Freecad 0.19 python3.7
Hello forum I'm using Freecad 0.19 with python3.7...,I'm having a problem getting blender to use Freecad.pyd in the add-on preference for blender. I won't lie I located the file which is" D:\New folder\Library\bin\FreeCAD.pyd"
But when I import a Freecad model it says "unable to import Freecad"thanks in advanced
Re: Freecad 0.19 python3.7
I think you have the same problem as here:https://forum.freecadweb.org/viewtopic.php?t=30465
i.e. Freecad's and Blender's Python don't match.
I think the easiest option now is to use FreeCAD 0.18.4 because its built with Python 3.6
"fight the good fight"
For me, the exact Blender and it's Python version number are not quoted. So to assist here's my working config with recent alpha Blender, note you don't put the FreeCAD.pyd in the Blender FreeCAD Importer AddOn config, just the folder:
Blender v2.83.11
Python 3.7.4
FreeCAD Importer Addon Locator
C:\Program Files\FreeCAD\bin\
OS: Windows 7 SP 1 (6.1)
Version: 0.19.18533 (Git)
Hash: a785660f596616ec058fc0efccf5be737e8abaaf
Python version: 3.7.3
Qt version: 5.12.1
Blender v2.83.11
Python 3.7.4
Qt version: 5.12.1
Thank for the replysgrogan wrote: ↑Wed Apr 22, 2020 10:58 amI think you have the same problem as here:https://forum.freecadweb.org/viewtopic.php?t=30465
I'm using blended 2.80 and it has python 3.7
And My Freecad has python 3.7
I've tried yorik methods and still I have no progress
In blender python console
>import sys
>sys.path.append.(D:\New folder\Library\bin\FrreeCAD.pyd")
File"<blender_console>", line 1
SyntaxError:(Unicode error) 'unicodeescape' codec can't decode bytes in position 2-3:malformed \N character escape
>import FeeeCAD
Trackback(most recent call last):
File"<blender_console>",Line 1 ,in <module>
ImportError:DLL load failed : %1 is not a valid Win32 application
That what I get when do so on the blender console
Thanks for the replySyres wrote: ↑Wed Apr 22, 2020 11:23 am For me, the exact Blender and it's Python version number are not quoted. So to assist here's my working config with recent alpha Blender, note you don't put the FreeCAD.pyd in the Blender FreeCAD Importer AddOn config, just the folder:
Blender v2.83.11
Python 3.7.4
Qt version: 5.12.1
Is that the latest blender version?
missing quote?
>sys.path.append.("D:\New folder\Library\bin\FrreeCAD.pyd")
Never noticed that I skip it when I was typing to you ..besides that I did it with the quote in the blender console but it gave me those errors
>import sys
>sys.path.append.("D:\New folder\Library\bin\FreeCAD.pyd")
SyntaxError: invalid syntax
2.83 is the latest Beta but 2.90 is the new Alpha. Below is the exact procedure I followed to move up to a new version, I don't have any path modifications to 'hack' the locator setting and there should be no need for it.
1) Browse to https://builder.blender.org/download/
I would recommend downloading 2.83 Beta - it's very stable (1200 bugs fixed in the past few months) and has some excellent features such as the Intel Denoiser in the Compositor and big sculpting improvements. Demonstration of the Intel Denoiser available here https://www.youtube.com/watch?v=wbpMNr0 ... e=emb_logo
2) Extract the zip file to a location of your choice, you'll ned to make a shortcut on your Desktop manually as it's just a portable build.
3) Download a current FreeCAD Importer, I personally use @s-light's which was forked from @yorik's last year
Browse to https://github.com/s-light/io_import_fcstd
from the Clone or Download, Download ZIP but do not extract it
4) Start Blender 2.83
You'll get a one-off Start screen and click Load 2.80 Settings which will bring everything across
5) Click Edit Menu > Preferences, AddOns button/tab
At this point I would recommend removing the existing FreeCAD importer by expanding it in the list of AddOns and clicking the Remove button and click OK
6) Close the Preferences Window, close without saving and restart Blender 2.83
Click Edit Menu > Preferences, AddOns button/tab, click the Install button and navigate to the zip file of the importer downloaded earlier
click Install AddOn button
Tick the Active checkbox and expand the FreeCAD Importer properties
Copy and Paste the folder as below into the Path to FreeCAD lib text box
8) Try importing a simple FreeCAD file, the settings I use with Millimetres set as my default Units is:
Good luck
Thanks for the reply again SyresSyres wrote: ↑Thu Apr 23, 2020 11:48 am2.83 is the latest Beta but 2.90 is the new Alpha. Below is the exact procedure I followed to move up to a new version, I don't have any path modifications to 'hack' the locator setting and there should be no need for it.
7) Close the Preferences WindowCode: Select all
FreeCADImporterSettings.
Good luck
I will noify you later on the progress
Thanks syres i successfully completed the task Iam able to import freecad project into blender 2.83 ,thanks to your knowledge
I really aprieciate it .
