cannot import name 'Qt' from 'PySide.QtGui'
MrGadget49
Post by MrGadget49 »
Hello FreeCAD builders,
I'm not sure if this is the right forum, for this question, but I'm posting it here because I believe it is related to my build of FreeCad. I do not experience this problem when I run a recent appImg.
The problem is, I get the following error when I run a macro (widgetExample)
02:09:43 Traceback (most recent call last):
File "/home/jody/.local/share/FreeCAD/Macro/widgetExample.FCMacro", line 1, in <module>
from PySide.QtGui import QWidget, QLabel, Qt, QVBoxLayout, QHBoxLayout, QPushButton, QListWidget, QListWidgetItem
<class 'ImportError'>: cannot import name 'Qt' from 'PySide.QtGui' (/home/jody/freecad/freecad-build/Ext/PySide/QtGui.py)
I thought perhaps I was missing a library or something, but I compared my list (show below) with the one from the appImage that works and everything related to PySide and QT seems to be there.
This software uses open source components whose copyright and other proprietary rights belong to their respective owners:
    Boost 1_67
    https://www.boost.org
    Coin3D 4.0.0a
    https://coin3d.github.io
    Eigen 3.3.7
    https://eigen.tuxfamily.org
    FreeType 2.9.1
    https://freetype.org
    KDL
    https://www.orocos.org/kdl
    libarea
    https://github.com/danielfalck/libarea
    Open CASCADE Technology 7.3.0
    https://www.opencascade.com/open-cascade-technology/
    Point Cloud Library
    https://www.pointclouds.org
    PyCXX 7.1.7
    http://cxx.sourceforge.net
     Python 3.7.3
     https://www.python.org
    Qt for Python (PySide) 5.11.2
    https://wiki.qt.io/Qt_for_Python
    Qt 5.11.3
    https://www.qt.io
    Salome SMESH
    https://salome-platform.org
    Qt for Python (Shiboken) 5.11.2
    vtk 6.3.0
    https://www.vtk.org
    Xerces-C 3.2.2
    https://xerces.apache.org/xerces-c
    Zipios++
    http://zipios.sourceforge.net
    zlib 1.2.11
    https://zlib.net
The script is presented below but like I said, it works on one of the recent app images that I was using before I made my build. It's failing on line one.
class MyWidget(QWidget):
	def __init__(self,text):
		super(MyWidget,self).__init__()
		label = QLabel(text)
		label.setAlignment(Qt.AlignCenter | Qt.AlignRight)
		button = QPushButton("push me!")
		layout = QHBoxLayout()
		layout.addWidget(label)
		layout.addWidget(button)
		self.setLayout(layout)
class MyWindow(QWidget):
	def __init__(self):
		super(MyWindow,self).__init__()
		list = QListWidget()
		listItem = QListWidgetItem(list)
		listItemWidget = MyWidget("listItem")
		listItem.setSizeHint(listItemWidget.sizeHint())
		list.addItem("Item one")
		list.addItem("Item two")
		list.addItem(listItem)
		list.setItemWidget(listItem,listItemWidget)
		myWidget1 = MyWidget("test1")
		layout = QVBoxLayout()
		layout.addWidget(myWidget1)
		layout.addWidget(list)
		mySize = QtCore.QSize(1000, 200)
		self.setFixedSize(mySize)
		self.show()
myWin=MyWindow()
OS: Debian GNU/Linux 10 (buster) (MATE/mate)
Version: 0.21.30623 (Git)
Build type: Unknown
Branch: myWorkBranch
Hash: 27f08f38b1658e419e20a153e13236eff1293b77
Python 3.7.3, Qt 5.11.3, Coin 4.0.0a, Vtk 6.3.0, OCC 7.3.0
Installed mods:
  * lattice2 1.0.0
  * Assembly4 0.12.4
  * Curves 0.5.8
  * fasteners 0.4.13
  * sheetmetal 0.2.57
Any ideas or suggestions would be greatly appreciated! Also, if there isany other information I can post that would help, please let me know.
Jody
onekk
Re: cannot import name 'Qt' from 'PySide.QtGui'
Post by onekk »
See maybe:
https://wiki.freecadweb.org/PySide
Probably Qt is not a Child of PySide.QtGui.
Why see linked text.
Regards
Carlo D.
- Various other stuffs.
chennes
Post by chennes »
I am not at a computer to double check, but I think Qt is in QtCore.
Chris Hennes
Pioneer Library System
heda
Post by heda »
from appimage...
>>> from PySide import QtCore, QtGui
>>> 'Qt' in dir(QtGui)
True
>>> 'Qt' in dir(QtCore)
True
>>> from PySide.QtCore import Qt
>>> from PySide.QtGui import Qt
so you are probably right in that it has to do with your build,
what knob to turn is way out of my realm - you need some compilation flag whiz to get help for that...
MrGadget49
onekk wrote: Mon Nov 28, 2022 9:43 am See maybe:
Regards
Carlo D.
Thanks, Carlo. I learned a lot from your link. It definitely helped!
I also learned that you are correct, Qt is not from QtGui. Not in my version anyway. In the appImage version, it seems to be in both. In my version it's only in QtCore. See the post below for more info.
Jody
MrGadget49
chennes wrote: Mon Nov 28, 2022 1:35 pm I am not at a computer to double check, but I think Qt is in QtCore.
I found out that you are correct, In my version it is only in QtCore.
MrGadget49
heda wrote: Mon Nov 28, 2022 4:32 pm from appimage...
>>> 'Qt' in dir(QtGui)
True
>>> 'Qt' in dir(QtCore)
True
Thanks for the clue Heda,
I ran the same from my Python console and got... (Sorry it's so big)
So, based on that, I did a little playing around with the include on line 1 of my original file and replaced it with:
from PySide import QtGui, QtCore
from PySide.QtGui import QWidget,QListWidget,QListWidgetItem,QLabel,QPushButton,QHBoxLayout,QVBoxLayout
I just deleted everything from my original line except QtGui & QtCore. Then I added them in one at a time as they came up missing. In the end, I didn't even need 'Qt' and the script runs.
I'm still certain that there is something about my build that isn't quite rite. The script did run on the appImages as it was. I would really like to understand why. If there are any compilation flag wizards out there who could shed any light on it, I would love to know.
Thanks again Heda, You really helped get me going in the rite direction.
Jody
Post by Kunda1 »
>>> 'Qt' in dir(QtGui)
True
>>> 'Qt' in dir(QtCore)
True
An aside: this is a great block of code to add to the wiki somewhere. Maybe in the poweruser section or scripting ? Maybe in FreeCAD_Scripting_Basics ?
MrGadget49
Kunda1 wrote: Wed Nov 30, 2022 12:38 pm An aside: this is a great block of code to add to the wiki somewhere. Maybe in the poweruser section or scripting ? Maybe in FreeCAD_Scripting_Basics ?
I agree, I've already added it to my toolbox! :)
Jody
