old TempoVis.py in recent builds
sgrogan
Re: old TempoVis.py in recent builds
Postby sgrogan » Fri Oct 04, 2019 10:14 pm
kkremitzki wrote:
Fri Oct 04, 2019 10:02 pm
I removed those because, in my testing trying to fix the builds, I was getting errors about them not being present. There's a bug somewhere screwing with all this.
@kkremitzki, can you try this?
usr/share/freecad-daily/Ext/freecad/*.py
usr/share/freecad-daily/Ext/PySide/*.py
usr/share/freecad-daily/Mod/AddonManager/*.py
usr/share/freecad-daily/Mod/AddonManager/*.ui
usr/share/freecad-daily/Mod/Arch/Dice3DS/*.py
usr/share/freecad-daily/Mod/Arch/Presets/*.json
usr/share/freecad-daily/Mod/Arch/Presets/*.csv
usr/share/freecad-daily/Mod/Arch/*.py
usr/share/freecad-daily/Mod/Complete/*.py
usr/share/freecad-daily/Mod/Draft/*.py
usr/share/freecad-daily/Mod/Fem/*.py
usr/share/freecad-daily/Mod/Fem/femexamples/*.py
usr/share/freecad-daily/Mod/Fem/femexamples/meshes/*.py
usr/share/freecad-daily/Mod/Fem/femguiobjects/*.py
usr/share/freecad-daily/Mod/Fem/feminout/*.py
usr/share/freecad-daily/Mod/Fem/femmesh/*.py
usr/share/freecad-daily/Mod/Fem/femobjects/*.py
usr/share/freecad-daily/Mod/Fem/femresult/*.py
usr/share/freecad-daily/Mod/Fem/femsolver/*.py
usr/share/freecad-daily/Mod/Fem/femsolver/calculix/*.py
usr/share/freecad-daily/Mod/Fem/femsolver/elmer/*.py
usr/share/freecad-daily/Mod/Fem/femsolver/elmer/equations/*.py
usr/share/freecad-daily/Mod/Fem/femsolver/fenics/*.py
usr/share/freecad-daily/Mod/Fem/femsolver/z88/*.py
usr/share/freecad-daily/Mod/Fem/femtest/*.py
usr/share/freecad-daily/Mod/Fem/femtools/*.py
usr/share/freecad-daily/Mod/Fem/Resources/ui/*.ui
usr/share/freecad-daily/Mod/Idf/*.py
usr/share/freecad-daily/Mod/Image/*.py
usr/share/freecad-daily/Mod/Image/ImageTools/*.py
usr/share/freecad-daily/Mod/Import/*.py
usr/share/freecad-daily/Mod/Inspection/*.py
usr/share/freecad-daily/Mod/Material/materialtools/*.py
usr/share/freecad-daily/Mod/Material/*.py
usr/share/freecad-daily/Mod/Material/*.ui
usr/share/freecad-daily/Mod/Measure/*.py
usr/share/freecad-daily/Mod/Mesh/*.py
usr/share/freecad-daily/Mod/MeshPart/*.py
usr/share/freecad-daily/Mod/OpenSCAD/*.py
usr/share/freecad-daily/Mod/Part/*.py
usr/share/freecad-daily/Mod/Part/AttachmentEditor/*.py
usr/share/freecad-daily/Mod/Part/AttachmentEditor/*.ui
usr/share/freecad-daily/Mod/Part/BOPTools/*.py
usr/share/freecad-daily/Mod/Part/CompoundTools/*.py
usr/share/freecad-daily/Mod/Part/BasicShapes/*.py
usr/share/freecad-daily/Mod/PartDesign/*.py
usr/share/freecad-daily/Mod/PartDesign/*.ui
usr/share/freecad-daily/Mod/PartDesign/Scripts/*.py
usr/share/freecad-daily/Mod/PartDesign/fcgear/*.py
usr/share/freecad-daily/Mod/PartDesign/PartDesignTests/*.py
usr/share/freecad-daily/Mod/PartDesign/WizardShaft/*.py
usr/share/freecad-daily/Mod/Path/*.py
usr/share/freecad-daily/Mod/Path/PathScripts/*.py
usr/share/freecad-daily/Mod/Path/PathScripts/post/*.py
usr/share/freecad-daily/Mod/Path/PathTests/*.py
usr/share/freecad-daily/Mod/Points/*.py
usr/share/freecad-daily/Mod/Raytracing/Init.py
usr/share/freecad-daily/Mod/Raytracing/InitGui.py
#usr/share/freecad-daily/Mod/Raytracing/RaytracingExample.py
usr/share/freecad-daily/Mod/ReverseEngineering/*.py
usr/share/freecad-daily/Mod/Robot/*.py
usr/share/freecad-daily/Mod/Show/*.py
usr/share/freecad-daily/Mod/Show/SceneDetails/*.py
usr/share/freecad-daily/Mod/Sketcher/Init.py
usr/share/freecad-daily/Mod/Sketcher/InitGui.py
usr/share/freecad-daily/Mod/Sketcher/Profiles.py
