Build fails with todays git pull
drmacro
Post by drmacro »
I get the following today after git pull on master.
[ 53%] Linking CXX shared library ../../../../Mod/Mesh/Mesh.so
[ 53%] Built target Mesh
make: *** [Makefile:149: all] Error 2
Same thing worked fine yesterday.
First time it failed today I removed CMakeCache.txt from the build directory. It got a bit further.
When that failed I remove the entire contents of the build directory. This produced the error shown above.
Syres
Re: Build fails with todays git pull
Post by Syres »
I just updated a couple of minutes ago succesfully using Python 3.6.9, Qt5.9.5 and OCCT 7.3 on Linux Mint 19.3. Have a go at Git Bisect, this is a good step-by-step tutorial https://www.youtube.com/watch?v=D7JJnLFOn4A
Use the commit from the end of 7th August as your Good 8b06680eb826983bc4f489a5b37beb00358dd549 , assuming it still compiles with it!!
drmacro
Post by drmacro »
Interesting that Manjaro/AUR builds fine with 30036.
But, the error was on Debian...which is usually rock solid compared to Manjaro. :cry:
Syres
Post by Syres »
Looks like Windows compilation has problems also based on https://forum.freecadweb.org/viewtopic. ... 11#p616411
adrianinsaval
Post by adrianinsaval »
Surely there are more useful error messages somewhere above, you should post those or upload your full log so it can be properly evaluated.
Founder
Post by wmayer »
drmacro wrote: Tue Aug 09, 2022 12:40 pm I get the following today after git pull on master.
What's the OCC version you use?
drmacro
Post by drmacro »
adrianinsaval wrote: Tue Aug 09, 2022 3:32 pm Surely there are more useful error messages somewhere above, you should post those or upload your full log so it can be properly evaluated.
That message is the sum total of what is displayed.
But, I also log all output. There are several thousand lines, would you like to read them? ;)
Edit: I saw that there had been new commits recently so, tried again.
The log was only a bit over 300 lines, I don't think there is much more helpful:
-- Compiler: GNU, version: 10.2.1
-- prefix: /usr/local
-- bindir: bin
-- datadir: share
-- docdir: share/doc/FreeCAD
-- includedir: include
-- libdir: lib
-- cmake: 3.18.4
-- Could NOT find Doxygen (missing: DOXYGEN_EXECUTABLE)
-- PyCXX found:
--   Headers:  /home/mac/freecad-source/src
--   Sources:  /home/mac/freecad-source/src/CXX
--   Version:  7.1.7
-- -- Found OCE/OpenCASCADE version: 7.7.0
-- -- OCE/OpenCASCADE include directory: /home/mac/occt77-install/include/opencascade
-- -- OCE/OpenCASCADE shared libraries directory: /home/mac/occt77-install/lib
-- The imported target "vtkParseOGLExt" references the file
   "/usr/bin/vtkParseOGLExt-7.1"
but this file does not exist.  Possible reasons include:
* The file was deleted, renamed, or moved to another location.
* An install or uninstall procedure did not complete successfully.
* The installation package was faulty and contained
   "/usr/lib/cmake/vtk-7.1/VTKTargets.cmake"
but not all the files it references.
-- The imported target "vtkRenderingPythonTkWidgets" references the file
   "/usr/lib/x86_64-linux-gnu/libvtkRenderingPythonTkWidgets.so"
-- The imported target "vtk" references the file
   "/usr/bin/vtk"
-- The imported target "pvtk" references the file
   "/usr/bin/pvtk"
-- VTK components: vtkCommonCore;vtkCommonDataModel;vtkFiltersVerdict;vtkIOXML;vtkFiltersCore;vtkFiltersGeneral;vtkIOLegacy;vtkFiltersExtraction;vtkFiltersSources;vtkFiltersGeometry;vtkIOMPIParallel;vtkParallelMPI;vtkhdf5;vtkFiltersParallelDIY2;vtkRenderingCore;vtkInteractionStyle;vtkRenderingFreeType;vtkRenderingOpenGL2
-- Check for medfile (libmed and libmedc) ...
