[Fixed][Sketcher] windows build fails (conda)
looo
Post by looo »
Building for windows with conda currently fails with the following error:
GeoList.cpp.obj : error LNK2005: "public: static class Sketcher::GeoElementId const Sketcher::GeoElementId::RtPnt" (?RtPnt@GeoElementId@Sketcher@@2V12@B) already defined in SketchObject.cpp.obj
GeoList.cpp.obj : error LNK2005: "public: static class Sketcher::GeoElementId const Sketcher::GeoElementId::HAxis" (?HAxis@GeoElementId@Sketcher@@2V12@B) already defined in SketchObject.cpp.obj
GeoList.cpp.obj : error LNK2005: "public: static class Sketcher::GeoElementId const Sketcher::GeoElementId::VAxis" (?VAxis@GeoElementId@Sketcher@@2V12@B) already defined in SketchObject.cpp.obj
GeoEnum.cpp.obj : error LNK2005: "public: static class Sketcher::GeoElementId const Sketcher::GeoElementId::RtPnt" (?RtPnt@GeoElementId@Sketcher@@2V12@B) already defined in SketchObject.cpp.obj
GeoEnum.cpp.obj : error LNK2005: "public: static class Sketcher::GeoElementId const Sketcher::GeoElementId::HAxis" (?HAxis@GeoElementId@Sketcher@@2V12@B) already defined in SketchObject.cpp.obj
GeoEnum.cpp.obj : error LNK2005: "public: static class Sketcher::GeoElementId const Sketcher::GeoElementId::VAxis" (?VAxis@GeoElementId@Sketcher@@2V12@B) already defined in SketchObject.cpp.obj
   Creating library src\Mod\Sketcher\App\Sketcher.lib and object src\Mod\Sketcher\App\Sketcher.exp
Maybe abdullah can help with this issue:
abdullah wrote:
looo
Re: [Sketcher] windows build fails (conda)
Post by looo »
wmayer wrote:
can you help with this isssue, it's still failing after 2 weeks.
Founder
Post by wmayer »
Is this built from current master? What compiler does Windows Conda actually use?
So far we have current master working on:
  • Linux with clang/gcc
  • macOS with clang
  • Windows with MSVC
  • Windows with MSYS/clang
looo
Post by looo »
wmayer wrote: Sun Jan 16, 2022 5:05 pm Is this built from current master? What compiler does Windows Conda actually use?
  • macOS with clang
  • Windows with MSVC
Conda uses msvc for windows to build freecad.
-- The C compiler identification is MSVC 19.16.27045.0
-- The CXX compiler identification is MSVC 19.16.27045.0
SketchAnalysis.cpp.obj : error LNK2005: "public: static class Sketcher::GeoElementId const Sketcher::GeoElementId::RtPnt" (?RtPnt@GeoElementId@Sketcher@@2V12@B) already defined in SketchObject.cpp.obj
SketchAnalysis.cpp.obj : error LNK2005: "public: static class Sketcher::GeoElementId const Sketcher::GeoElementId::HAxis" (?HAxis@GeoElementId@Sketcher@@2V12@B) already defined in SketchObject.cpp.obj
SketchAnalysis.cpp.obj : error LNK2005: "public: static class Sketcher::GeoElementId const Sketcher::GeoElementId::VAxis" (?VAxis@GeoElementId@Sketcher@@2V12@B) already defined in SketchObject.cpp.obj
AppSketcher.cpp.obj : error LNK2005: "public: static class Sketcher::GeoElementId const Sketcher::GeoElementId::RtPnt" (?RtPnt@GeoElementId@Sketcher@@2V12@B) already defined in SketchObject.cpp.obj
ExternalGeometryFacadePyImp.cpp.obj : error LNK2005: "public: static class Sketcher::GeoElementId const Sketcher::GeoElementId::RtPnt" (?RtPnt@GeoElementId@Sketcher@@2V12@B) already defined in SketchObject.cpp.obj
ExternalGeometryFacadePyImp.cpp.obj : error LNK2005: "public: static class Sketcher::GeoElementId const Sketcher::GeoElementId::HAxis" (?HAxis@GeoElementId@Sketcher@@2V12@B) already defined in SketchObject.cpp.obj
ExternalGeometryFacadePyImp.cpp.obj : error LNK2005: "public: static class Sketcher::GeoElementId const Sketcher::GeoElementId::VAxis" (?VAxis@GeoElementId@Sketcher@@2V12@B) already defined in SketchObject.cpp.obj
ConstraintPyImp.cpp.obj : error LNK2005: "public: static class Sketcher::GeoElementId const Sketcher::GeoElementId::RtPnt" (?RtPnt@GeoElementId@Sketcher@@2V12@B) already defined in SketchObject.cpp.obj
ConstraintPyImp.cpp.obj : error LNK2005: "public: static class Sketcher::GeoElementId const Sketcher::GeoElementId::HAxis" (?HAxis@GeoElementId@Sketcher@@2V12@B) already defined in SketchObject.cpp.obj
