FreeCAD and Raspberry Pi 4
tiedemate
Re: FreeCAD and Raspberry Pi 4
Postby tiedemate » Thu Nov 21, 2019 6:03 pm
I tried to grab the output of the terminal. I don't know how to scroll up and access older output unfortunately, but maybe you can make anything out of it. (I can't use the terminal emulator in KDE because it's crashing all the time, so I have to use the Strg + Alt + F2 thing).
In any case good to hear there will likely be some activity directed towards the Pinebook Pro!
Best regards!
Bjoern
tty2.log
(15.7 KiB) Downloaded 15 times
tiedemate
Postby tiedemate » Thu Nov 21, 2019 6:48 pm
Here's a second try, I managed to capture an error scrolling through the screen, and then at the end the message is different from the first try.
Sorry that I can't be more specific, I've got zero experience compiling stuff...
Postby chrisb » Thu Nov 21, 2019 7:00 pm
You can redirect the output of stdout and stderr to a file. Such log output can be included directly in the post included in code tags </>. That makes reading easier.
tiedemate
Postby tiedemate » Fri Nov 22, 2019 12:46 pm
Very good hint, I still have a lot to learn, when it comes to Linux...
Here's the output of
cmake -DPYTHON_EXECUTABLE=/usr/bin/python2.7 \ -DPYTHON_INCLUDE_DIR=/usr/include/python2.7m \ -DPYTHON_LIBRARY=/usr/lib/arm-linux-gnueabihf/libpython2.7m.so \ -DPYTHON_PACKAGES_PATH=/usr/local/lib/python2.7/dist-packages/ ../freecad-source
-- The C compiler identification is GNU 9.2.1
-- The CXX compiler identification is GNU 9.2.1
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Compiler: GNU, version: 9.2.1
-- Looking for GL/gl.h
-- Looking for GL/gl.h - found
-- Looking for C++ include istream
-- Looking for C++ include istream - found
-- Looking for C++ include ostream
-- Looking for C++ include ostream - found
-- Looking for C++ include fstream
-- Looking for C++ include fstream - found
-- Looking for C++ include sstream
-- Looking for C++ include sstream - found
-- Looking for C++ include ios
-- Looking for C++ include ios - found
-- Looking for C++ include iostream
-- Looking for C++ include iostream - found
-- Looking for C++ include iomanip
-- Looking for C++ include iomanip - found
-- Check for STD namespace
-- Check for STD namespace - found
-- prefix: /usr/local
-- bindir: bin
-- datadir: share
-- docdir: share/doc/FreeCAD
-- includedir: include
-- libdir: lib
-- cmake: 3.13.4
-- Found PythonInterp: /usr/bin/python2.7 (found version "2.7.17")
-- Found PythonLibs: /usr/lib/arm-linux-gnueabihf/libpython2.7.so (found suitable exact version "2.7.17rc1")
-- Looking for pthread.h
-- Looking for pthread.h - found
-- Looking for pthread_create
-- Looking for pthread_create - not found
-- Looking for pthread_create in pthreads
-- Looking for pthread_create in pthreads - not found
-- Looking for pthread_create in pthread - found
-- Found Threads: TRUE
-- Boost version: 1.67.0
-- Found the following Boost libraries:
--   filesystem
--   program_options
--   regex
--   system
--   thread
--   chrono
--   date_time
--   atomic
-- Found Xerces-C: /usr/lib/arm-linux-gnueabihf/libxerces-c.so
-- Found ZLIB: /usr/lib/arm-linux-gnueabihf/libz.so (found version "1.2.11")
-- PyCXX found:
--   Headers:  /home/tiedemate/freecad-source/src
--   Sources:  /home/tiedemate/freecad-source/src/CXX
--   Version:  6.2.8
-- Found OCC: /usr/include/opencascade (found version "7.3.0")
-- -- Found OCE/OpenCASCADE version: 7.3.0
-- -- OCE/OpenCASCADE include directory: /usr/include/opencascade
-- -- OCE/OpenCASCADE shared libraries directory: /usr/lib/arm-linux-gnueabihf
-- The imported target "vtkGUISupportQt" references the file
   "/usr/lib/arm-linux-gnueabihf/libvtkGUISupportQt-7.1.so.7.1.1"
but this file does not exist.  Possible reasons include:
* The file was deleted, renamed, or moved to another location.
* An install or uninstall procedure did not complete successfully.
* The installation package was faulty and contained
   "/usr/lib/cmake/vtk-7.1/VTKTargets.cmake"
but not all the files it references.