-- We guess that libmed was built using hdf5-openmpi version
-- Found Boost: /usr/lib/x86_64-linux-gnu/cmake/Boost-1.74.0/BoostConfig.cmake (found suitable version "1.74.0", minimum required is "1.55") found components: filesystem program_options regex system thread date_time
-- Shiboken2Config: Using default python: .cpython-39-x86_64-linux-gnu
-- SHIBOKEN_PYTHON_INCLUDE_DIRS computed to value: '/usr/include/python3.9'
-- SHIBOKEN_PYTHON_LIBRARIES computed to value: ''
-- libshiboken built for RelWithDebInfo
-- PYTHON_CONFIG_SUFFIX: .cpython-39-x86_64-linux-gnu
-- PySide2 Python module found at /usr/lib/python3/dist-packages/PySide2.
-- Found Matplotlib: /usr/lib/python3/dist-packages/matplotlib (found version "3.3.4")
-- Platform is 64-bit, set -D_OCC64
-- Performing Test _flag_found
-- Performing Test _flag_found - Success
-- [E57] Revison ID: E57Format-2.2.1-x86_64-linux-gcc10
-- [E57] Building static library
-- setting gcc options: -Wall -Werror -Wno-deprecated -pedantic-errors
-- Found Boost: /usr/lib/x86_64-linux-gnu/cmake/Boost-1.74.0/BoostConfig.cmake (found version "1.74.0") found components: python39
-- found Boost: 1_74
-- boost-incude dirs are: /usr/include
-- boost-python lib is:
-- boost_LIBRARY_DIRS is: /usr/lib/x86_64-linux-gnu
-- Boost_LIBRARIES is: Boost::python
-- area module (for Path Workbench) will be installed to: lib
Summary report
-- Build type:          Release
-- Compiler:            /usr/bin/c++ (10.2.1)
-- Flags:               -Wall -Wextra -Wno-write-strings
-- Standard:            Requires C++17
-- Python:              3.9.2 [/usr/bin/python3.9] [.cpython-39-x86_64-linux-gnu]
-- PCL:                 not enabled
-- pybind11:            not enabled
-- Boost:               1.74.0
-- XercesC:             3.2.3 [/usr/lib/x86_64-linux-gnu/libxerces-c.so] [/usr/include]
-- ZLIB:                1.2.11
-- PyCXX:               7.1.7 [/home/mac/freecad-source/src]
-- OCC:                 7.7.0 [TKFillet;TKMesh;TKernel;TKG2d;TKG3d;TKMath;TKIGES;TKSTL;TKShHealing;TKXSBase;TKBool;TKBO;TKBRep;TKTopAlgo;TKGeomAlgo;TKGeomBase;TKOffset;TKPrim;TKSTEPBase;TKSTEPAttr;TKSTEP209;TKSTEP;TKHLR;TKFeat] [/home/mac/occt77-install/lib] [/home/mac/occt77-install/include/opencascade]
-- SMESH:               7.7.1.0 build internal
-- MEDFile:             4.1.0 [/usr/lib/x86_64-linux-gnu/libmedC.so] [/usr/include]
-- HDF5:                1.10.6
-- VTK:                 7.1.1
-- NETGEN:              not enabled
-- SWIG:                4.0.2
-- Eigen3               3.3.9
-- Qt5Core:             5.15.2
-- Qt5Network:          5.15.2
-- Qt5Xml:              5.15.2
-- Qt5XmlPatterns:      5.15.2
-- Qt5Widgets:          5.15.2
-- Qt5PrintSupport:     5.15.2
-- Qt5OpenGL:           5.15.2
-- Qt5Svg:              5.15.2
-- Qt5UiTools:          5.15.2
-- Qt5Concurrent:       5.15.2
-- Qt5WebKitWidgets:    5.212.0
-- Designer plugin:     not built per user request (BUILD_DESIGNER_PLUGIN)
-- Shiboken2:           5.15.2 [/usr/lib/x86_64-linux-gnu/cmake/Shiboken2-5.15.2] [/usr/lib/../include/shiboken2;/usr/include/python3.9]
-- PySide2:             5.15.2 [/usr/lib/../include/PySide2]
-- PySide2Tools:        [/usr/lib/qt5/bin/uic] [/usr/lib/qt5/bin/rcc]
-- Freetype:            2.10.4