#usr/share/freecad-daily/Mod/Sketcher/SketcherExample.py
usr/share/freecad-daily/Mod/Sketcher/TestSketcherApp.py
usr/share/freecad-daily/Mod/Sketcher/TestSketcherGui.py
usr/share/freecad-daily/Mod/Sketcher/ProfileLib/*.py
usr/share/freecad-daily/Mod/Spreadsheet/*.py
usr/share/freecad-daily/Mod/Spreadsheet/Resources/icons/*.svg
usr/share/freecad-daily/Mod/Start/*.py
usr/share/freecad-daily/Mod/Start/StartPage/*.py
usr/share/freecad-daily/Mod/Surface/*.py
usr/share/freecad-daily/Mod/TechDraw/TDTest/*.py
usr/share/freecad-daily/Mod/Test/*.py
usr/share/freecad-daily/Mod/Tux/*.py
usr/share/freecad-daily/Mod/Web/*.py
Note the two commented files, they are examples and are not allowed?
vocx
Postby vocx » Fri Oct 04, 2019 11:34 pm
I just wanted to note something about Arch files.
The Dice3D and Preset files are in the source directory
source-dir/src/Mod/Arch/Dice3D
source-dir/src/Mod/Arch/Preset
Once I compile the source, they end up here
build-dir/Mod/Arch/Dice3DS/
build-dir/data/Mod/Arch/Presets
The Dice3DS files are Python files (module to be imported), while the Presets are .json and .csv (just information, no code).
The debian/freecad-daily-runtime.install seems to place them in the same usr/share directory, is this the proper way? Or should data and code be separate?
usr/share/freecad-daily/Mod/Arch/Dice3DS/dom3ds.py
usr/share/freecad-daily/Mod/Arch/Dice3DS/__init__.py
usr/share/freecad-daily/Mod/Arch/Dice3DS/util.py
usr/share/freecad-daily/Mod/Arch/Presets/ifc_products_IFC2X3.json
usr/share/freecad-daily/Mod/Arch/Presets/ifc_products_IFC4.json
sgrogan
Postby sgrogan » Fri Oct 04, 2019 11:59 pm
This seems to be handled by the rules file https://salsa.debian.org/science-team/f ... /rules#L17
My question is this a FreeCAD CMake thing , or are there different requirements for different distro's?
The PPA (and I think most distro's) is packaged from the install target.
kkremitzki
Postby kkremitzki » Sat Oct 05, 2019 12:27 am
That was the idea with the distinction between freecad-runtime and freecad-common files, with freecad-runtime being meant to solely have Python files. But there's no need for that, in retrospect, so eventually I'll combine the two and just have freecad-common, I think. With 0.19 there will be a break in the binary packages, i.e. libfreecad-python3-0.18 will have its name changed, so that would be a good time to do it.
openBrain
Postby openBrain » Wed Oct 09, 2019 2:50 pm
Updated today with daily build of 2019/10/08 and got this when I open a file : ;)
<string>(2)<class 'ModuleNotFoundError'>: No module named 'Show.TempoVis'
DeepSOIC
Postby DeepSOIC » Wed Oct 09, 2019 3:18 pm
If the file was saved while you were editing a sketch, that's to be expected. Just ignore.
openBrain
Postby openBrain » Wed Oct 09, 2019 3:21 pm
Don't know as this is a file from the forum. :) Anyway thanks for explanation.
Still can be better if the error message is a bit more "comprehensive". ;)
DeepSOIC
Postby DeepSOIC » Wed Oct 09, 2019 3:27 pm
Well, it's tricky. TempoVis instance is saved as a property of a sketch when a sketch is open, and FreeCAD will save that property to a file, and point to the class as a module name + class name combo to later restore the object. However, TempoVis.py was renamed into mTempoVis.py, so FreeCAD fails to find that TempoVis.py when loading the project, so this is a totally all-right error message. FreeCAD has no idea about what TempoVis is, this loading mechanism is general.
The error should go away after resaving the project.