-- The imported target "vtkGUISupportQtSQL" references the file
   "/usr/lib/arm-linux-gnueabihf/libvtkGUISupportQtSQL-7.1.so.7.1.1"
-- The imported target "vtkParseOGLExt" references the file
   "/usr/bin/vtkParseOGLExt-7.1"
-- The imported target "vtkRenderingPythonTkWidgets" references the file
   "/usr/lib/arm-linux-gnueabihf/libvtkRenderingPythonTkWidgets.so"
-- The imported target "vtk" references the file
   "/usr/bin/vtk"
-- The imported target "pvtk" references the file
   "/usr/bin/pvtk"
-- VTK components: vtkCommonCore;vtkCommonDataModel;vtkFiltersVerdict;vtkIOXML;vtkFiltersCore;vtkFiltersGeneral;vtkIOLegacy;vtkFiltersExtraction;vtkFiltersSources;vtkFiltersGeometry;vtkIOMPIParallel;vtkParallelMPI;vtkhdf5;vtkFiltersParallelDIY2;vtkRenderingCore;vtkInteractionStyle;vtkRenderingFreeType;vtkRenderingOpenGL2
-- Check for medfile (libmed and libmedc) ...
-- Found MEDFile: /usr/include
-- Found PkgConfig: /usr/bin/pkg-config (found version "0.29.1")
-- We guess that libmed was built using hdf5-openmpi version
-- Checking for one of the modules 'hdf5-openmpi'
-- Checking for one of the modules 'ompi-cxx'
-- Found SWIG: /usr/bin/swig3.0 (found version "3.0.12")
-- Found Eigen3: /usr/include/eigen3 (found suitable version "3.3.7", minimum required is "2.91.0")
-- Looking for Q_WS_X11
-- Looking for Q_WS_X11 - found
-- Looking for Q_WS_WIN
-- Looking for Q_WS_WIN - not found
-- Looking for Q_WS_QWS
-- Looking for Q_WS_QWS - not found
-- Looking for Q_WS_MAC
-- Looking for Q_WS_MAC - not found
-- Found Qt4: /usr/bin/qmake (found suitable version "4.8.7", minimum required is "4.5.0")
-- Found Freetype: /usr/lib/arm-linux-gnueabihf/libfreetype.so (found version "2.9.1")
-- Found OpenGL: /usr/lib/arm-linux-gnueabihf/libOpenGL.so
-- Found OpenGLU: /usr/lib/arm-linux-gnueabihf/libGLU.so
-- Checking for module 'Coin'
--   No package 'Coin' found
-- Coin3D libraries found
-- Found Spnav: /usr/lib/libspnav.so
-- Using default python: -python2.7
-- libshiboken built for Release
-- Found PySide Tools: /usr/bin/pyside-uic, /usr/bin/pyside-rcc
matplotlib not found, Plot module won't be available.
-- Platform is 32-bit
-- /home/tiedemate/freecad-build/src/Base/TypePy.cpp
-- /home/tiedemate/freecad-build/src/Base/BaseClassPy.cpp
-- /home/tiedemate/freecad-build/src/Base/BoundBoxPy.cpp
-- /home/tiedemate/freecad-build/src/Base/CoordinateSystemPy.cpp
-- /home/tiedemate/freecad-build/src/Base/PersistencePy.cpp
-- /home/tiedemate/freecad-build/src/Base/VectorPy.cpp
-- /home/tiedemate/freecad-build/src/Base/MatrixPy.cpp
-- /home/tiedemate/freecad-build/src/Base/RotationPy.cpp
-- /home/tiedemate/freecad-build/src/Base/PlacementPy.cpp
-- /home/tiedemate/freecad-build/src/Base/AxisPy.cpp
-- /home/tiedemate/freecad-build/src/Base/UnitPy.cpp
-- /home/tiedemate/freecad-build/src/Base/QuantityPy.cpp
-- /home/tiedemate/freecad-build/src/App/DocumentPy.cpp
-- /home/tiedemate/freecad-build/src/App/DocumentObjectPy.cpp
-- /home/tiedemate/freecad-build/src/App/ExtensionPy.cpp
-- /home/tiedemate/freecad-build/src/App/ExtensionContainerPy.cpp
-- /home/tiedemate/freecad-build/src/App/DocumentObjectExtensionPy.cpp
-- /home/tiedemate/freecad-build/src/App/GroupExtensionPy.cpp
-- /home/tiedemate/freecad-build/src/App/LinkBaseExtensionPy.cpp
-- /home/tiedemate/freecad-build/src/App/DocumentObjectGroupPy.cpp
-- /home/tiedemate/freecad-build/src/App/GeoFeaturePy.cpp
-- /home/tiedemate/freecad-build/src/App/GeoFeatureGroupExtensionPy.cpp
-- /home/tiedemate/freecad-build/src/App/OriginGroupExtensionPy.cpp
-- /home/tiedemate/freecad-build/src/App/PartPy.cpp
-- /home/tiedemate/freecad-build/src/App/ComplexGeoDataPy.cpp
-- /home/tiedemate/freecad-build/src/App/PropertyContainerPy.cpp
-- /home/tiedemate/freecad-build/src/App/MaterialPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Points/App/PointsPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Mesh/App/FacetPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Mesh/App/MeshFeaturePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Mesh/App/MeshPointPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Mesh/App/MeshPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Mesh/Gui/ViewProviderMeshPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/ArcPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/ArcOfConicPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/ArcOfCirclePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/ArcOfParabolaPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/BodyBasePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/ConicPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/CirclePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/ArcOfEllipsePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/EllipsePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/HyperbolaPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/ArcOfHyperbolaPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/ParabolaPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/OffsetCurvePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/GeometryPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/GeometryExtensionPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/GeometryIntExtensionPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/GeometryStringExtensionPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/GeometryBoolExtensionPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/GeometryDoubleExtensionPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/GeometryCurvePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/BoundedCurvePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/TrimmedCurvePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/GeometrySurfacePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/LinePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/LineSegmentPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/PointPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/BezierCurvePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/BSplineCurvePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/PlanePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/ConePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/CylinderPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/SpherePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/ToroidPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/BezierSurfacePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/BSplineSurfacePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/OffsetSurfacePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/PlateSurfacePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/RectangularTrimmedSurfacePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/SurfaceOfExtrusionPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/SurfaceOfRevolutionPