Discussion: State of the snap (Snap Packaging)
Re: Discussion: State of the snap (Snap Packaging)
Edge is built from this recipe: https://github.com/ppd/freecad-ppd/blob ... craft.yaml
by this workflow: https://github.com/ppd/freecad-ppd/blob ... -daily.yml
So edge is built on a daily basis at midnight and pulls the then current HEAD from FreeCAD master. I hope that clears things up.
Thx!
- HenriqueReis
Re: Saving aborted
OS: Ubuntu Core 20 (Budgie:GNOME/budgie-desktop)
Version: 0.20.26658 (Git)
Hash: 86ee738dff708f8cb54ac1a4ea39092092350ddf
Python version: 3.8.10
Qt version: 5.15.3
OCC version: 7.5.2
Locale: Portuguese/Brazil (pt_BR)
Guys ... I have a problem with my FreeCAD ... it is not allowing me to save my files or open files ... like when I save the message "Save aborted" appears.
I emphasize that I do not display the folder window to open or to save the file.
My version 0.20 installation process was running the command: sudo snap install --edge freecad-ppd
Indicated by this link: https://wiki.freecadweb.org/Ubuntu_Snap
Qt version: 5.15.3
OCC version: 7.5.2
Reason: Moved post to the official Snap thread
@HenriqueReis I can't recreate the problem on the same version of snap edge
OS: Ubuntu Core 20 (KDE/plasma)
Qt version: 5.15.3
OCC version: 7.5.2
Qt version: 5.15.3
OCC version: 7.5.2
An educated guess: For some reason, no desktop portal could be running in your session. The Qt platform plugin inside the snap will call the xdg desktop portal implementation outside of the snap via dbus to open a file dialog. KDE and Gnome sessions usually have this set up.
So there are most likely two options: install a desktop portal or set an environment variable so that Qt does not use the desktop portal.
@ppd can you check out this issue: https://forum.freecadweb.org/viewtopic. ... 57#p554457 It may not be snap related (although I can recreate it on it) but perhaps you can troubleshoot it nonetheless?
That's due to the files getting installed to another directory:
So that probably needs to be changed to
src/Mod/Mesh/CMakeLists.txt: Line 48
INSTALL(FILES ${MeshTestDataFiles} DESTINATION Mod/Mesh/Data)
INSTALL(FILES ${MeshTestDataFiles} DESTINATION Mod/Mesh/App/TestData)
Excellent, @chennes merged the fix in git commit fc642482d
@ppd can you update snap edge so I can test?
+1
BTW, can you make a badge for the snap edge that specifies the current revision number ?
