No module PySide2.QtUiTools
drmacro
Post by drmacro »
Trying to figure out if something I did messed things up or if this is legitimate.
I start FC. The first time I select the A2+ workbench it produces this error, but only the first.
No module named 'PySide2.QtUiTools'
The other day I installed the qt tools to use designer:
pip install pyqt5-tools
Is this what messed up my environment? Or is there an issue with A2+
I checked and all the build deps are still ok (have been for months...)
And, it does build fine.
I'm not sure if this is an A2+ thing or I messed up my environment...feel free to move the the Assembly forum if that makes more sense.
Syres
Re: No module PySide2.QtUiTools
Post by Syres »
Try
sudo apt install python3-pyside2.qtuitools
and see if it fixes the error. No idea if the pyqt-tools caused it.
drmacro
Post by drmacro »
Syres wrote: Fri Aug 19, 2022 4:07 pm Try
Thanks, that got it.
So, did the pip install I did overwrite something?
Syres
Post by Syres »
Quite possibly, I'm just going through a full install of everything on top of a new SSD with Linux Mint 20.3 and keeping a close eye on very subtle Qt changes but I've no intention of upgrading anything I don't have to.
adrianinsaval
Post by adrianinsaval »
if possible prefer installing distro packages over pip, pip seems to be too problematic.
drmacro
Post by drmacro »
adrianinsaval wrote: Fri Aug 19, 2022 9:41 pm if possible prefer installing distro packages over pip, pip seems to be too problematic.
Sure, but I couldn't find a distro package that included QtDesigner on Debian.
waebbl
Post by waebbl »
I just tried this on my Gentoo box and also got this error. Problem here is, that FreeCAD doesn't depend on the designer module of PySide2. Because no other of my installed packages needs it, PySide2 is built without support of this optional module. A simple reinstall of the pyside2 package with the designer module enabled would probably solve this.
Would it be possible to add something like a dependency check to the AddonManager and the query interface between it and the addons? So an addon exposes the dependencies it needs and the AddonManager only allows installation of an addon if all dependencies are satisfied and displays instructions on how to solve the issue if the dependencies are not satisfied.
Post by Kunda1 »
waebbl wrote: Fri Aug 19, 2022 11:34 pm Would it be possible to add something like a dependency check to the AddonManager and the query interface between it and the addons? So an addon exposes the dependencies it needs and the AddonManager only allows installation of an addon if all dependencies are satisfied and displays instructions on how to solve the issue if the dependencies are not satisfied.
Hey @waebbl there is Package_Metadata but if you need more granularity, please open a ticket on https://github.com/FreeCAD/FreeCAD-addons/
waebbl
Post by waebbl »
Kunda1 wrote: Sat Aug 20, 2022 2:21 am
Hi @Kunda1, thanks for the hint. At a first glance this looks like what I was asking. Gonna take a deeper look into this.
Post by Kunda1 »
