sudo apt-get install freecad
$ freecad
FreeCAD 0.18.4, Libs: 0.18.4R
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2019
During initialization the error No module named 'PyQt5' occurred in /usr/share/freecad/Mod/Tux/InitGui.py
Please look into the log file for further information
During initialization the error No module named 'PyQt5' occurred in /usr/share/freecad/Mod/Ship/InitGui.py
During initialization the error No module named 'PyQt5' occurred in /usr/share/freecad/Mod/Draft/InitGui.py
During initialization the error No module named 'PyQt5' occurred in /usr/share/freecad/Mod/Arch/InitGui.py
During initialization the error No module named 'PyQt5' occurred in /usr/share/freecad/Mod/Plot/InitGui.py
sudo apt-get install pyqt5-dev
sudo apt-get install pyqt5-dev-tools
libnglib.so: cannot open shared object file: No such file or directory
File "<string>", line 45, in Initialize
File "<string>", line 75, in Initialize
File "/usr/share/freecad/Mod/Path/PathScripts/PathGuiInit.py", line 69, in Startup
from PathScripts import PathSurfaceGui
File "/usr/share/freecad/Mod/Path/PathScripts/PathSurfaceGui.py", line 27, in <module>
import PathScripts.PathSurface as PathSurface
File "/usr/share/freecad/Mod/Path/PathScripts/PathSurface.py", line 28, in <module>
import MeshPart
You can also check if Netgen maesher is available from "Create mesh from shape..." in the Mesh design WB.
Netgen is missing
if I see your point (maybe I misunderstand), I would say it's not set:
cmake ../freecad-source -DBUILD_QT5=ON -DPYTHON_EXECUTABLE=/usr/bin/python3
Summary report
-- Build type:
-- Compiler: /usr/bin/c++ (9.3.0)
-- Flags: -Wall -Wextra -Wno-write-strings
-- Standard: Requires C++11
-- Python: [/usr/bin/python3] [.cpython-38-aarch64-linux-gnu]
-- PCL: not enabled
-- pybind11: not enabled
-- Boost: 1.71.0
-- XercesC: [/usr/lib/aarch64-linux-gnu/libxerces-c.so] [/usr/include]
-- ZLIB: 1.2.11
-- PyCXX: [/home/ubuntu/freecad-source/src]
-- OCC: 7.3.0 [TKFillet;TKMesh;TKernel;TKG2d;TKG3d;TKMath;TKIGES;TKSTL;TKShHealing;TKXSBase;TKBin;TKBool;TKBO;TKCDF;TKBRep;TKTopAlgo;TKGeomAlgo;TKGeomBase;TKOffset;TKPrim;TKSTEP;TKSTEPBase;TKSTEPAttr;TKHLR;TKFeat]
-- SMESH: build internal
-- MEDFile: [/usr/lib/aarch64-linux-gnu/libmedC.so] [/usr/include]
-- HDF5: 1.10.4
-- VTK: 7.1.1
-- NETGEN: not enabled
-- SWIG: 4.0.1
-- Eigen3 3.3.7
-- Qt5Core: 5.12.8
-- Qt5Network: 5.12.8
-- Qt5Xml: 5.12.8
-- Qt5XmlPatterns: 5.12.8
-- Qt5Widgets: 5.12.8
-- Qt5PrintSupport: 5.12.8
-- Qt5OpenGL: 5.12.8
-- Qt5Svg: 5.12.8
-- Qt5UiTools: 5.12.8
-- Qt5Concurrent: 5.12.8
-- Qt5WebKitWidgets: 5.212.0
-- Shiboken2: 5.14.0 [/usr/lib/aarch64-linux-gnu/cmake/Shiboken2-5.14.0] [/usr/include/shiboken2;/usr/include/python3.8]
-- PySide2: 5.14.0 [/usr/lib/../include/PySide2]
-- PySide2Tools: not found
-- Freetype: 2.10.1
-- OpenGLU: /usr/lib/aarch64-linux-gnu/libGLU.so [/usr/lib/aarch64-linux-gnu/libGLU.so][/usr/include]
-- Coin3D: [/usr/lib/aarch64-linux-gnu/libCoin.so] [/usr/include]
-- SPNAV: [/usr/lib/libspnav.so] [/usr/include]
-- Matplotlib: 3.1.2
-- Rift: not enabled (BUILD_VR)
-- Doxygen: not found
Now run 'cmake --build /home/ubuntu/freecad-build' to build FreeCAD
I think its here: https://salsa.debian.org/science-team/f ... /rules#L15
after installing:sgrogan wrote: ↑Tue May 05, 2020 11:10 pmIf thats correct you need the netgen and netgen-headers packages https://salsa.debian.org/science-team/f ... rol#L49-50
sudo apt-get install netgen
sudo apt-get install netgen-headers
I try to compile but no success:
