macos packaging using homebrew
ipatch
Post by ipatch »
i've been using macos homebrew and several different versions of the OS to build and test freecad from git master for a little while now. i've uploaded a few DGM releases of the FreeCAD.app bundle to the homebrew-freecad tap hosted on github.
https://github.com/FreeCAD/homebrew-fre ... -26155.dmg
i've been trying my best to make sure most if not all things are working. that release seems to have more things working and included than the prior release or two that i have posted.
however something i have noticed is the addon manager appears to not work ie. i'm experiencing some runtime related issues using the addon manager. take a quick look at my app bundle, comparing and contrasting to the conda released bundles i see the conda releases are including a GitPython module that my bundle seems to be missing.
cd /Applications/freecads/FreeCAD-0.20-26155-git.app/Contents/Resources
fd -t f 'gitpython'
compared to
/Applications/freecads/FreeCAD.conda.0.20.26155.app/Contents/Resources
fd -t f 'gitpython'
conda-meta/gitpython-3.1.24-pyhd8ed1ab_0.json
i'm building freecad from git source and have most if not all dependencies installed via macos homebrew some from the provided tap others from upstream homebrew-core.
my cmake args look like the below
cmake  \
-DHOMEBREW_PREFIX=$bp \
-DPYTHON_EXECUTABLE="$bp/bin/python3" \
-DPYTHON_INCLUDE_DIR=\
$bp/opt/python@3.9/Frameworks/Python.framework/Versions/3.9/include/python3.9 \
-DBUILD_SMESH=1 \
-DBUILD_FEM_NETGEN=ON \
-DCMAKE_PREFIX_PATH=\
"$bp/Cellar/vtk@8.2/8.2.0_7/lib/cmake;\
$bp/Cellar/qt@5/5.15.2_1/lib/cmake;\
$bp/Cellar/pyside@2/5.15.2_1/lib/cmake;\
$bp/Cellar/hdf5@1.10/1.10.7_1/lib;\
$bp/Cellar/nglib@6.2.2104/6.2.2104_1/Contents/Resources/CMake;" \
-DCMAKE_INSTALL_PREFIX="/opt/beta/freecad/amd64/release" \
-DFREECAD_CREATE_MAC_APP=1 \
-DCMAKE_BUILD_TYPE=Release \
-DINSTALL_TO_SITEPACKAGES=1 \
../freecad-src/
$bp is an environment variable i've set to my provided homebrew prefix as i use this macosvm for different use cases and this particular build user has macos homebrew setup in their respected $HOME directory.
doing a internet searches i came across a forum thread where the cmake args for the conda build were posted as the below
cmake -G "Ninja" \
-D BUID_WITH_CONDA:BOOL=ON \
-D CMAKE_BUILD_TYPE=Release \
-D CMAKE_INSTALL_PREFIX:FILEPATH=$PREFIX \
-D CMAKE_PREFIX_PATH:FILEPATH=$PREFIX \
-D CMAKE_LIBRARY_PATH:FILEPATH=$PREFIX/lib \
-D CMAKE_INSTALL_LIBDIR:FILEPATH=$PREFIX/lib \
-D CMAKE_INCLUDE_PATH:FILEPATH=$PREFIX/include \
-D BUILD_QT5:BOOL=ON \
-D FREECAD_USE_OCC_VARIANT="Official Version" \
-D OCC_INCLUDE_DIR:FILEPATH=$PREFIX/include \
-D USE_BOOST_PYTHON:BOOL=OFF \
-D FREECAD_USE_PYBIND11:BOOL=ON \
-D BUILD_ENABLE_CXX11:BOOL=ON \
-D SMESH_INCLUDE_DIR:FILEPATH=$PREFIX/include/smesh \
-D FREECAD_USE_EXTERNAL_SMESH=ON \
-D BUILD_FLAT_MESH:BOOL=ON \
-D BUILD_WITH_CONDA:BOOL=ON \
-D PYTHON_EXECUTABLE:FILEPATH=$PREFIX/bin/python \
-D BUILD_FEM_NETGEN:BOOL=ON \
-D BUILD_PLOT:BOOL=OFF \
-D BUILD_SHIP:BOOL=OFF \
-D OCCT_CMAKE_FALLBACK:BOOL=OFF \
-D FREECAD_USE_QT_DIALOG:BOOL=ON \
-D BUILD_DYNAMIC_LINK_PYTHON:BOOL=OFF \
-D Boost_NO_BOOST_CMAKE:BOOL=ON \
-D FREECAD_USE_PCL:BOOL=ON \
-D INSTALL_TO_SITEPACKAGES:BOOL=ON \
${CMAKE_PLATFORM_FLAGS[@]} \
i don't remember the exact forum post i copied those from, but any help on how i can get the addon manager properly working would be AWESOME. i have little to know experience debugging python runtime issues, so any help would be greatly appreciated.
