cut
Chinese forum
Moderator: paullee
论坛规矩 / 論壇規矩 , 有用的资讯 / 有用的資訊
重要:寻求帮助之前,请先看看这里 /
重要:尋求幫助之前,請先看看這裡
另外,对论坛用户 友善!阅读FreeCAD 行为准则!
/ 另外,對論壇用戶 友善! 閱讀FreeCAD
行為準則
邱映文
cut
Post by 邱映文 »
兩個body無法進行cut,請問是甚麼原因,謝謝
https://youtu.be/ssloBxxc4DY
1.FCStd
(142.41 KiB) Downloaded 154 times
paullee
Re: cut
Post by paullee »
邱映文 wrote: Sat Jun 05, 2021 12:38 pm 兩個body無法進行cut,請問是甚麼原因,謝謝
歡迎:)
你可以把檔案上載,讓其它人看清楚。我不用Part Design, 不知是否Revolution 出問題了。
你可以用英文說明一下嗎?
paullee
Re: cut
Post by paullee »
The OP is asking why Boolen Cut is not working (see Youtube Video) - see Pad001 is cutting by Revolution.
I do not use Part Design - wild guess : Not working because Revolution has error?
邱映文
Re: cut
Post by 邱映文 »
This is the first time I use this to post, I don’t know how to put the file
Re: cut
It is nonsense to cut a feature from another feaature of the same body. Instead of a cut he probably wants to use a subtractive feature.
邱映文
Re: cut
Post by 邱映文 »
1.FCStd
(142.41 KiB) Downloaded 163 times
邱映文
Re: cut
Post by 邱映文 »
paullee wrote: Sat Jun 05, 2021 12:54 pm
歡迎:)
你可以用英文說明一下嗎?
Re: cut
Moved to Chinese forum.
paullee
Re: cut
Post by paullee »
chrisb wrote: Sat Jun 05, 2021 1:00 pm It is nonsense to cut a feature from another feaature of the same body. Instead of a cut he probably wants to use a subtractive feature.
Thanks @chrisb for the hint. Though I do not use Part Design, playing around and trying a few features then seem get it.
邱映文 wrote: Sat Jun 05, 2021 1:09 pm 1.FCStd
@chrisb 提示 應直接用 Subtractive Feature.... 我亂試了10分鐘,發現用Grove,是這樣嗎?
1_ r.FCStd
(137.24 KiB) Downloaded 152 times
Screenshot from 2021-06-06 01-06-35.png (245.29 KiB) Viewed 5623 times
Screenshot from 2021-06-06 01-06-23.png (254.2 KiB) Viewed 5623 times
邱映文
Re: cut
Post by 邱映文 »
paullee wrote: Sat Jun 05, 2021 5:12 pm
1_ r.FCStd
Thank you paullee, I just succeeded with Grove, thank you very much!