-- OpenGL:              /usr/lib/x86_64-linux-gnu/libGL.so
-- OpenGLU:             [/usr/lib/x86_64-linux-gnu/libGLU.so][/usr/include]
-- Coin3D:              4.0.0 [/usr/lib/x86_64-linux-gnu/libCoin.so] [/usr/include]
-- Pivy:                0.6.5
-- SPNAV:               [/usr/lib/libspnav.so] [/usr/include]
-- Matplotlib:          3.3.4
-- Rift:                not enabled (BUILD_VR)
-- Doxygen:             not found
-- Configuring done
-- Generating done
-- Build files have been written to: /home/mac/fc-daily-build-occt77
[  0%] Linking CXX shared library ../../../lib/libDriver.so
[  1%] Automatic MOC for target E57Format
[  1%] Built target lazy_loader
[  1%] Linking CXX shared library ../../../lib/libMEFISTO2.so
[  1%] Built target E57Format_autogen
[  1%] Automatic MOC for target FreeCADBase
[  1%] Linking CXX shared library ../../../lib/libSMDS.so
[  1%] Generating version_check
[  1%] Built target FreeCADBase_autogen
[  1%] Copying /home/mac/freecad-source/src/Mod/AddonManager/AddonManagerTest/gui/test_workers_installation.py to /home/mac/fc-daily-build-occt77/Mod/AddonManager/AddonManagerTest/gui/test_workers_installation.py
[  1%] Copying /home/mac/freecad-source/src/Mod/AddonManager/AddonManagerTest/gui/test_workers_startup.py to /home/mac/fc-daily-build-occt77/Mod/AddonManager/AddonManagerTest/gui/test_workers_startup.py
[  1%] Copying /home/mac/freecad-source/src/Mod/AddonManager/AddonManagerTest/gui/test_workers_utility.py to /home/mac/fc-daily-build-occt77/Mod/AddonManager/AddonManagerTest/gui/test_workers_utility.py
[  2%] Built target AddonManagerTests
[  2%] Copying /home/mac/freecad-source/src/Mod/AddonManager/Addon.py to /home/mac/fc-daily-build-occt77/Mod/AddonManager/Addon.py
git
/home/mac/fc-daily-build-occt77/src/Build/Version.h.out written
[  2%] Copying /home/mac/freecad-source/src/Mod/AddonManager/AddonManager.py to /home/mac/fc-daily-build-occt77/Mod/AddonManager/AddonManager.py
[  2%] Generating Version.h
[  2%] Copying /home/mac/freecad-source/src/Mod/AddonManager/addonmanager_macro.py to /home/mac/fc-daily-build-occt77/Mod/AddonManager/addonmanager_macro.py
[  2%] Built target fc_version
[  2%] Copying /home/mac/freecad-source/src/Mod/AddonManager/addonmanager_utilities.py to /home/mac/fc-daily-build-occt77/Mod/AddonManager/addonmanager_utilities.py
[  3%] Built target Arch
[  3%] Copying /home/mac/freecad-source/src/Mod/AddonManager/addonmanager_workers_startup.py to /home/mac/fc-daily-build-occt77/Mod/AddonManager/addonmanager_workers_startup.py
[  3%] Copying /home/mac/freecad-source/src/Mod/AddonManager/addonmanager_workers_installation.py to /home/mac/fc-daily-build-occt77/Mod/AddonManager/addonmanager_workers_installation.py
[  9%] Built target Draft
[  9%] Copying /home/mac/freecad-source/src/Mod/AddonManager/addonmanager_workers_utility.py to /home/mac/fc-daily-build-occt77/Mod/AddonManager/addonmanager_workers_utility.py
[ 10%] Built target FemGuiScriptsTarget
[ 10%] Copying /home/mac/freecad-source/src/Mod/AddonManager/install_to_toolbar.py to /home/mac/fc-daily-build-occt77/Mod/AddonManager/install_to_toolbar.py
[ 10%] Copying /home/mac/freecad-source/src/Mod/AddonManager/NetworkManager.py to /home/mac/fc-daily-build-occt77/Mod/AddonManager/NetworkManager.py
