I face a quite basic display topic, that's why I put it in the install/compile forum, please see attachment and look at the menu bar and the open menu.
FreeCAD is 0.19, I also tried latest snap release with no effect.
Ubuntu is 22.04.1 which is up to date, i.e. dist-upgrade.
What might resolve the issue?
Display issue
Display issue
- Bildschirmfoto vom 2022-12-09 14-08-42.png (39.37 KiB) Viewed 928 times
Re: Display issue
First thing to try: Use 0.21 AppImage from https://github.com/FreeCAD/FreeCAD-AppI ... kly-builds.
- adrianinsaval
Re: Display issue
This usually a dpi issue, most often seen on xfce systems, check your font dpi settings and make sure it's set at 96
Re: Display issue
Indeed, this resolved the issue. Thank you!adrianinsaval wrote: ↑Fri Dec 09, 2022 10:39 pm This usually a dpi issue, most often seen on xfce systems, check your font dpi settings and make sure it's set at 96
Re: Display issue
Can you please formulate an entry for the Known OS specific issues?adrianinsaval wrote: ↑Fri Dec 09, 2022 10:39 pm This usually a dpi issue, most often seen on xfce systems, check your font dpi settings and make sure it's set at 96
- adrianinsaval
Re: Display issue
there is one already, first entry on the linux listchrisb wrote: ↑Sun Dec 11, 2022 6:04 pm Can you please formulate an entry for the Known OS specific issues?
Re: Display issue
Thanks for looking at it anyway.
