Appimage delivered with Glider wb
david69
Post by david69 »
AppImage comes with Glider workbench.
and the update of Help Addon is abnormal, see my Freecad info below.
OS: Ubuntu 22.04.1 LTS (LXQt/Lubuntu)
Version: 0.21.30492 (Git) AppImage
Hash: b4578fb3eae842eb510a1bc055d07d369a67ce94
Python 3.10.6, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Locale: French/France (fr_FR)
Installed mods:
  * Help.backup1662889774.5125165 1.0.3
  * Help 1.0.3
anybody else observes that?
adrianinsaval
Re: Appimage delivered with Glider wb
Post by adrianinsaval »
glider workbench is added by looo who is the packager for the appimage, IIRC he develops that workbench too. The help addon thing is a bug with the addon manager I think, can you weight in @chennes ?
chennes
Post by chennes »
Those backups get created when something goes wrong with a git update that requires a re-clone. As a general rule they can be safely deleted if the addon is not creating any trouble, but I have not yet automated that process.
Chris Hennes
Pioneer Library System
david69
Post by david69 »
@looo can you give a look to this thread pls?
the fact that Glider is delivered with AppImage, is it an error or something planned?
@chennes I am not behind my personnal computer, I'll do that this evening. I will remove and put it back this Addon. Would also be great to have the possibility to translate the interface on Crowdin of Help Addon. I keep you in touch.
david69
Post by david69 »
here my FreeCAD info once I have removed Help Addon with the Addon manager:
Installed mods:
david69
Post by david69 »
chennes wrote: Mon Oct 10, 2022 12:59 am As a general rule they can be safely deleted if the addon is not creating any trouble, but I have not yet automated that process.
as you can see in my previous post, after removing the Help Addon, I still have the backup trace.
when you say, one can remove it, how do you manually do that?
looo
Post by looo »
david69 wrote: Mon Oct 10, 2022 10:01 am @looo can you give a look to this thread pls?
the glider workbench is shipped with the weekly builds, I can remove it if wanted.
david69
Post by david69 »
yes please remove it if it is not too much work. the lighter the better.
david69 wrote: Sun Oct 30, 2022 3:35 pm yes please remove it if it is not too much work. the lighter the better.
+1
And it often needs explanations to newbies why just this workbench is included.
david69
Post by david69 »
I also wish the removal of Reverse engineering, Robot workbenches as they are no more supported as official workbench with V1.0.
Paddle has also raised the point about the shortcut <none> and I don't know the status about Test Framework and Web.
I guess it requires extra work to purge these workbenches. That's an other story.