[ 18%] Built target FemScriptsTarget
[ 18%] Copying /home/mac/freecad-source/src/Mod/AddonManager/package_details.py to /home/mac/fc-daily-build-occt77/Mod/AddonManager/package_details.py
[ 18%] Copying /home/mac/freecad-source/src/Mod/AddonManager/package_list.py to /home/mac/fc-daily-build-occt77/Mod/AddonManager/package_list.py
[ 18%] Copying /home/mac/freecad-source/src/Mod/AddonManager/TestAddonManagerGui.py to /home/mac/fc-daily-build-occt77/Mod/AddonManager/TestAddonManagerGui.py
[ 18%] Built target AddonManager
[ 19%] Built target Idf
[ 20%] Built target FemPythonUi
[ 20%] Built target ImageScripts
[ 21%] Built target ImportScripts
[ 21%] Built target ImportPy
[ 21%] Built target FluidMaterialLib
[ 23%] Built target MaterialLib
[ 23%] Built target MaterialToolsLib
[ 24%] Built target Material
[ 24%] Built target MeshTestData
[ 24%] Built target MeshScripts
[ 24%] Built target OpenSCADTests
[ 25%] Built target OpenSCAD
[ 26%] Built target PartScripts
[ 26%] Built target WizardShaft
[ 26%] Built target PartDesignHole
[ 27%] Built target PartDesignScripts
[ 29%] Built target PathTests
[ 33%] Built target PathScripts
[ 33%] Built target Plot
[ 33%] Built target PointsScripts
[ 33%] Built target RaytracingScripts
[ 33%] Built target ReverseEngineeringScripts
[ 34%] Built target RobotScripts
[ 34%] Built target Show
[ 34%] Built target SketcherScripts
[ 34%] Built target SpreadsheetScripts
[ 34%] Built target StartTests
[ 34%] Built target StartScripts
[ 34%] Built target StartPage
[ 34%] Built target SurfaceScripts
[ 34%] Built target TDTestTarget
[ 35%] Built target TechDraw_Data
[ 35%] Built target Test
[ 35%] Built target Tux
[ 35%] Built target WebScripts
[ 36%] Built target SMDS
[ 36%] Built target FreeCADGui_Resources
[ 36%] Built target PreferencePacks_data
[ 38%] Built target Stylesheets_data
[ 39%] Built target PreferencePackTemplates_data
[ 39%] Built target Example_data
[ 39%] Linking CXX shared library ../../../lib/libSMESHDS.so
[ 40%] Built target E57Format
[ 40%] Linking CXX shared library ../../lib/libFreeCADBase.so
[ 43%] Built target FreeCADBase
[ 43%] Automatic MOC for target FreeCADApp
[ 43%] Built target FreeCADApp_autogen
Scanning dependencies of target FreeCADApp
[ 43%] Building CXX object src/App/CMakeFiles/FreeCADApp.dir/Application.cpp.o
[ 43%] Built target SMESHDS
[ 43%] Built target MEFISTO2
[ 43%] Built target Driver
[ 43%] Linking CXX shared library ../../../lib/libDriverSTL.so
[ 43%] Linking CXX shared library ../../../lib/libDriverUNV.so
[ 43%] Linking CXX shared library ../../../lib/libDriverDAT.so
[ 44%] Built target DriverDAT
[ 44%] Built target DriverUNV
[ 44%] Built target DriverSTL
[ 44%] Linking CXX shared library ../../../lib/libSMESH.so
[ 45%] Built target SMESH
[ 45%] Linking CXX shared library ../../../lib/libStdMeshers.so
[ 47%] Built target StdMeshers
[ 47%] Linking CXX shared library ../../lib/libFreeCADApp.so
[ 49%] Built target FreeCADApp
[ 49%] Automatic MOC for target FreeCADMainPy
[ 49%] Automatic MOC for target FreeCADMainCmd
[ 49%] Automatic MOC for target Part
[ 49%] Automatic MOC for target Image
[ 49%] Automatic MOC for target FreeCADGui
[ 49%] Built target FreeCADMainCmd_autogen
[ 49%] Built target FreeCADMainPy_autogen
