conda-packages for osx
looo
Postby looo » Sun Mar 03, 2019 3:00 pm
As we already had a conda-topic for windows and one for linux, I guess it's time to also create one for mac.
I am now a proud mac user (thanks to chris_b who send me a mac mini) and I am pretty happy with the experience so far. Some tests with FreeCAD showed that the 3d-view is a bit slower than on linux and windows (I also did some tests on a very recent mac (mac-book and a big imac) with similar results). But it works and it's definetly worth to push for updated libraries also for the mac.
So my first step on the mac was the setup of conda to build conda-packages locally. Actually it was pretty easy to get this done. But I didn't realy understand these instructions at first [1]. Thats why I added a section to the FreeCAD_Conda repository for this setup. In case anyone is intersted, please follow these instructions [2] and report back if it worked for you.
With this setup + a miniconda installation (+installing conda-build) it should be possible to create local conda-packages for osx.
[1] https://www.anaconda.com/utilizing-the- ... ibution-5/
[2] https://github.com/FreeCAD/FreeCAD_Cond ... ild.md#osx
Re: conda-packages for osx
Postby Kunda1 » Sun Mar 03, 2019 4:50 pm
Fantastic news!
@chrisb that was a very cool gesture. Much appreciation.
@looo appreciate your work on much needed OSX build
Postby chrisb » Sun Mar 03, 2019 5:17 pm
Good to see that the Mac is useful. Is it possible that you provide a TimeMachine image with the development environment installed? Then I can install that on the other MacMinis for further usage.
If you don't have access to several GB of webspace you could send me a memory stick.
looo
Postby looo » Mon Mar 04, 2019 8:44 am
chrisb wrote: Sun Mar 03, 2019 5:17 pm Good to see that the Mac is useful. Is it possible that you provide a TimeMachine image with the development environment installed? Then I can install that on the other MacMinis for further usage.
hmm, I can also provide a script to do this.
Postby chrisb » Mon Mar 04, 2019 9:35 am
looo wrote: Mon Mar 04, 2019 8:44 am
That would be even better, because it would not be dedicated to these MacMinis.
looo
Postby looo » Mon Mar 04, 2019 2:25 pm
#1 install miniconda
curl -L -O https://repo.continuum.io/miniconda/Miniconda3-latest-MacOSX-x86_64.sh
bash  Miniconda3-latest-MacOSX-x86_64.sh -b
rm Miniconda3-latest-MacOSX-x86_64.sh
#2 get MacOSX10.9.sdk
curl -L -O https://github.com/phracker/MacOSX-SDKs/releases/download/10.13/MacOSX10.9.sdk.tar.xz
tar -xvf MacOSX10.9.sdk.tar.xz -c /opt/
echo "CONDA_BUILD_SYSROOT:" > ~/conda_build_config.yaml
echo "   - /opt/MacOSX10.9.sdk  # [osx]" >> ~/conda_build_config.yaml
rm MacOSX10.9.sdk.tar.xz
#circle ci has the sdk in another place. This will result in some linking errors. Workaround by creating a symlink:
mkdir -p /Applications/Xcode-9.0.1.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/
ln -s /opt/MacOSX10.9.sdk /Applications/Xcode-9.0.1.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/
#3 update conda and install necessary tools
source ~/miniconda3/bin/activate root
conda-config --add channels conda-forge
conda update --all -y
conda install conda-build conda-forge-pinning conda-smithy anaconda-client -y
jmborer
Postby jmborer » Thu Mar 07, 2019 8:41 pm
May I ask why 10.9 is still used where 10.13 is available or did I miss something?
https://github.com/phracker/MacOSX-SDKs ... sdk.tar.xz
looo
Postby looo » Thu Mar 07, 2019 9:48 pm
I guess for backward compatibility. Maybe it's also possible to use a newer sdk. But we already seen difficulties creating packages on different ci's which used divverent versions of the sdk...
vectronic
Postby vectronic » Fri May 03, 2019 11:45 pm
After much hair-pulling, I realise there is correction to be made on this page:
add a file in the user-home-directory named conda-build-config.yaml containing these lines
should say:
add a file in the user-home-directory named conda_build_config.yaml containing these lines
i.e. the name of the config file needs to be with underscores, not hyphens....
looo
Postby looo » Sat May 04, 2019 6:33 am
Makes sense. Sry for the troubles.