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/PartFeaturePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/AttachExtensionPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/Part2DObjectPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/AttachEnginePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/TopoShapePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/TopoShapeCompoundPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/TopoShapeCompSolidPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/TopoShapeEdgePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/TopoShapeFacePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/TopoShapeShellPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/TopoShapeSolidPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/TopoShapeVertexPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/TopoShapeWirePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/BRepOffsetAPI_MakePipeShellPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/Geom2d/ArcOfCircle2dPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/Geom2d/ArcOfConic2dPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/Geom2d/ArcOfEllipse2dPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/Geom2d/ArcOfHyperbola2dPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/Geom2d/ArcOfParabola2dPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/Geom2d/BezierCurve2dPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/Geom2d/BSplineCurve2dPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/Geom2d/Circle2dPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/Geom2d/Conic2dPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/Geom2d/Ellipse2dPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/Geom2d/Geometry2dPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/Geom2d/Hyperbola2dPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/Geom2d/Curve2dPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/Geom2d/Line2dSegmentPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/Geom2d/Line2dPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/Geom2d/OffsetCurve2dPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Part/App/Geom2d/Parabola2dPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/PartDesign/App/BodyPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/PartDesign/App/FeaturePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/PartDesign/Gui/ViewProviderPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Sketcher/App/SketchObjectSFPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Sketcher/App/SketchObjectPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Sketcher/App/SketchGeometryExtensionPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Sketcher/App/ExternalGeometryExtensionPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Sketcher/App/ConstraintPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Sketcher/App/SketchPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Robot/App/Robot6AxisPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Robot/App/TrajectoryPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Robot/App/WaypointPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Robot/App/RobotObjectPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Import/App/StepShapePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Fem/App/FemMeshPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Fem/App/FemPostPipelinePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Fem/Gui/ViewProviderFemMeshPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Spreadsheet/App/SheetPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Spreadsheet/App/PropertySheetPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Spreadsheet/App/PropertyColumnWidthsPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Spreadsheet/App/PropertyRowHeightsPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Path/App/CommandPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Path/App/PathPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Path/App/ToolPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Path/App/TooltablePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Path/App/FeaturePathCompoundPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Path/App/AreaPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Path/App/FeatureAreaPy.cpp
-- setting gcc options: -Wall -Werror -Wno-deprecated -pedantic-errors
--   python27
-- found Boost: 1_67
-- boost-incude dirs are: /usr/include
-- boost-python lib is:
-- boost_LIBRARY_DIRS is: /usr/lib/arm-linux-gnueabihf
-- Boost_LIBRARIES is: /usr/lib/arm-linux-gnueabihf/libboost_python27.so
-- area module (for Path Workbench) will be installed to: lib
-- /home/tiedemate/freecad-build/src/Mod/Path/PathSimulator/App/PathSimPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/Measure/App/MeasurementPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/DrawPagePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/DrawViewPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/DrawViewPartPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/DrawViewSymbolPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/DrawTemplatePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/DrawParametricTemplatePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/DrawSVGTemplatePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/DrawViewClipPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/DrawViewDimensionPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/DrawViewDimExtentPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/DrawHatchPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/DrawGeomHatchPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/DrawViewCollectionPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/DrawProjGroupPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/DrawProjGroupItemPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/DrawViewAnnotationPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/DrawLeaderLinePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/DrawRichAnnoPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/GeomFormatPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/CenterLinePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/CosmeticEdgePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/CosmeticVertexPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/DrawTilePy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/DrawTileWeldPy.cpp
-- /home/tiedemate/freecad-build/src/Mod/TechDraw/App/DrawWeldSymbolPy.cpp
Created file /home/tiedemate/freecad-build/doc/freecad.qch
-- Found Doxygen: /usr/bin/doxygen (found version "1.8.13") found components:  doxygen missing components:  dot
-- Note: Doxygen docs will look better with graphviz's dot installed.
