0.20 no start after installation on Windows 10
nordman
Post by nordman »
Hallo,
i have on PC Windows 10, last updates, 64-bit
0.19 work without problem.
But 0.20 after installation i can start one time only.
If i close 0.20 and after that try to start, i get message:
Initialization of FreeCAD failed
Unknown runtime error occurred while initializing FreeCAD.
Please contact the applications support for more information.
I tryed to start from icon and from .exe in freeCAD folder. Get the same message.
What could be the error?
Re: 0.20 no start after installation on Windows 10
Please always retry such issues with the latest development version. If that doesn't help, please create a log file with the additional commandline parameter --write-log. It will be placed in %APPDATA%\FreeCAD. Paste its contents here wrapped in code tags.
nordman
Post by nordman »
Thanks! With last develop 20.1 - the same error message.
I started freeCAD 20.1 in the commandline: "C:\Program Files\FreeCAD 0.20\bin\FreeCAD.exe"--write-log
But in directory
Windows(C:) > user > TOM > AppData > Roaming > FreeCAD
there is no log file.
Please help: what is file name and how to find file,dirctory %APPDATA%\FreeCAD ?
nordman wrote: Tue Aug 16, 2022 12:20 pm I started freeCAD 20.1 in the commandline: "C:\Program Files\FreeCAD 0.20\bin\FreeCAD.exe"--write-log
You need an additional space before the --write-log
nordman
Post by nordman »
Start 0.20.1 in commandoline "C:\Program Files\FreeCAD 0.20\bin\FreeCAD.exe" --write-log
No log file in Windows(C:) > user > TOM > AppData > Roaming > FreeCAD
nordman wrote: Tue Aug 16, 2022 1:42 pm No log file in Windows(C:) > user > TOM > AppData > Roaming > FreeCAD
Please start and terminate your FreeCAD. Look in the aforementioned folder. Has the file user.cfg got a new timestamp?
nordman
Post by nordman »
File user.cfg did NOT get a new timestamp after i click to start.
And this message i get immediately, in the same time if i click:
Did you install as normal user or as admin? Looks like a permissions issue.
What does the addon macro findConfigFiles say?
nordman
Post by nordman »
I'm admin on my PC, all installations as admin.
I have ESET antivirus, but i tred to set swich off ESET - did not help.
And 0.19.4 work perfectely on my PC.
I dont know how to start addon macro findConfigFiles ?
nordman wrote: Tue Aug 16, 2022 10:08 pm I dont know how to start addon macro findConfigFiles ?
You can use the AddonManager to install the macro. If it cannot be installed, you can go to http://www.freecadweb.org/wiki/index.ph ... onfigFiles copy the code and execute it in the Python console.
