[Finally DONE] conda: vtk9 / occt7.5 / python3.9 / boost1.74 migration
Placeholder for tracking the migration to new versions of vtk / occt / boost and other libraries. I think to work on this during the wintertime. So 0.19 release should be with older deps (not doing this mistake again and update deps during release is happening).
[x] python3.9 https://github.com/conda-forge/python-f ... k/pull/395
[x] vtk9 https://github.com/conda-forge/vtk-feedstock/pull/127
[x] occt7.5 https://github.com/conda-forge/occt-feedstock/pull/58
[x] opencamlib with boost1.74: https://github.com/conda-forge/opencaml ... ock/pull/5
[x] opencamlib with python3.9: https://github.com/conda-forge/opencaml ... ock/pull/6
[x] smesh + vtk9 https://forum.freecadweb.org/viewtopic. ... 9&start=30
[x] start occt-migration link
[x] smesh https://github.com/conda-forge/smesh-feedstock/pull/42
[x] netgen https://github.com/conda-forge/netgen-feedstock/pull/38
[x] gmsh (failing windows build) https://github.com/conda-forge/gmsh-feedstock/pull/39
[x] ifcopenshell https://github.com/conda-forge/ifcopens ... ck/pull/17
[x] freecad
[x] python-occ not yet ready: https://github.com/tpaviot/pythonocc-core/issues/917
[x] smesh crash on osx (reproduce by creating a mesh with netgen)
[x] weekly builds updated to vtk9 / occt7.5 /python3.9
[x] Appimage updated to vtk9 / occt7.5 /python3.9
[x] freecad
Re: [WIP] conda: vtk9 / occt7.5 / python3.9 / boost1.74 migration
Nice! Does nglib survive the migration to occt 7.5.0?looo wrote: ↑Mon Nov 09, 2020 10:51 am laceholder for tracking the migration to new versions of vtk / occt / boost and other libraries. I think to work on this during the wintertime. So 0.19 release should be with older deps (not doing this mistake again and update deps during release is happening).
"fight the good fight"
good question, didn't thought about netgen yet. Maybe first get things updated to vtk9 / python3.9 and then try occt7.5...sgrogan wrote: ↑Mon Nov 09, 2020 11:38 pmNice! Does nglib survive the migration to occt 7.5.0?looo wrote: ↑Mon Nov 09, 2020 10:51 am laceholder for tracking the migration to new versions of vtk / occt / boost and other libraries. I think to work on this during the wintertime. So 0.19 release should be with older deps (not doing this mistake again and update deps during release is happening).
- hobbes1069
I am updating Fedora Rawhide to OCC 7.5.0. I'm actually just waiting on the last build to complete so I can push an update. I'm building FreeCAD 0.19 from latest master as of yesterday.
Now I'm working on VTK 9.0.1 with it's maintainer. We have setup a COPR to do test builds outside of the Fedora ecosphere:
https://copr.fedorainfracloud.org/coprs/orion/vtk9.0/
It doesn't look like FreeCAD has been migrated yet:
https://copr-be.cloud.fedoraproject.org ... ild.log.gz
Thanks,
Richard
Thanks,
Richard
Thank you all so much!
packages are ready for testing at conda-forge. There are builds available for py3.8 / py3.9 - vtk9 - boost1.74 - occt7.4 - linux / osx / win. You can create an environment with one of these packages by:
py3.9 should be default but it still has some issues. So you can also test with py3.8 by specifying the version:
Would be nice if some people can test and help with fixing the remaining issues. Once this is done I will go ahead and start with the occt7.5 migration.
conda create -n freecad_vtk9 freecad vtk=9 -c conda-forge/label/smesh_rc -c freecad/label/dev -c conda-forge
conda create -n freecad_vtk9 freecad vtk=9 python=3.8 -c conda-forge/label/smesh_rc -c freecad/label/dev -c conda-forge
FEM tests have a hard dependency on matplotlib. After installing this I get 3 self test errors related to MeshGroups. I will investigate.
I also get 1 error related to the StartGui, I also get this on all other builds from master.
