Lately when building from the bleeding edge, I've been getting complaints that Matplotlib can't be found. But it actually IS installed through Debian's APT package system. Pip3 doesn't want to install it because it's already been installed through APT. Of course, this prevents the Path workbench from loading and may be related to the problem described here: https://forum.freecadweb.org/posting.ph ... =4&t=70945
Here's what I get when calling cmake:
cmake ../FreeCAD -DCMAKE_INSTALL_PREFIX=/opt/freecad -DBUILD_QT5=ON -DPYTHON_EXECUTABLE=/usr/bin/python3
-- The imported target "vtkParseOGLExt" references the file
"/usr/bin/vtkParseOGLExt-7.1"
but this file does not exist. Possible reasons include:
* The file was deleted, renamed, or moved to another location.
* An install or uninstall procedure did not complete successfully.
* The installation package was faulty and contained
"/usr/lib/cmake/vtk-7.1/VTKTargets.cmake"
but not all the files it references.
-- The imported target "vtkRenderingPythonTkWidgets" references the file
"/usr/lib/x86_64-linux-gnu/libvtkRenderingPythonTkWidgets.so"
-- The imported target "vtk" references the file
"/usr/bin/vtk"
-- The imported target "pvtk" references the file
"/usr/bin/pvtk"
-- VTK components: vtkCommonCore;vtkCommonDataModel;vtkFiltersVerdict;vtkIOXML;vtkFiltersCore;vtkFiltersGeneral;vtkIOLegacy;vtkFiltersExtraction;vtkFiltersSources;vtkFiltersGeometry;vtkIOMPIParallel;vtkParallelMPI;vtkhdf5;vtkFiltersParallelDIY2;vtkRenderingCore;vtkInteractionStyle;vtkRenderingFreeType;vtkRenderingOpenGL2
Matplotlib not found, Plot module won't be available.