ConstraintPyImp.cpp.obj : error LNK2005: "public: static class Sketcher::GeoElementId const Sketcher::GeoElementId::VAxis" (?VAxis@GeoElementId@Sketcher@@2V12@B) already defined in SketchObject.cpp.obj
SketchPyImp.cpp.obj : error LNK2005: "public: static class Sketcher::GeoElementId const Sketcher::GeoElementId::RtPnt" (?RtPnt@GeoElementId@Sketcher@@2V12@B) already defined in SketchObject.cpp.obj
SketchPyImp.cpp.obj : error LNK2005: "public: static class Sketcher::GeoElementId const Sketcher::GeoElementId::HAxis" (?HAxis@GeoElementId@Sketcher@@2V12@B) already defined in SketchObject.cpp.obj
SketchPyImp.cpp.obj : error LNK2005: "public: static class Sketcher::GeoElementId const Sketcher::GeoElementId::VAxis" (?VAxis@GeoElementId@Sketcher@@2V12@B) already defined in SketchObject.cpp.obj
PropertyConstraintList.cpp.obj : error LNK2005: "public: static class Sketcher::GeoElementId const Sketcher::GeoElementId::RtPnt" (?RtPnt@GeoElementId@Sketcher@@2V12@B) already defined in SketchObject.cpp.obj
PropertyConstraintList.cpp.obj : error LNK2005: "public: static class Sketcher::GeoElementId const Sketcher::GeoElementId::HAxis" (?HAxis@GeoElementId@Sketcher@@2V12@B) already defined in SketchObject.cpp.obj
PropertyConstraintList.cpp.obj : error LNK2005: "public: static class Sketcher::GeoElementId const Sketcher::GeoElementId::VAxis" (?VAxis@GeoElementId@Sketcher@@2V12@B) already defined in SketchObject.cpp.obj
Constraint.cpp.obj : error LNK2005: "public: static class Sketcher::GeoElementId const Sketcher::GeoElementId::RtPnt" (?RtPnt@GeoElementId@Sketcher@@2V12@B) already defined in SketchObject.cpp.obj
Constraint.cpp.obj : error LNK2005: "public: static class Sketcher::GeoElementId const Sketcher::GeoElementId::HAxis" (?HAxis@GeoElementId@Sketcher@@2V12@B) already defined in SketchObject.cpp.obj
Constraint.cpp.obj : error LNK2005: "public: static class Sketcher::GeoElementId const Sketcher::GeoElementId::VAxis" (?VAxis@GeoElementId@Sketcher@@2V12@B) already defined in SketchObject.cpp.obj
Sketch.cpp.obj : error LNK2005: "public: static class Sketcher::GeoElementId const Sketcher::GeoElementId::RtPnt" (?RtPnt@GeoElementId@Sketcher@@2V12@B) already defined in SketchObject.cpp.obj
Sketch.cpp.obj : error LNK2005: "public: static class Sketcher::GeoElementId const Sketcher::GeoElementId::HAxis" (?HAxis@GeoElementId@Sketcher@@2V12@B) already defined in SketchObject.cpp.obj
Sketch.cpp.obj : error LNK2005: "public: static class Sketcher::GeoElementId const Sketcher::GeoElementId::VAxis" (?VAxis@GeoElementId@Sketcher@@2V12@B) already defined in SketchObject.cpp.obj
Maybe it's related to using -D FREECAD_USE_PCH:BOOL=OFF for these builds.
Founder
Post by wmayer »
Very unlikely. It's probably related to the MSVC compiler version.
GeneFC
Post by GeneFC »
looo wrote: Mon Jan 17, 2022 10:54 am Conda uses msvc for windows to build freecad.
I have used those exact versions of the compilers multiple times without problems.
I just used 19.29.30139, again with no problems.
Using LibPack, not Conda.
Gene
chennes
Post by chennes »
Is a Conda build "clean"? I had an issue last week that required me to do a from-scratch rebuild on Visual Studio -- I don't recall the exact error, but it was related to something in Sketcher.
Chris Hennes
Pioneer Library System
looo
Post by looo »
chennes wrote: Sun Jan 23, 2022 5:55 pm
conda does a full rebuild, no caching.
looo
Post by looo »
GeneFC wrote: Tue Jan 18, 2022 7:58 pm I have used those exact versions of the compilers multiple times without problems.
the issue occurs only with current master, not with 0.19.3.
Founder
Post by wmayer »
Of course. It's all about this class https://github.com/FreeCAD/FreeCAD/blob ... /GeoEnum.h that has been added last month.
I would have assumed that it's a compiler bug because it's working with so many compilers and it's perfectly valid C++ code. But now that Gene said he uses the exact same compiler version and for him it works then I guess something must be wrong with the object files from a previous build.
Not using a cache is not the same as doing a clean rebuild. So, let me rephrase the question: are you sure that between two builds all object files (*.obj) are deleted?
