Appimage delivered with Glider wb
onekk
Re: Appimage delivered with Glider wb
Post by onekk »
david69 wrote: Mon Oct 31, 2022 9:30 am I also wish the removal of Reverse engineering, Robot workbenches as they are no more supported as official workbench with V1.0.
Paddle has also raised the point about the shortcut <none> and I don't know the status about Test Framework and Web.
I guess it requires extra work to purge these workbenches. That's an other story.
I don't think Reverse Engineering WB is not supported, as it is made by @wmayer and hold some updated 11 months ago, and recently I have had some discussion about it and he has told me none about his deprecation, He has only mentioned that as soon as he has some spare time he will check a couple of things.
I admit that is not wide used, but when you have to make use of point clouds and made some approximating of surfaces, it is the only tool available for now.
Regards
Carlo D.
- Various other stuffs.
david69
Post by david69 »
onekk wrote: Mon Oct 31, 2022 10:06 am ...I don't think Reverse Engineering WB is not supported, ...
Carlo D.
good if it is supported.
was it not said that this workbench may move as an external workbench? may be I misread.
onekk
Post by onekk »
david69 wrote: Mon Oct 31, 2022 12:43 pm
Carlo D.
I don't know, but probably not as it is coded in C.
Sadly compiled things are very sensible regarding libraries mismatch, as example if you compile it for OCCT 7.6.1 and FreeCAD is compiled with OCCT 7.5.3 things could not work.
Such thing will work as example if you are bundling your own WB with FreeCAD, you start with a defined FreeCAD version and then compile FreeCAD and your own C++ WB to make an AppImage or similar for each platform (Linux, Windows and MacOS), so the base libraries are the same.
But if you intend to distribute it as a separate WB to be managed by the AddOn Manager, from the little I know I think it is not feasible.
Regards
Carlo D.
david69
Post by david69 »
thank you for the detailed answer.
yes not easy when initial code is well mixed, nested.
looo
Post by looo »
Opengilder and the glider-wb are removed now.
looo wrote: Sat Nov 26, 2022 12:27 pm Opengilder and the glider-wb are removed now.
Thanks! Looks more professional now.
david69
Post by david69 »
OS: Ubuntu 22.04.1 LTS (LXQt/Lubuntu)
Version: 0.21.31109 (Git) AppImage
Hash: c23ee7ad88433a0f00e84afae0a62fe738be0c09
Python 3.10.8, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Locale: French/France (fr_FR)
Installed mods:
  * Help 1.0.3
no more Glider, thank you looo