OS: Windows 10 (10.0)
Version: 0.19.23738 (Git)
Hash: 7a08b7aad25f19eab6f297409f42f7d174412af0
Python version: 3.9.1
Qt version: 5.12.9
OCC version: 7.4.0
I get the same FEM test errors with the PY3.8 version, so it must be SMESH/vtk9 releated?
Version: 0.19.23739 (Git)
Hash: 020e5bc7093a8a07b89edd92e6c12496457b7ad6
Python version: 3.8.6
Qt version: 5.12.9
OCC version: 7.4.0
I can package Win build(s) if it helps.
Qt version: 5.12.9
OCC version: 7.4.0
First errorbernd wrote: pinged by pinger macro
File "C:\Users\Chris\Miniconda3\envs\freecad_vtk9-py38\lib\unittest\case.py", line 60, in testPartExecutor
yield
File "C:\Users\Chris\Miniconda3\envs\freecad_vtk9-py38\lib\unittest\case.py", line 676, in run
self._callTestMethod(testMethod)
File "C:\Users\Chris\Miniconda3\envs\freecad_vtk9-py38\lib\unittest\case.py", line 633, in _callTestMethod
method()
File "C:\Users\Chris\Miniconda3\envs\freecad_vtk9-py38\Library\Mod\Fem\femtest\app\test_mesh.py", line 695, in test_add_group_elements
fm.addGroupElements(myid, elements_to_be_added)
Base.FreeCADError: AddGroupElements: No group for given id.
should be fixed with the latest py3.9 build. See @wmayers comment here: https://github.com/trelau/SMESH/pull/31 ... -766358432
I think we can go directly to py3.9 and occt7.5 and keep the old builds py3.8 / occt7.4 / vtk8 until the 0.19 release. But first the smesh packages needs to be packaged for conda-forge. I wait for @trelau to decide when this is the case.
What is still remaining with the py3.9 / vtk9 builds is this test error:
File "/home/lo/miniconda3/envs/freecad_vtk9/lib/python3.9/unittest/case.py", line 59, in testPartExecutor
yield
File "/home/lo/miniconda3/envs/freecad_vtk9/lib/python3.9/unittest/case.py", line 593, in run
File "/home/lo/miniconda3/envs/freecad_vtk9/lib/python3.9/unittest/case.py", line 550, in _callTestMethod
method()
File "/home/lo/miniconda3/envs/freecad_vtk9/lib/python3.9/unittest/loader.py", line 34, in testFailure
raise self._exception
ImportError: Failed to import test module: TestStartGui
File "/home/lo/miniconda3/envs/freecad_vtk9/lib/python3.9/unittest/loader.py", line 154, in loadTestsFromName
module = __import__(module_name)
File "/home/lo/miniconda3/envs/freecad_vtk9/Mod/Start/TestStartGui.py", line 25, in <module>
from TestStart.TestStartPage import TestStartPage
ModuleNotFoundError: No module named 'TestStart'
#0 /lib/x86_64-linux-gnu/libc.so.6(+0x3f040) [0x7f9b83686040]
#1 /home/lo/miniconda3/envs/freecad_vtk9/bin/../lib/libpython3.9.so.1.0(PyObject_GC_Del+0x1b) [0x7f9b8587944b]
#2 0x7f9b862ff388 in Gui::ViewProviderPythonFeatureImp::~ViewProviderPythonFeatureImp() from /home/lo/miniconda3/envs/freecad_vtk9/bin/../lib/libFreeCADGui.so+0x208
#3 0x7f9a4f8f034d in Gui::ViewProviderPythonFeatureT<PartGui::ViewProviderPart>::~ViewProviderPythonFeatureT() from /home/lo/miniconda3/envs/freecad_vtk9/lib/PartGui.so+0x2d
#4 0x7f9b85f5fc34 in Gui::Document::~Document() from /home/lo/miniconda3/envs/freecad_vtk9/bin/../lib/libFreeCADGui.so+0x294
#5 0x7f9b85f6038a in Gui::Document::~Document() from /home/lo/miniconda3/envs/freecad_vtk9/bin/../lib/libFreeCADGui.so+0xa
This is because of PCH
-DFREECAD_USE_PCH=TRUE will remove the error,
It's not specific to conda.