-- Coin3D doc is not installed
-- /home/tiedemate/freecad-build/src/Gui/DocumentPy.cpp
-- /home/tiedemate/freecad-build/src/Gui/PythonWorkbenchPy.cpp
-- /home/tiedemate/freecad-build/src/Gui/ViewProviderPy.cpp
-- /home/tiedemate/freecad-build/src/Gui/ViewProviderDocumentObjectPy.cpp
-- /home/tiedemate/freecad-build/src/Gui/WorkbenchPy.cpp
-- /home/tiedemate/freecad-build/src/Gui/SelectionObjectPy.cpp
-- /home/tiedemate/freecad-build/src/Gui/LinkViewPy.cpp
-- /home/tiedemate/freecad-build/src/Gui/ViewProviderLinkPy.cpp
-- /home/tiedemate/freecad-build/src/Gui/AxisOriginPy.cpp
Summary report
-- Build type:
-- Compiler:            /usr/bin/c++ (9.2.1)
-- Flags:               -Wall -Wextra -Wno-write-strings
-- Python:              [/usr/bin/python2.7] [-python2.7]
-- PCL:                 not enabled
-- pybind11:            not enabled
-- Boost:               106700
-- XercesC:             [/usr/lib/arm-linux-gnueabihf/libxerces-c.so] [/usr/include]
-- ZLIB:                1.2.11
-- PyCXX:               [/home/tiedemate/freecad-source/src]
-- OCC:                 7.3.0 [TKFillet;TKMesh;TKernel;TKG2d;TKG3d;TKMath;TKIGES;TKSTL;TKShHealing;TKXSBase;TKBin;TKBool;TKBO;TKCDF;TKBRep;TKTopAlgo;TKGeomAlgo;TKGeomBase;TKOffset;TKPrim;TKSTEP;TKSTEPBase;TKSTEPAttr;TKHLR;TKFeat]
-- SMESH:               build internal
--  MEDFile:            [/usr/lib/arm-linux-gnueabihf/libmedC.so] [/usr/include]
--  HDF5:               1.10.4
--  VTK:                7.1.1
-- NETGEN:              not enabled
-- SWIG:                3.0.12
-- Eigen3               3.3.7
-- Qt4:
-- QtWebKit:            found
-- Shiboken:            1.2.2 [/usr/include/shiboken]
-- PySide:              1.2.2 [/usr/include/PySide]
-- PySideTools:         [/usr/bin/pyside-uic] [/usr/bin/pyside-rcc]
-- Freetype:            2.9.1
-- OpenGLU:             /usr/lib/arm-linux-gnueabihf/libGLU.so [/usr/lib/arm-linux-gnueabihf/libGLU.so][/usr/include]
-- Coin3D:              [/usr/lib/arm-linux-gnueabihf/libCoin.so] [/usr/include]
-- SPNAV:               [/usr/lib/libspnav.so] [/usr/include]
-- Matplotlib:          not found
-- Rift:                not enabled (BUILD_VR)
-- Doxygen:             not found
Now run 'cmake --build /home/tiedemate/freecad-build' to build FreeCAD
-- Configuring done
-- Generating done
-- Build files have been written to: /home/tiedemate/freecad-build
I can't insert the output of the subsequent
make -j4
because it exceeds the character limit, so I attached it as a textfile.