[ 49%] Built target Part_autogen
[ 49%] Built target Image_autogen
[ 49%] Automatic MOC for target Mesh
[ 49%] Automatic MOC for target Spreadsheet
[ 49%] Automatic MOC for target Points
[ 49%] Built target Mesh_autogen
[ 49%] Built target Spreadsheet_autogen
[ 49%] Automatic MOC for target Start
[ 49%] Built target Points_autogen
[ 49%] Built target Start_autogen
[ 49%] Automatic MOC for target Web
[ 49%] Linking CXX shared library ../../lib/FreeCAD.so
[ 49%] Linking CXX executable ../../bin/FreeCADCmd
[ 49%] Built target Web_autogen
Scanning dependencies of target Image
[ 49%] Building CXX object src/Mod/Image/App/CMakeFiles/Image.dir/ImagePlane.cpp.o
Scanning dependencies of target Points
[ 49%] Building CXX object src/Mod/Points/App/CMakeFiles/Points.dir/AppPoints.cpp.o
Scanning dependencies of target Mesh
[ 49%] Building CXX object src/Mod/Mesh/App/CMakeFiles/Mesh.dir/Core/Decimation.cpp.o
Scanning dependencies of target Part
[ 49%] Building CXX object src/Mod/Mesh/App/CMakeFiles/Mesh.dir/Core/Degeneration.cpp.o
[ 49%] Building CXX object src/Mod/Image/App/CMakeFiles/Image.dir/AppImage.cpp.o
[ 49%] Building CXX object src/Mod/Points/App/CMakeFiles/Points.dir/AppPointsPy.cpp.o
[ 49%] Building CXX object src/Mod/Part/App/CMakeFiles/Part.dir/FeaturePartBoolean.cpp.o
[ 49%] Building CXX object src/Mod/Mesh/App/CMakeFiles/Mesh.dir/Core/Evaluation.cpp.o
[ 49%] Linking CXX shared library ../../../../Mod/Image/Image.so
Scanning dependencies of target Spreadsheet
[ 49%] Building CXX object src/Mod/Spreadsheet/App/CMakeFiles/Spreadsheet.dir/Spreadsheet_autogen/mocs_compilation.cpp.o
[ 49%] Building CXX object src/Mod/Spreadsheet/App/CMakeFiles/Spreadsheet.dir/Cell.cpp.o
[ 49%] Building CXX object src/Mod/Spreadsheet/App/CMakeFiles/Spreadsheet.dir/PropertySheet.cpp.o
[ 49%] Building CXX object src/Mod/Points/App/CMakeFiles/Points.dir/Points.cpp.o
[ 49%] Building CXX object src/Mod/Mesh/App/CMakeFiles/Mesh.dir/Core/MeshKernel.cpp.o
[ 49%] Building CXX object src/Mod/Points/App/CMakeFiles/Points.dir/PointsPyImp.cpp.o
[ 49%] Building CXX object src/Mod/Mesh/App/CMakeFiles/Mesh.dir/Core/Segmentation.cpp.o
[ 49%] Building CXX object src/Mod/Spreadsheet/App/CMakeFiles/Spreadsheet.dir/PropertySheetPyImp.cpp.o
[ 49%] Building CXX object src/Mod/Mesh/App/CMakeFiles/Mesh.dir/Core/SetOperations.cpp.o
[ 49%] Built target FreeCADGui_autogen
[ 49%] Building CXX object src/Mod/Mesh/App/CMakeFiles/Mesh.dir/Core/TopoAlgorithm.cpp.o
[ 49%] Building CXX object src/Mod/Points/App/CMakeFiles/Points.dir/PointsAlgos.cpp.o
[ 49%] Building CXX object src/Mod/Mesh/App/CMakeFiles/Mesh.dir/Core/Visitor.cpp.o
[ 49%] Building CXX object src/Mod/Mesh/App/CMakeFiles/Mesh.dir/AppMesh.cpp.o
[ 49%] Building CXX object src/Mod/Spreadsheet/App/CMakeFiles/Spreadsheet.dir/PropertyColumnWidths.cpp.o
[ 49%] Building CXX object src/Mod/Mesh/App/CMakeFiles/Mesh.dir/AppMeshPy.cpp.o
[ 49%] Building CXX object src/Mod/Mesh/App/CMakeFiles/Mesh.dir/Exporter.cpp.o
[ 49%] Building CXX object src/Mod/Spreadsheet/App/CMakeFiles/Spreadsheet.dir/PropertyColumnWidthsPyImp.cpp.o
[ 49%] Building CXX object src/Mod/Spreadsheet/App/CMakeFiles/Spreadsheet.dir/PropertyRowHeights.cpp.o
[ 49%] Building CXX object src/Mod/Mesh/App/CMakeFiles/Mesh.dir/Importer.cpp.o
