Replacing pivy was too simple. I replaced coin and pivy from Conda into the libpack and I can build FC and pass all unit tests.
Trails WB loads.
What is the easiest way to test the SoGeo stuff?
from pivy import coin
sg = FreeCADGui.ActiveDocument.ActiveView.getSceneGraph()
node = sg.getChild(0)
if not isinstance(node, coin.SoGeoOrigin):
node = coin.SoGeoOrigin()
sg.insertChild(node,0)
node.geoSystem.setValues(["UTM", "Z1", "FLAT"])
node.geoCoords.setValue(4512486125.0, 580526122.0, 0.0)
Thanks, exactly what I needed!HakanSeven12 wrote: ↑Sat Nov 21, 2020 1:35 pm Run this macro. If this not returning an error its works.
Python 3.8.6+ (heads/3.8-dirty:a12f459ec2, Nov 5 2020, 12:01:10) [MSC v.1927 64 bit (AMD64)] on win32
Type 'help', 'copyright', 'credits' or 'license' for more information.
>>> Gui.runCommand('Std_DlgMacroExecute',0)
I put a test build here: https://github.com/sgrogan/FreeCAD/rele ... /0.19_test
Thanks and done. Same link.HakanSeven12 wrote: ↑Sat Nov 21, 2020 8:11 pm I tested your build. Everything works great at SoGeo side Can you add scipy library too?
Do you have any need to use boost 1.74? If yes please point out what is missing. Then i can try to use the newer boost version.sinfee wrote: ↑Sat Nov 21, 2020 7:05 amThanks a lot. but Can you tell me: why use boost 1.67 ,not 1.74 ?apeltauer wrote: ↑Sun Nov 15, 2020 5:03 pm New version uploaded:
https://github.com/apeltauer/FreeCAD/re ... ack_12.4.1
I'm a beginner of boost from 1.72 , and now I used 1.74 with vc2015 on my work , so can you give me a suggestion for how to make 3rd party libraries by myself?apeltauer wrote: ↑Mon Nov 23, 2020 6:29 amDo you have any need to use boost 1.74? If yes please point out what is missing. Then i can try to use the newer boost version.sinfee wrote: ↑Sat Nov 21, 2020 7:05 amThanks a lot. but Can you tell me: why use boost 1.67 ,not 1.74 ?apeltauer wrote: ↑Sun Nov 15, 2020 5:03 pm New version uploaded:
