[Solved] Re: FreeCAD on macOS became utterly slow
When moving from 0.20.29177 to 0.21.29865 FreeCAD became so slow that it is almost unusable. When I turn this cube with the mouse in 3D view I get with the old version this speed of 50-60 fps.
Edit: It was still fast in 0.21.29393
With the current version I have only 1/20 of this: 1-3 fps.
This happens not only in 3D view but also e.g. in Sketcher: Collapsing or expanding the constraints list at the left takes with the old version ~1 second. Doing the same in the current version takes 5 seconds. I can really see it moving line by line.
@looo: Is there some optimization missing?
Fast version
OS: macOS 10.16
Version: 0.20.29177 (Git)
Python 3.9.13, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
Locale: C/Default (C)
Installed mods:
  * FC_SU
  * DynamicData 2.46.0
  * FeedsAndSpeeds 0.4.0
  * fcgear
  * fasteners
  * sheetmetal
  * ExplodedAssembly
  * Curves 0.3.0
Slow version:
OS: macOS 10.16
Version: 0.21.29865 (Git)
Hash: fb5c731847398c5bfbc37468ba851e70860a86d5
Installed mods:
  * FC_SU
  * fcgear
  * fasteners
  * sheetmetal
  * ExplodedAssembly
  * Curves 0.3.0
edwilliams16
Post by edwilliams16 »
OS: macOS High Sierra (10.13)
Version: 0.21.29971 (Git)
Hash: 29197f503dc8c802cd82c968d16f5e1356365bda
Installed mods:
  * Curves 0.5.4
  * fasteners 0.3.51
  * fcgear 1.0.0
  * GDML 1.8.0
  * Help 1.0.3
  * lattice2 1.0.0
  * MeshRemodel 1.8919.0
  * toSketch
I just updated from a early July Mac version - neither was/is slow.
My curves is actually
adrianinsaval
Post by adrianinsaval »
what happens with a clean config?
Founder
Post by wmayer »
You should try to get a new build that uses the old libraries: Python 3.9.13, Qt 5.12.9, (and rather unlikely OCC 7.5.3)
A clean config does the trick. I will start the hard work and try to find what causes it. I will start with Software OpenGL and VBO.
It was none of the usual suspects. I will start creating a preference pack of my most important ones. That seems to be better than restoring the whole stored config anyway.
wmayer wrote: Mon Aug 08, 2022 7:32 pm You should try to get a new build that uses the old libraries: Python 3.9.13, Qt 5.12.9, (and rather unlikely OCC 7.5.3)
My first guess was not so bad: it was the "Use software OpenGL" (which I had to set when the current version of macOS was introduced).
The problem was, that changing it in the settings has no effect on the running instance. It takes effect on next restart.
Founder
Post by wmayer »
chrisb wrote: Sun Aug 14, 2022 9:46 am The problem was, that changing it in the settings has no effect on the running instance. It takes effect on next restart.
Yes, it must be set before creating a QApplication in order to take effect.
So, if I got you right it's fast if the option is not set but becomes slow after setting it and restarting FreeCAD -- which actually makes sense. But do you must set it to achieve correct behaviour?
wmayer wrote: Sun Aug 14, 2022 11:18 am But do you must set it to achieve correct behaviour?
No it runs perfectly now without. It was in the beginning of macOS 12 where I needed it. Looo has in the meantime added some specific environment variables and Apple has made some updates too. So everything ok now!
DanielIS
Re: [Solved] Re: FreeCAD on macOS became utterly slow
Post by DanielIS »
Thank you very much, just update to 0.20.1 and had this problem, it drove me Crazy.
