Ubuntu 20.04 : libshiboken2.cpython-36m-x86_64-linux-gnu.so.5.11: cannot open shared object file
boy007
Post by boy007 »
upgraded to 18.04 -> 20.4.2 Ubuntu and Freecad dose not library, nor I do not find
library from ppa!! Tried apt-get, snap installs,...
freecad: error while loading shared libraries: libshiboken2.cpython-36m-x86_64-linux-gnu.so.5.11: cannot open shared object file: No such file or directory
joni@mpi1:/usr/bin$
adrianinsaval
Re: Ubuntu 20.04 : libshiboken2.cpython-36m-x86_64-linux-gnu.so.5.11: cannot open shared object file
Post by adrianinsaval »
Were did you install freecad from? I remember having issues with ppas after upgrading ubuntu once so check if you still have freecad's ppa enabled in case you were using that before.
boy007
Post by boy007 »
hi,
in deed this problematic,
Ubuntu 20.4 from Launch Pad repository gives error that error.
SNAP package dose not include SpaceNav Spaceball support.
Ubuntu own repository is at v.18
But AppIMAGE work's and when time I will do it from sources again!
joni
kkremitzki
Post by kkremitzki »
I can't reproduce this issue. I have tried with the stable PPA on a fresh Ubuntu 20.04 installation, and I also tried putting the stable PPA on Ubuntu 18.04 and then upgrading to 20.04 like you mentioned. Have you tried removing all the FreeCAD packages and then re-installing? Please provide more info to reproduce the issue.
