Realthunder's Link branch Snap packages
bambuko
Re: Realthunder's Link branch Snap packages
Post by bambuko »
ppd wrote: Tue Jan 25, 2022 4:05 pm Assembly3 has an install dialog for py_slvs included nowadays. No need to use the terminal.
Yes, but... when I used it recently it resulted in error message (still installed though OK)
Anyway, it works fine now (after Kunda1 put me on straight and narrow :lol: )
but when I try to open existing assembly files it results in long error messages :oops:
basically saying that all the linked files do not exist .... :twisted:
bambuko@Z97MD3Hcd5bddbb:/snap$ free*
FreeCAD 0.20, Libs: 2022.120R14555 (Git shallow)
Adding snap-specific PYTHONPATH to sys.path: /home/bambuko/snap/freecad-realthunder/common/.local/lib/python3.8/site-packages:/snap/freecad-realthunder/1/lib/python3.8/site-packages:/snap/freecad-realthunder/1/usr/lib/python3/dist-packages
connect failed: No such file or directory
<Exception> File '/run/user/1000/doc/a3927f7c/04_wheels.FCStd' does not exist!
Exception opening file: /run/user/1000/doc/a3927f7c/04_wheels.FCStd [File '/run/user/1000/doc/a3927f7c/04_wheels.FCStd' does not exist!]
<Exception> File '/run/user/1000/doc/a3927f7c/14_8ft_track.FCStd' does not exist!
Exception opening file: /run/user/1000/doc/a3927f7c/14_8ft_track.FCStd [File '/run/user/1000/doc/a3927f7c/14_8ft_track.FCStd' does not exist!]
<Exception> File '/run/user/1000/doc/a3927f7c/02_loco_base.FCStd' does not exist!
Exception opening file: /run/user/1000/doc/a3927f7c/02_loco_base.FCStd [File '/run/user/1000/doc/a3927f7c/02_loco_base.FCStd' does not exist!]
<Exception> File '/run/user/1000/doc/a3927f7c/08_bogie_wheels.FCStd' does not exist!
Exception opening file: /run/user/1000/doc/a3927f7c/08_bogie_wheels.FCStd [File '/run/user/1000/doc/a3927f7c/08_bogie_wheels.FCStd' does not exist!]
<Exception> File '/run/user/1000/doc/a3927f7c/09_tender_wheels.FCStd' does not exist!
Exception opening file: /run/user/1000/doc/a3927f7c/09_tender_wheels.FCStd [File '/run/user/1000/doc/a3927f7c/09_tender_wheels.FCStd' does not exist!]
<Exception> File '/run/user/1000/doc/a3927f7c/08_bogie.FCStd' does not exist!
Exception opening file: /run/user/1000/doc/a3927f7c/08_bogie.FCStd [File '/run/user/1000/doc/a3927f7c/08_bogie.FCStd' does not exist!]
<Exception> File '/run/user/1000/doc/a3927f7c/07_axle_pump_hsg.FCStd' does not exist!
Exception opening file: /run/user/1000/doc/a3927f7c/07_axle_pump_hsg.FCStd [File '/run/user/1000/doc/a3927f7c/07_axle_pump_hsg.FCStd' does not exist!]
3.8e-08 <App> Document.cpp(3224): _1_loco_assembly#Link002.LinkedObject: Link not restored
Linked object: Assembly009
Linked file: 04_wheels.FCStd
0.0783552 <App> Document.cpp(3224): _1_loco_assembly#Link.LinkedObject: Link not restored
0.0850565 <App> Document.cpp(3224): _1_loco_assembly#Link001.LinkedObject: Link not restored
Linked object: Assembly001
0.0887584 <App> Document.cpp(3224): _1_loco_assembly#Link003.LinkedObject: Link not restored
Linked object: Assembly004
0.0923961 <App> Document.cpp(3224): _1_loco_assembly#Link004.LinkedObject: Link not restored
Linked object: Assembly005
0.0992371 <App> Document.cpp(3224): _1_loco_assembly#Link005.LinkedObject: Link not restored
Linked object: Assembly006
0.0992947 <App> Document.cpp(3224): _1_loco_assembly#Link006.LinkedObject: Link not restored
Linked object: Assembly007
0.099368 <App> Document.cpp(3224): _1_loco_assembly#Link007.LinkedObject: Link not restored
Linked object: Assembly008
0.106971 <App> Document.cpp(3224): _1_loco_assembly#Link009.LinkedObject: Link not restored
Linked object: Assembly010
0.128364 <App> Document.cpp(3224): _1_loco_assembly#Link010.LinkedObject: Link not restored
Linked object: Assembly002
0.135073 <App> Document.cpp(3224): _1_loco_assembly#Link011.LinkedObject: Link not restored
Linked object: Assembly003
0.159644 <App> Document.cpp(3224): _1_loco_assembly#Link012.LinkedObject: Link not restored
Linked file: 14_8ft_track.FCStd
0.159721 <App> Document.cpp(3224): _1_loco_assembly#Link013.LinkedObject: Link not restored
Linked object: Assembly026
Linked file: 02_loco_base.FCStd
0.159777 <App> Document.cpp(3224): _1_loco_assembly#Link014.LinkedObject: Link not restored
Linked object: Assembly027
0.159839 <App> Document.cpp(3224): _1_loco_assembly#Link015.LinkedObject: Link not restored
Linked object: Assembly051
0.159913 <App> Document.cpp(3224): _1_loco_assembly#Link017.LinkedObject: Link not restored
Linked object: Assembly034
0.159973 <App> Document.cpp(3224): _1_loco_assembly#Link016.LinkedObject: Link not restored
Linked object: Assembly054
0.160042 <App> Document.cpp(3224): _1_loco_assembly#Link018.LinkedObject: Link not restored
Linked object: Assembly081