ubuntu@ubuntu:~$ sudo apt install cmake cmake-gui libboost-date-time-dev libboost-dev libboost-filesystem-dev libboost-graph-dev libboost-iostreams-dev libboost-program-options-dev libboost-python-dev libboost-regex-dev libboost-serialization-dev libboost-signals-dev libboost-thread-dev libcoin-dev libeigen3-dev libgts-bin libgts-dev libkdtree++-dev libmedc-dev libocct-data-exchange-dev libocct-ocaf-dev libocct-visualization-dev libopencv-dev libproj-dev libpyside2-dev libqt5opengl5-dev libqt5svg5-dev libqt5webkit5-dev libqt5x11extras5-dev libqt5xmlpatterns5-dev libshiboken2-dev libspnav-dev libvtk7-dev libx11-dev libxerces-c-dev libzipios++-dev occt-draw pyside2-tools python3-dev python3-matplotlib python3-pivy python3-ply python3-pyside2.qtcore python3-pyside2.qtgui python3-pyside2.qtsvg python3-pyside2.qtwidgets python3-pyside2uic qtbase5-dev qttools5-dev swig
Reading package lists... Done
Building dependency tree
Reading state information... Done
Note, selecting 'cmake-qt-gui' instead of 'cmake-gui'
E: Unable to locate package libboost-signals-dev
E: Unable to locate package python3-pyside2uic
ubuntu@ubuntu:~$
Performing C SOURCE FILE Test CMAKE_HAVE_LIBC_PTHREAD failed with the following output:
Change Dir: /home/ubuntu/freecad-build/CMakeFiles/CMakeTmp
Run Build Command(s):/usr/bin/make cmTC_b510b/fast && /usr/bin/make -f CMakeFiles/cmTC_b510b.dir/build.make CMakeFiles/cmTC_b510b.dir/build
make[1]: Entering directory '/home/ubuntu/freecad-build/CMakeFiles/CMakeTmp'
Building C object CMakeFiles/cmTC_b510b.dir/src.c.o
/usr/bin/cc -DCMAKE_HAVE_LIBC_PTHREAD -o CMakeFiles/cmTC_b510b.dir/src.c.o -c /home/ubuntu/freecad-build/CMakeFiles/CMakeTmp/src.c
Linking C executable cmTC_b510b
/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_b510b.dir/link.txt --verbose=1
/usr/bin/cc -DCMAKE_HAVE_LIBC_PTHREAD -rdynamic CMakeFiles/cmTC_b510b.dir/src.c.o -o cmTC_b510b
/usr/bin/ld: CMakeFiles/cmTC_b510b.dir/src.c.o: in function `main':
src.c:(.text+0x48): undefined reference to `pthread_create'
/usr/bin/ld: src.c:(.text+0x50): undefined reference to `pthread_detach'
/usr/bin/ld: src.c:(.text+0x5c): undefined reference to `pthread_join'
make[1]: *** [CMakeFiles/cmTC_b510b.dir/build.make:87: cmTC_b510b] Error 1
make[1]: Leaving directory '/home/ubuntu/freecad-build/CMakeFiles/CMakeTmp'
make: *** [Makefile:121: cmTC_b510b/fast] Error 2
Source file was:
#include <pthread.h>
void* test_func(void* data)
return data;
int main(void)
pthread_t thread;
pthread_create(&thread, NULL, test_func, NULL);
pthread_detach(thread);
pthread_join(thread, NULL);
pthread_atfork(NULL, NULL, NULL);
pthread_exit(NULL);
return 0;
Determining if the function pthread_create exists in the pthreads failed with the following output:
Run Build Command(s):/usr/bin/make cmTC_372ae/fast && /usr/bin/make -f CMakeFiles/cmTC_372ae.dir/build.make CMakeFiles/cmTC_372ae.dir/build
Building C object CMakeFiles/cmTC_372ae.dir/CheckFunctionExists.c.o
/usr/bin/cc -DCHECK_FUNCTION_EXISTS=pthread_create -o CMakeFiles/cmTC_372ae.dir/CheckFunctionExists.c.o -c /usr/share/cmake-3.16/Modules/CheckFunctionExists.c
Linking C executable cmTC_372ae
/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_372ae.dir/link.txt --verbose=1
/usr/bin/cc -DCHECK_FUNCTION_EXISTS=pthread_create -rdynamic CMakeFiles/cmTC_372ae.dir/CheckFunctionExists.c.o -o cmTC_372ae -lpthreads
/usr/bin/ld: cannot find -lpthreads
make[1]: *** [CMakeFiles/cmTC_372ae.dir/build.make:87: cmTC_372ae] Error 1
make: *** [Makefile:121: cmTC_372ae/fast] Error 2
How about FEM and Path?
