什么时候出for arm64cpu的0.19版呢
Chinese forum
Moderator: paullee
论坛规矩 / 論壇規矩 , 有用的资讯 / 有用的資訊
重要:寻求帮助之前,请先看看这里 /
重要:尋求幫助之前,請先看看這裡
另外,对论坛用户 友善!阅读FreeCAD 行为准则!
/ 另外,對論壇用戶 友善! 閱讀FreeCAD
行為準則
wywwy
Post by wywwy »
现在for arm64 linux的最新版本知道0.18,最新的0.19 appimage只支持x86的cpu
paullee
Re: 什么时候出for arm64cpu的0.19版呢
Post by paullee »
不知 有沒有 ?
@Realthunder 知道嗎 ?
realthunder wrote: Ping
realthunder
Post by realthunder »
-alex- wrote:ping
Hi Alex, is you arm64 build happens to be available for public to download? I think the OP is asking for upstream build.
Try Assembly3 with my custom build of FreeCAD at here.
-alex-
Post by -alex- »
realthunder wrote: Thu Jan 07, 2021 11:16 pm Hi Alex, is you arm64 build happens to be available for public to download? I think the OP is asking for upstream build.
Hi, no it is not planed sorry.
The original poster could try to compile FC by himself? I don't know his OS, but that's not so difficult on Linux, he should just follow the Compile_on_Linux instructions.
用户@wywwy可以尝试自己编译FC? 我不知道他的操作系统,但是在Linux上并不是那么困难,他应该遵循 Compile_on_Linux 的说明。
@wywwy:告诉我是否需要一些帮助来编译 FC 0.19.
88
wywwy
Post by wywwy »
我试用的是uos ,这是基于 debian 。我还没有编译过,不过我愿意尝试一下,能否提供一些这方面的教程呢。
-alex-
Post by -alex- »
wywwy wrote: Fri Jan 08, 2021 12:54 am 我试用的是uos ,这是基于 debian 。我还没有编译过,不过我愿意尝试一下,能否提供一些这方面的教程呢。
Google translation / 谷歌翻译
Sorry, late reply / 不好意思回复迟了:
Do this (Debian 10) / 这样做(Debian 10) :
1- Open a bash terminal / 打开bash终端:
2- Update the system / 更新系统 :
sudo apt-get update
sudo apt-get upgrade
3- Download the FreeCAD source code / 下载FreeCAD源代码 :
sudo apt install git
cd
git clone https://github.com/FreeCAD/FreeCAD.git freecad-source
4- Then install dependancies following Compile_on_Linux / 然后按照 Compile_on_Linux 安装依赖项 :
sudo apt install build-essential
libtool
lsb-release
cmake
cmake-gui
cmake-curses-gui
libboost-date-time-dev
libboost-dev
libboost-filesystem-dev
libboost-graph-dev
libboost-iostreams-dev
libboost-program-options-dev
libboost-python-dev
libboost-regex-dev
libboost-serialization-dev
libboost-signals-dev
libboost-thread-dev
libcoin-dev
libeigen3-dev
libgts-bin
libgts-dev
libkdtree++-dev
libmedc-dev
libocct-data-exchange-dev
libocct-ocaf-dev
libocct-visualization-dev
libopencv-dev
libproj-dev
libpyside2-dev
libqt5opengl5-dev
libqt5svg5-dev
libqt5webkit5-dev
libqt5x11extras5-dev
libqt5xmlpatterns5-dev
libshiboken2-dev
libspnav-dev
libvtk7-dev
libx11-dev
libxerces-c-dev
libzipios++-dev
occt-draw
pyside2-tools
python3-dev
python3-matplotlib
python3-pivy
python3-ply
python3-pyside2.qtcore
python3-pyside2.qtgui
python3-pyside2.qtsvg
python3-pyside2.qtwidgets
python3-pyside2uic
qtbase5-dev
qttools5-dev
swig
5- Create freecad-buid folder in you home/user directory or whatever, then compile the source code inside it / 在主目录/用户目录或任何其他目录中创建freecad-buid文件夹,然后在其中编译源代码 :
cd
mkdir freecad-build
cd freecad-build/
cmake ../freecad-source -DBUILD_QT5=ON -DPYTHON_EXECUTABLE=/usr/bin/python3 -DUSE_PYBIND11=ON
6- Compile / 编译 :
make -j$(nproc --ignore=2)
7- Run and enjoy FreeCAD / 运行并享受FreeCAD :
cd
cd freecad-build/bin/
./Freecad
Good luck / 祝好运 ;)
wywwy
Post by wywwy »
安装第三方依赖的时候,很多都无法定位啊,很多包无法定位,什么源可以都包含呢
felixlee868
Post by felixlee868 »
ARM 64位的版本,可能有些难度。如果你是使用 conda 这种科学计算软件环境,来安装 freecad, 一般情况下,freecad 应可以运行。但有些工具, 如 ccx 或 gmsh 等,可能会有问题。可能这些工具使用了 Intel 专用的硬件加速指令,但 ARM 64-bit 上没有相应的指令。
Apple MacBook M1 号称使用 Rosetta2 函数库来转译两个CPU 架构之间的区别,但经我实测,现在还没有宣称的那么好,还有好多软件工具有问题。
wywwy
Post by wywwy »
非常感谢 @-alex-,按照你的方法这次顺利地在华为鲲鹏920(arm构架)平台上编译0.20版的freecad,并正常运行。
wywwy
Post by wywwy »
-alex- wrote: Thu Jan 21, 2021 1:17 am
sudo apt-get update
cd
libtool
lsb-release
cmake
cmake-gui
cmake-curses-gui
libboost-dev
libboost-graph-dev
libboost-python-dev
libboost-regex-dev
libboost-thread-dev
libcoin-dev
libeigen3-dev
libgts-bin
libgts-dev
libkdtree++-dev
libmedc-dev
libocct-ocaf-dev
libopencv-dev
libproj-dev
libpyside2-dev
libqt5opengl5-dev
libqt5svg5-dev
libqt5webkit5-dev
libshiboken2-dev
libspnav-dev
libvtk7-dev
libx11-dev
libxerces-c-dev
libzipios++-dev
occt-draw
pyside2-tools
python3-dev
python3-matplotlib
python3-pivy
python3-ply
python3-pyside2uic
qtbase5-dev
qttools5-dev
swig
cd
mkdir freecad-build
cd freecad-build/
6- Compile / 编译 :
cd
./Freecad
Good luck / 祝好运 ;)
非常感谢,原先在uos 1030版本下,用你的方法没成功,升级到1040后再试了一次,很顺利就完成了,你的方法最简单.我还想请教一下,我如何打包成可以在别的机器上安装的deb安装包,或者appimage文件包呢?