[ 49%] Building CXX object src/Mod/Spreadsheet/App/CMakeFiles/Spreadsheet.dir/PropertyRowHeightsPyImp.cpp.o
[ 49%] Building CXX object src/Mod/Points/App/CMakeFiles/Points.dir/PointsFeature.cpp.o
[ 49%] Building CXX object src/Mod/Mesh/App/CMakeFiles/Mesh.dir/Edge.cpp.o
[ 49%] Building CXX object src/Mod/Spreadsheet/App/CMakeFiles/Spreadsheet.dir/PreCompiled.cpp.o
[ 49%] Building CXX object src/Mod/Spreadsheet/App/CMakeFiles/Spreadsheet.dir/Sheet.cpp.o
[ 49%] Building CXX object src/Mod/Mesh/App/CMakeFiles/Mesh.dir/EdgePyImp.cpp.o
[ 49%] Building CXX object src/Mod/Spreadsheet/App/CMakeFiles/Spreadsheet.dir/SheetPyImp.cpp.o
[ 49%] Building CXX object src/Mod/Mesh/App/CMakeFiles/Mesh.dir/Facet.cpp.o
[ 49%] Building CXX object src/Mod/Mesh/App/CMakeFiles/Mesh.dir/FacetPyImp.cpp.o
[ 49%] Building CXX object src/Mod/Points/App/CMakeFiles/Points.dir/PointsGrid.cpp.o
[ 49%] Building CXX object src/Mod/Mesh/App/CMakeFiles/Mesh.dir/FeatureMeshCurvature.cpp.o
[ 49%] Building CXX object src/Mod/Mesh/App/CMakeFiles/Mesh.dir/FeatureMeshDefects.cpp.o
[ 49%] Building CXX object src/Mod/Mesh/App/CMakeFiles/Mesh.dir/FeatureMeshExport.cpp.o
[ 49%] Building CXX object src/Mod/Points/App/CMakeFiles/Points.dir/Properties.cpp.o
[ 49%] Building CXX object src/Mod/Mesh/App/CMakeFiles/Mesh.dir/FeatureMeshImport.cpp.o
[ 49%] Building CXX object src/Mod/Spreadsheet/App/CMakeFiles/Spreadsheet.dir/SheetObserver.cpp.o
[ 49%] Building CXX object src/Mod/Spreadsheet/App/CMakeFiles/Spreadsheet.dir/Utils.cpp.o
[ 49%] Building CXX object src/Mod/Spreadsheet/App/CMakeFiles/Spreadsheet.dir/AppSpreadsheet.cpp.o
[ 49%] Building CXX object src/Mod/Points/App/CMakeFiles/Points.dir/PropertyPointKernel.cpp.o
[ 49%] Building CXX object src/Mod/Mesh/App/CMakeFiles/Mesh.dir/FeatureMeshSegmentByMesh.cpp.o
[ 49%] Building CXX object src/Mod/Mesh/App/CMakeFiles/Mesh.dir/FeatureMeshSetOperations.cpp.o
[ 49%] Building CXX object src/Mod/Points/App/CMakeFiles/Points.dir/Structured.cpp.o
[ 49%] Building CXX object src/Mod/Mesh/App/CMakeFiles/Mesh.dir/FeatureMeshSolid.cpp.o
[ 49%] Linking CXX shared library ../../../../Mod/Spreadsheet/Spreadsheet.so
[ 49%] Building CXX object src/Mod/Mesh/App/CMakeFiles/Mesh.dir/FeatureMeshTransform.cpp.o
[ 49%] Building CXX object src/Mod/Mesh/App/CMakeFiles/Mesh.dir/FeatureMeshTransformDemolding.cpp.o
[ 49%] Building CXX object src/Mod/Mesh/App/CMakeFiles/Mesh.dir/Mesh.cpp.o
[ 49%] Linking CXX shared library ../../../../Mod/Points/Points.so
[ 49%] Building CXX object src/Mod/Mesh/App/CMakeFiles/Mesh.dir/MeshFeature.cpp.o
[ 49%] Building CXX object src/Mod/Mesh/App/CMakeFiles/Mesh.dir/MeshFeaturePyImp.cpp.o
[ 49%] Building CXX object src/Mod/Mesh/App/CMakeFiles/Mesh.dir/MeshPointPyImp.cpp.o
[ 49%] Building CXX object src/Mod/Mesh/App/CMakeFiles/Mesh.dir/MeshProperties.cpp.o
[ 49%] Building CXX object src/Mod/Mesh/App/CMakeFiles/Mesh.dir/MeshPyImp.cpp.o
[ 49%] Building CXX object src/Mod/Mesh/App/CMakeFiles/Mesh.dir/MeshTexture.cpp.o
[ 49%] Building CXX object src/Mod/Mesh/App/CMakeFiles/Mesh.dir/Segment.cpp.o
[ 49%] Linking CXX shared library ../../../../Mod/Mesh/Mesh.so
[ 51%] Built target Mesh
drmacro
Post by drmacro »
Apparently commit 99084f1a62114d0dfa5886a50e602e906537d7ca fixed it...
