Hi Gary.
Yes, the AppImage needs an executable bit set and you can move it around freely, as @chrisb has mentioned.
Gary R wrote: ↑Tue May 19, 2020 12:36 am
Second, is there any way to setup a desktop logo that will start the package?
Due to the fact you don't install anything, desktop integration doesn't work out of the box. There are solutions available, such as:
https://github.com/TheAssassin/AppImageLauncher
If you would only want to add a launcher, you could create a .desktop file manually:
nano $HOME/.local/share/applications/freecad.desktop
Add content:
[Desktop Entry]
Type=Application
Name=FreeCAD
Icon=/home/user_name/FreeCAD.svg
Exec=/home/user_name/FreeCAD.AppImage
And in general i would recommend, for anybody using an AppImage, to familiarize themselves with the concept of updating.
https://wiki.freecadweb.org/AppImage
There are two AppImage update tools available and best to test and select the one that suits your needs the best. AppImage update tool will only download the "delta changes". I recommend running it once per week, as the development AppImage gets updated once a week, usually over the weekend.
P.S. Note that, due to the fact the actual AppImage gets created and deployed daily, there is some "packaging noise" added and the updater therefore will find updates on "daily basis" and will download a small chunk of data, but that doesn't actually update anything FreeCAD code vise.
