The Path workbench does not start
_taras_
Post by _taras_ »
When starting Path, the inscription appears Import.so The shared object file cannot be opened. There is no such file or directory.
In the report window
09:08:00  Import.so: it is impossible to open a shared object file: There is no such file or directory
09:08:00  Traceback (most recent call last):
  File "<string>", line 62, in Initialize
  File "/usr/share/freecad-daily/Mod/Path/PathScripts/PathPreferencesPathJob.py", line 27, in <module>
    import PathGui as PGui  # ensure Path/Gui/Resources are loaded
I use
OS: Ubuntu 20.04.4 LTS (XFCE/xubuntu)
Version: 0.21.
Branch: unknown
Hash: d88729d2c42630064142b341b636c2ff6afa1391
Python 3.8.10, Qt 5.12.8, Coin 4.0.0, Vtk 7.1.1, OCC 7.5.2
Locale: Russian/Russia (ru_RU)
srr55
Re: The Path workbench does not start
Post by srr55 »
I also ran into this issue with FreeCAD 0.21 (command line only) on Ubuntu 20.04 in Docker. I tried building it with FreeCAD version 0.20 and the Path module imports no problem.
xc22143
Post by xc22143 »
srr55 wrote: Fri Aug 12, 2022 10:50 pm
Thank you for your reply! What should I do to compile the back version? I use the tortoisegit to get the source code. Maybe I should choose 'v20' branch not the 'master' branch?
Syres
Post by Syres »
_taras_ wrote: Tue Aug 09, 2022 7:22 am
Version: 0.21.
Branch: unknown
There are a few things about the output that raises questions, compare it to my a couple of days out of date:
OS: Linux Mint 20.3 (X-Cinnamon/cinnamon)
Version: 0.21.30173 (Git)
Hash: ded17b7543c492d9051af454ced20781bbaa0d38
Python 3.8.10, Qt 5.12.8, Coin 4.0.0, Vtk 7.1.1, OCC 7.3.0
Installed mods:
  * A2plus 0.4.56a
  * Curves 0.5.6
  * Plot 2022.4.17
  * fasteners 0.4.2
  * sheetmetal 0.2.56
Your hash is 19 days old so when you run git pull in the source folder is it actually showing how many files have changed, along with insertions and deletions such as:
477 files changed, 1241 insertions(+), 1564 deletions(-)
Also there's no proper git version in your output so I had to look up how old the build was using the hash.
onekk
Post by onekk »
Probably trying with an Appimage will be a good test.
I've noted some strange things, as OCCT and VTK version very old compared to a recent Appimage of 0.20.1:
OS: Artix Linux (openbox)
Version: 0.20.1.29410 (Git) AppImage
Branch: (HEAD detached at 0.20.1)
Hash: f5d13554ecc7a456fb6e970568ae5c74ba727563
Locale: Italian/Italy (it_IT)
Installed mods:
  * Curves 0.5.6
Regards
Carlo D.
- Various other stuffs.
