsaval »
Right now the toponaming branch is basically the same as master but a little outdated and whit a different readme file so it's not worth building IMO.
I'm guessing the toponaming branch got rebased somewhere along the way and that's why you get that error, you can do
git reset --hard origin/development/toponaming
You will lose any local change you made though
drmacro
Re: 0.21 topo build
Post by drmacro »
I had previously gotten the out as noted here: https://forum.freecadweb.org/viewtopic. ... st+forward
I followed the suggestion at the end of that thread at that point.
It appeared ok after that.
Until today I noticed the out as noted in the OP.
Since I have no local changes to the branch, I have issued the above mentioned:
And it did get the new readme and no errors...
Thanks for the replies.