0.160084 <App> Document.cpp(3224): _1_loco_assembly#Link019.LinkedObject: Link not restored
Linked object: Assembly028
0.160136 <App> Document.cpp(3224): _1_loco_assembly#Link020.LinkedObject: Link not restored
Linked object: Assembly033
0.160179 <App> Document.cpp(3224): _1_loco_assembly#Link021.LinkedObject: Link not restored
Linked object: Assembly083
0.178668 <App> Document.cpp(3224): _1_loco_assembly#Link031.LinkedObject: Link not restored
Linked file: 08_bogie.FCStd
0.18316 <App> Document.cpp(3224): _1_loco_assembly#Link032.LinkedObject: Link not restored
Linked object: Assembly075
Linked file: 07_axle_pump_hsg.FCStd
0.183247 <App> Document.cpp(3224): _1_loco_assembly#Link033.LinkedObject: Link not restored
Linked object: Assembly077
0.183311 <App> Document.cpp(3224): _1_loco_assembly#Link034.LinkedObject: Link not restored
Linked object: Assembly078
0.183386 <App> Document.cpp(3224): _1_loco_assembly#Link035.LinkedObject: Link not restored
Linked object: Assembly079
0.185222 <App> Document.cpp(3224): _1_loco_assembly#Link023.LinkedObject: Link not restored
Linked object: Assembly038
Linked file: 08_bogie_wheels.FCStd
0.25807 <App> Document.cpp(3224): _1_loco_assembly#Link024.LinkedObject: Link not restored
Linked object: Assembly039
0.342313 <App> Document.cpp(3224): _1_loco_assembly#Link029.LinkedObject: Link not restored
Linked file: 09_tender_wheels.FCStd
0.373547 <App> Document.cpp(3224): _1_loco_assembly#Link026.LinkedObject: Link not restored
0.405063 <App> Document.cpp(3224): _1_loco_assembly#Link028.LinkedObject: Link not restored
I am using Link branch and Assembly3
you can also download ... and try it here
excellent Assembly3 tutorials here
ppd
Post by ppd »
bambuko wrote: Tue Jan 25, 2022 5:14 pm but when I try to open existing assembly files it results in long error messages :oops:
Looks like you're accessing a file via the document portal. I quote:
 The FileChooser portal allows sandboxed applications to ask
 the user for access to files outside the sandbox.
 The portal backend will present the user with a file chooser dialog.
The selected files will be made accessible to the application via the
document portal, and the returned URI will point into the document
portal fuse filesystem in /run/user/$UID/doc/.
(https://flatpak.github.io/xdg-desktop-portal/)
If the files are in your home folder, the portal should return a normal path. Where are those files?
Try FreeCAD from the Snap Store: Stable releases (in latest/stable) & daily builds (in latest/edge). Supports installing additional python packages via pip!
bambuko
Post by bambuko »
ppd wrote: Tue Jan 25, 2022 5:36 pm ...If the files are in your home folder, the portal should return a normal path. Where are those files?
Thank you!
I have suspected it was something like this ... (not exactly the clearest thing about snap :mrgreen: )
The file (all my data) is kept on NAS and accessible from any PC connected to it.
On my Linux machines the mount point for NAS data is in my home directory:
 home/bambuko/My_NAS_Files
so in theory this should be OK?
ppd
Post by ppd »
What kind of mount is it? CIFS, sshfs? The mount path alone is not enough; I think it's a little more complicated than that.
I just conducted a little experiment: A ssh mount via sshfs -o allow_other,uid=1001,gid=1002 user@server:/folder ~/remotedir works perfectly fine. The key is the uid & gid mapping (Apparmor is very strict :D) and the allow_other option (so snapd as root can access it, I guess).
bambuko
Post by bambuko »
ppd wrote: Tue Jan 25, 2022 6:44 pm What kind of mount is it? CIFS, sshfs? The mount path alone is not enough; I think it's a little more complicated than that.
sorry, cifs
ppd
Post by ppd »
bambuko wrote: Tue Jan 25, 2022 6:57 pm
sorry, cifs
Works for me. At least when I specify the uid and gid mapping as described above for sshfs.
bambuko
Post by bambuko »
Thank you,
I will play with it tomorrow - must admit more complicated and PITA than what I was hoping it would be... :cry:
ppd
Post by ppd »
For the record, I used this command:
sudo mount -t cifs -o guest,uid=$UID //server/folder  ~/remotedir/
The key is to specify a uid. You can set this in /etc/fstab or in a systemd mount unit.
bambuko
Post by bambuko »
and I thought that snap was meant to better at integrating the app.... :mrgreen: :D
oh the joys of Linux :x
no doubt I will be back with more questions....
bambuko
Post by bambuko »
ppd wrote: Tue Jan 25, 2022 7:26 pm The key is to specify a uid. You can set this in /etc/fstab or in a systemd mount unit.
My "mount at boot" fstab line for NAS specifies uid and files open fine in snap FreeCAD as long as there are no external links.
It's not the location that is an issue.
Try opening an assembly file with external links....