Best regards!
Bjoern
output cmake make.zip
(123.96 KiB) Downloaded 17 times
ToniGil
Postby ToniGil » Wed Dec 11, 2019 11:10 am
MartijnD wrote:
Fri Oct 11, 2019 4:49 am
Hello All,
Hereby I can confirm a successful build on the Pi4. I used the source of 0.18.3. As far as I can see everything is working.
Here is my short list used for installing:
sudo apt install cmake build-essential libtool lsb-release swig libboost-dev libboost-date-time-dev libboost-filesystem-dev libboost-graph-dev libboost-iostreams-dev libboost-program-options-dev libboost-python-dev libboost-regex-dev libboost-serialization-dev libboost-signals-dev libboost-thread-dev libcoin-dev libeigen3-dev libgts-bin libgts-dev libkdtree++-dev libmedc-dev libopencv-dev libproj-dev libvtk6-dev libx11-dev libxerces-c-dev libzipios++-dev qt4-dev-tools libqt4-dev libqt4-opengl-dev libqtwebkit-dev libshiboken-dev libpyside-dev pyside-tools python-dev python-matplotlib python-pivy python-ply python-pyside libocct*-dev occt-draw libsimage-dev doxygen libcoin-doc dh-exec libspnav-dev
wget https://github.com/FreeCAD/FreeCAD/archive/0.18.3.zip
unzip 0.18.3.zip
mkdir freecad-build
cd freecad-build
make -j4
Hope it helps someone.
Best regards and keep up the good work!
Martijn
Hi Martijn,
First of all, thenk you for your great job making the solution readable for newbies with your step by step explanation.
I tried to install Freecad on my raspberry pi4 with your detail and I had an error in the step "cmake...."
CMake Error: The source directory "/home/pi/freecad-source" does not exist.
Then I changed the final text "../freecad-source" --> " "../FreeCAD-0.18.3/src" as I thought it could be an error or a text to replace with the correct path. I had a new error message:
/usr/bin/python2.7: can't open file '/home/pi/FreeCAD-0.18.3/src/src/Tools/SubWCRev.py': [Errno 2] No such file or directory
CMake Error at Build/CMakeLists.txt:18 (fc_copy_file_if_different):
Unknown CMake command "fc_copy_file_if_different".
Then I tried several stupid things with no results... I attach CMakeOutput.log.
Could you please help with this? Thanks in advance.
Toni Gil.
CMakeOutput.log
(45.84 KiB) Downloaded 9 times
Site Admin
Postby wmayer » Wed Dec 11, 2019 12:26 pm
make -j4
The build fails because of this error:
In file included from /usr/include/qt4/QtOpenGL/QGLContext:1,
from /home/tiedemate/freecad-build/src/QtOpenGL.h:48,
from /home/tiedemate/freecad-source/src/Gui/Application.cpp:49:
/usr/include/qt4/QtOpenGL/qgl.h:85:17: error: conflicting declaration 'typedef GLfloat GLdouble'
85 | typedef GLfloat GLdouble;
In file included from /home/tiedemate/freecad-source/src/Gui/InventorAll.h:31,
from /home/tiedemate/freecad-source/src/Gui/Application.cpp:27:
/usr/include/GL/gl.h:134:17: note: previous declaration as 'typedef double GLdouble'
134 | typedef double GLdouble; /* double precision float */
There is a conflicting type definition of GLdouble. The OpenGL lib defines it as double but Qt re-defines it as GLfloat.
Site Admin
Postby wmayer » Wed Dec 11, 2019 12:32 pm
The source directory you set in CMake is not /home/pi/FreeCAD-0.18.3/src but /home/pi/FreeCAD-0.18.3
ToniGil
Postby ToniGil » Thu Dec 12, 2019 9:36 am
Thanks wmayer for your response.
This way it worked and finally I could execute the last line. After 2hours and a half working, I arrived to prompt and I think it´s done.
Now I have a new problem: I was waiting to find an item in Raspi menu for Freecad but it's not. A new one appeared "openCASCADE" but no Freecad.
How do I execute the program?
Thanks in advance.
Toni Gil.
Site Admin
Postby wmayer » Thu Dec 12, 2019 9:55 am
Inside the build directory open the folder bin. There you will find the file "FreeCAD" which you must double-click.
ToniGil
Postby ToniGil » Thu Dec 12, 2019 10:10 am
Sorry for my newbieness and thanks so much!
It works!!!!!
