No, with a debug build I get the same error as for the other WBs using numpy.
LibPack for Windows "Python packages"
Re: LibPack for Windows "Python packages"
There is however, a bigger issue: I can no longer tessellate parts. I rebuilt FC from scratch to check and the problem persists:
- select a part in the tree
- switch to the Mesh WB
- use there the menu Meshes->Create mesh from shape
result: nothing happens and I get this error:
16:25:23 Traceback (most recent call last):
File "D:\FreeCAD-build\bin\Lib\site-packages\shiboken2\files.dir\shibokensupport\__feature__.py", line 142, in _import
<class 'ImportError'>: DLL load failed while importing MeshPart: The specified procedure could not be found.
I removed the standalone python and rebuilt everything from scratch. But the problems persists. At least I got now the info that the "Prozedureinsprungspunkt" into nglib.dll could not be found.uwestoehr wrote: ↑Tue Dec 08, 2020 3:30 pmCode: Select all
16:25:23 Traceback (most recent call last): File "<string>", line 1, in <module> File "D:\FreeCAD-build\bin\Lib\site-packages\shiboken2\files.dir\shibokensupport\__feature__.py", line 142, in _import return original_import(name, *args, **kwargs) <class 'ImportError'>: DLL load failed while importing MeshPart: The specified procedure could not be found.
That is strange because the nglib.dll is the same as in the LibPack 12.3.2. (Few weeks ago we agreed to keep the NetGen files in the Libpack untouched until FreeCAD 0.19 was released.)
Even more strange is that I don't get this error message again (thus I cannot make a screenshot), now i only get the meaningless shibokensupport message.
Edit: for the same reason, also the FEM Workbench does not work. @apeltauer, can you compile so that the FEM Workbench works?
Do you still talk about the debug build or this it also happen for a release build?I removed the standalone python and rebuilt everything from scratch. But the problems persists. At least I got now the info that the "Prozedureinsprungspunkt" into nglib.dll could not be found.
This is for the release build. And now I was able to make a screenshot of the error message:
Edit: maybe it doesn't work because the NetGen in the Libpack was compiled against OCC 7.4 and the Libpack contains OCC 7.5?
I am getting an assertion failure when running self test from the test framework wb for a debug build, release doesn't have it.
I don't have a D: so I think a hard coded path somehow?I wasn't able to build with BUILD_FEM_NETGEN, so I thought this was the case and disabled it.
"fight the good fight"
I think certain modules do https://numpy.org/devdocs/user/building.html
I found this https://discuss.python.org/t/pip-pyproj ... uilds/3766
don't know what happens if it can't find a fortran compiler.
Yes, this must be the reason.Edit: maybe it doesn't work because the NetGen in the Libpack was compiled against OCC 7.4 and the Libpack contains OCC 7.5?
sorry, fem is disabled at my build ....
I will have a look for the netgen problem.
BTW: the selftest in debug mode never worked for me. Also numpy does not work in debug mode...
They are fixed now with git commit 065f3fafa9159. So, the Coin3d header file doesn't need to be modified any more.uwestoehr wrote: ↑Sat Dec 05, 2020 11:37 pm I get now only many warnings but in principles there are only 2 issues:
A: redefinition of HAVE_UINT8_T:Code: Select all
60>D:\FreeCAD-build\FreeCADLibs_12.4.2_x64_VC17\include\Inventor/system/inttypes.h(90,1): warning C4005: 'HAVE_INT8_T': macro redefinition 60>D:\FreeCADGit\src\FCConfig.h(134): message : see previous definition of 'HAVE_INT8_T' ... 60>D:\FreeCADGit\src\FCConfig.h(169): message : see previous definition of 'HAVE_UINT64_T'
I have no idea how to avoid this warning. To me it looks like a Qt internal problem.B: redefinition of GL_GLEXT_LEGACY:Code: Select all
60>D:\FreeCAD-build\FreeCADLibs_12.4.2_x64_VC17\include\QtGui/qopengl.h(136,1): warning C4005: 'GL_GLEXT_LEGACY': macro redefinition 60>D:\FreeCADGit\src\Gui\PreCompiled.cpp : message : see previous definition of 'GL_GLEXT_LEGACY'
