FreeCAD and Raspberry Pi 4
grayarea56
Raspberry Pi 4 and Segmentation Fault
Postby grayarea56 » Sat Oct 12, 2019 5:36 pm
Hi all,
I'm new to FreeCad, and I'm starting to love it!
I'm using it on my Desktop (windows) and it works perfect.
At night, I sometimes like to work from my Raspberry Pi 4.
I installed FreeCad version 0.18R
I'm using Raspbian.
I can run it, then if I click the "New" button I get the Segmentaion Fauilt.
I've searched the forum, many others have had this problem with the PI4.
I was wondering if there is a solution out there?
Dan Gray
Reason: Merged thread in to larger topic
Site Admin
Re: Raspberry Pi 4 and Segmentation Fault
Postby wmayer » Sat Oct 12, 2019 7:20 pm
https://forum.freecadweb.org/viewtopic. ... 60#p339874
At the moment the combination of Py2/Qt4 and presumably Py3/Qt4 works but Py3/Qt5 causes problems. I have no idea if this is something we can manage to get it working.
-alex-
Re: FreeCAD and Raspberry Pi 4
Postby -alex- » Sun Oct 13, 2019 2:35 pm
easyw-fc wrote:
Fri Oct 11, 2019 3:22 pm
vocx wrote:
Wed Oct 09, 2019 10:59 pm
Unfortunately, Python 2 is going to become unsupported very soon
An option could be to build for Qt4 & Py3.
I have compiled Freecad Py3:Qt4 build, and that works, I mean I can create a new file and some body in Part design for eg.
But I get some warning messages about Pyside and so on.
I have remove old freecad-build directory, then created a new one. Then:
pi@raspberrypi:~/freecad-build $ cmake  -DPYTHON_EXECUTABLE=/usr/bin/python3 -DCMAKE_BUILD_TYPE=Debug ../freecad-source
pi@raspberrypi:~/freecad-build $ make -j4
For exemple, while running Freecad, then creating a body (see picture below), thern closing Freecad, I got this messages in terminal:
pi@raspberrypi:~/freecad-build/bin $ ./FreeCAD
FreeCAD 0.19, Libs: 0.19R18504 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2019
During initialization the error "No module named 'PySide'" occurred in /home/pi/freecad-build/Mod/Tux/InitGui.py
Please look into the log file for further information
During initialization the error "No module named 'PySide'" occurred in /home/pi/freecad-build/Mod/Arch/InitGui.py
During initialization the error "No module named 'PySide'" occurred in /home/pi/freecad-build/Mod/AddonManager/InitGui.py
During initialization the error "No module named 'PySide'" occurred in /home/pi/freecad-build/Mod/Draft/InitGui.py
CommandManager::addTo() try to add an unknown command (Std_AddonMgr) to a widget!
  File "<string>", line 2, in <module>
  File "/home/pi/freecad-build/Mod/Start/StartPage/StartPage.py", line 29, in <module>
    from . import TranslationTexts
  File "/home/pi/freecad-build/Mod/Start/StartPage/TranslationTexts.py", line 24, in <module>
    from PySide import QtGui
<class 'ModuleNotFoundError'>: No module named 'PySide'
connect failed: No such file or directory
CommandManager::addTo() try to add an unknown command (PartDesign_InvoluteGear) to a widget!
X Error: BadWindow (invalid Window parameter) 3
  Major opcode: 31 (X_GrabKeyboard)
  Resource id:  0x0
  Resource id:  0x0
  Resource id:  0x0
  Resource id:  0x0
  Resource id:  0x0
  Resource id:  0x0
OS: Raspbian GNU/Linux 10 (buster) (LXDE/LXDE-pi)
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Version: 0.19.18504 (Git)
Build type: Debug
Hash: f66023a646db4b2502bb3637897443b3525ca3c7
Python version: 3.7.3
-alex-
Postby -alex- » Sun Oct 13, 2019 2:43 pm
vocx wrote:
Sat Oct 12, 2019 3:33 pm
Yes, it's fine to compile against 0.18, however, 0.19 is in active development and it brings so many new features over 0.18, that it would be great to make it work as well. Right now a 0.18 version is great to have, but in a few months, when 0.19 is ready to become the next stable version, it would be good to offer it as well in Raspbian, even in a Py2/Qt4 combination, but preferably with Py3/Qt5.
I agree 100%. Maybe we could even offer a Py3:Qt4 in Raspbian, if no warnings messages (see my previous post above, maybe I did something wrong or some libs are still missing, or ...?).
If I were to test things, I would probably only enable Part and Start.
There are other modules like Tux, Import, and AddonManager. These aren't proper workbenches, but rather they provide internal support for certain options of FreeCAD, such as the mouse navigation, and the import system. I would leave these enabled as well. That is, I would only disable those that are accessible through the workbench selector.
Thanks for informations, I will try again.
Site Admin
Postby wmayer » Sun Oct 13, 2019 3:10 pm
For Qt4 there should be a PySide and shiboken package that offer Python modules that can be imported at runtime. When installing them the warning should go away.
Without these modules the Tux wb doesn't load and the Path and FEM wb don't work 100% either.
Site Admin
Postby wmayer » Sun Oct 13, 2019 4:06 pm
The whole issue is it possible that's about OpenGL vs. OpenGL ES?
kkremitzki
Postby kkremitzki » Sun Oct 13, 2019 5:32 pm
That's one thing I have been suspecting, yes.
clicky
Postby clicky » Sun Oct 13, 2019 8:05 pm
:) Brilliant. Thank you for all your effort. It is working now for me, too. I did what you said (and got to the same state with PySide errors, etc).
Funny thing was that by running KDE with some 'dark colour theme' I had problem with fonts not showing (well - faint on very right) - but that's completely different problem and not that important.
grayarea56
Postby grayarea56 » Mon Oct 14, 2019 9:34 am
MartijnD wrote:
Fri Oct 11, 2019 4:49 am
Hello All,
Hereby I can confirm a successful build on the Pi4. I used the source of 0.18.3. As far as I can see everything is working.
Hope it helps someone.
\\est regards and keep up the good work!
Martijn
It helped me! I was able to make the 0.18.3, and it works on my PI 4!!!!
Thanks everyone!
Dan Gray
clicky
Postby clicky » Mon Oct 14, 2019 11:50 am
Oh, well - top of the master (as of yesterday) in this combination has an issue with loading files saved by itself. I can easily load files saved by version I have on my Mac, but trying to load version of FCStd file I've saved yesterday results with SIGSEGV :(
#0  /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer+0) [0xb02d9120]
I'll give it a go with some older version...
