输出*.stl文件后,分辨率降低,请教如何解决?
Moderator: paullee
论坛规矩 / 論壇規矩 , 有用的资讯 / 有用的資訊
准备3D打印,可是发现输出*.stl文件后,分辨率降低,请教如何解决?
Re: 输出*.stl文件后,分辨率降低,请教如何解决?
If you need help from others, please help others understand what you need.
Please provide: version info, screenshot, sample file.
Thank you fc_tofu.
FreeCAD Ver. 0.18
This is the screenshot of .stl exported from the solid part.
You can see the arrowed part which is supposed to be a smooth circle, but the resolution was lowered once I did export file to .stl format that is not fit for 3D printing.
FreeCAD Ver. 0.18
- 屏幕快照 2020-05-12 上午10.57.48.png (31.36 KiB) Viewed 9492 times
You didnot give a sample file. So I use PartWB cylinder primitive as test example.
The topology of exported mesh is basically same as Rendering mode >Hiden line (Tesselation). The setup of tesselation is located at Pref >Part Design >Shape View >Maximun deviation. Default value is 0.5%, you can try a lower value, 0.1% or so, to get finer display/export.
This is very helpful. Problem resolved, thanks again fc_tofu.
fc_tofu wrote: ↑Tue May 12, 2020 5:14 amYou didnot give a sample file. So I use PartWB cylinder primitive as test example.
盡量用中文吧,讓其它人也可以明白和參予 ,中英夾雜也無妨
各位好,我有類似的問題,我在Tinkercad畫一物件,匯出stl後要列印但不夠平滑,所以才接觸freecad,我在fc匯入後然後依上述更改設定後,看起來並沒有變得更平滑,請問該如何解決呢? 謝謝。
*使用fc版本為0.19
*使用fc版本為0.19
