[WIP] updating to netgen 6.2.2004 (was smesh windows problem)
looo
Postby looo » Sun Apr 26, 2020 4:49 pm
Maybe someone can give me a hint what this means. I tried to rerun the smesh windows build.
error LNK2019: unresolved external symbol __imp_gethostname referenced in function "class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > __cdecl GetHostname(void)" (?GetHostname@@YA?AV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@XZ)
SMESHMisc.dll : fatal error LNK1120: 1 unresolved externals
sgrogan
Re: windows smesh: unresolved external symbol __imp_gethostname
Postby sgrogan » Sun Apr 26, 2020 5:18 pm
Maybe this offers a hint?
https://www.experts-exchange.com/questi ... ame-8.html
Hi ,
you'll have to link with Ws2_32.lib ... simply open 'Project->Settings' dialog, select 'Link'-tab
and add Ws2_32.lib to 'Object/library modules'.
hope that helps,
ZOPPO
https://developercommunity.visualstudio ... -c-in.html
triplus
Postby triplus » Sun Apr 26, 2020 6:38 pm
Sometimes on Linux such outcome signals a borked build, starting fresh usually helps.
looo
Postby looo » Sun Apr 26, 2020 6:51 pm
Already tried 3 times. I guess it's a problem of VisualStudio setup on azure or it is related to the used compiler-package. The update I wanted to make is not very important. Only pinning netgen tightly to smesh to make sure smesh doesn't pull a newer version of netgen if we update netgen. I tried updating netgen recently (6.2.1808 ->6.2.2004) but netgen changed the interface which makes smesh incompatible...
triplus
Postby triplus » Sun Apr 26, 2020 8:52 pm
I guess the question is why are we talking about a 32 bit network oriented library in the first place. I would say try what @sgrogan suggested if you have "settings dialog" at your disposal? Reading this:
Ensure that the build environment links to the Winsock Library file Ws2_32.lib.
https://docs.microsoft.com/en-us/window ... pplication
This is therefore indeed what is likely missing. If the actual file is missing, then it is likely a part or some SDK, or you would need to define ws2_32.lib somewhere, as a dependency. Just guessing, as i have no experience with such toolchain.
triplus
Postby triplus » Sun Apr 26, 2020 8:57 pm
If you have a chance to install "Desktop development with C++" workload, do that. As maybe the mentioned library will be a part of that workload.
looo
Re: [solved] windows smesh: unresolved external symbol __imp_gethostname
Postby looo » Mon Apr 27, 2020 8:27 am
Hi ,
hope that helps,
ZOPPO
You were right. It seems like the library was linked in automatically previously but this has changed. The build is fixed with this little patch:
https://github.com/conda-forge/smesh-fe ... nker.patch
triplus
Postby triplus » Mon Apr 27, 2020 10:29 am
Great!
looo
Postby looo » Mon Apr 27, 2020 4:33 pm
question to the c++ experts:
Netgen has changed the interface to this:
geo->SetOCCParameters(occparam);
auto mesh = make_shared<Mesh>();
geo->GenerateMesh(mesh, mp);
mesh->SetGeometry(geo);
SetGlobalMesh(mesh);
which previously looked like this:
DLL_HEADER extern int OCCGenerateMesh(OCCGeometry&, shared_ptr<Mesh>&, MeshingParameters&);
Whats the easiest way to align to the new interface? Does it make sense? Or should we use the python bindings they provide to interface the meshing functionality?
Site Admin
Postby wmayer » Tue Apr 28, 2020 8:44 am
An option might be to add an implementation of OCCGenerateMesh to NETGENPlugin_Mesher.cxx in order to reduce the amount of changes. It could look like this:
int OCCGenerateMesh(OCCGeometry& geo, shared_ptr<Mesh>& mesh, MeshingParameters& mp)
    auto value = geo.GenerateMesh(mesh, mp);
    return value;
I wouldn't do that because it could become quite inefficient because the functions which call OCCGenerateMesh can be invoked many times.
Is SetOCCParameters a new function and if yes what's the type of occparam?