i'll link to a screenshot below showing what i presently seeing in regards to the addon manager.
Gift
Re: macos packaging using homebrew
Post by Gift »
Hello IPatch,
the git libs are pure python code. So it is possible to install it as resource in the python formula:
  resource "gitpython" do
    url "https://files.pythonhosted.org/packages/34/cc/aaa7a0d066ac9e94fbffa5fcf0738f5742dd7095bdde950bd582fca01f5a/GitPython-3.1.24.tar.gz"
    sha256 "df83fdf5e684fef7c6ee2c02fc68a5ceb7e7e759d08b694088d0cacb4eba59e5"
  end
  resource "gitdb" do
    url "https://files.pythonhosted.org/packages/fc/44/64e02ef96f20b347385f0e9c03098659cb5a1285d36c3d17c56e534d80cf/gitdb-4.0.9.tar.gz"
    sha256 "bac2fd45c0a1c9cf619e63a90d62bdc63892ef92387424b855792a6cabe789aa"
  end
Maybe the bundler have to add git. Or is git standard installed on MacOS?
Regards Benjamin
ipatch
Post by ipatch »
Gift
thanks for the suggestion, however i'm not installing freecad via
brew install freecad/freecad/freecad
but rather installing the deps ie. vtk,occ,python@3.9,coin3d,...etc... via homebrew
so i'm doing a
git clone https://github.com/freecad/freecad freecad-src
then creating a build directory and the same level as the freecad-src and then running,
cmake ../freecad-src
make
make install
forgive if you already understand that, or if i'm misunderstading what it is your conveying.
all that said, would there be a particular dependency that i could add those resources too so when i bundle freecad via make install they get included into the `FreeCAD.app` bundle and hopefully thus providing the utilities / resources required to get the AddOn Manager working as intended.
UPDATE, reread what you typed, you state i should include those resources in the python formula. hmmm.
Gift
Post by Gift »
Sorry, it is not so simple. Please check this commit.
ipatch
Post by ipatch »
Gift,
before you added that commit, were you running into the same issue that i described above were the addon manager was/is not displaying a list of available workbenches?
Gift
Post by Gift »
ipatch wrote: Fri Nov 05, 2021 5:27 pm Gift,
No. It works fine.
Gift
Post by Gift »
Please test this:
import addonmanager_utilities as utils
u = utils.urlopen("https://raw.githubusercontent.com/FreeCAD/FreeCAD-addons/master/addonflags.json")
print(u.read())
ipatch
Post by ipatch »
Gift wrote: Sun Nov 07, 2021 5:58 pm
Please test this:
print(u.read())
this is what i'm seeing with your suggested commands,
>>> print(u.read())
AttributeError: 'NoneType' object has no attribute 'read'
i'm using this release i published a while back,
Gift
Post by Gift »
ipatch wrote: Sun Nov 07, 2021 8:27 pm
>>> print(u.read())
Can you remove the exception in the source code for better error message? See here.
edit:
urllib.error.URLError: <urlopen error [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1129)>
With your dmg I get the same issue.
Gift
Post by Gift »
