conda images, some questions.
onekk
Post by onekk »
Hello, I have some question about conda package.
i have used the fcenv-dev miniconda package and I'm perfectly satisfied, but I've noted that when I make a periodic update many packages could be "downgraded".
What is the correct way to update the fcenv-dev miniconda environment.
I use:
conda update -n fcenv-dev freecad
TIA for any advice and explanation.
feel free to ask about my configuration, but be patient as I'm rather new to miniconda.
Regards
Carlo D.
- Various other stuffs.
Re: conda images, some questions.
Post by Kunda1 »
looo wrote: pinged by pinger macro
looo
Post by looo »
If a lot of packages are downgraded, maybe your channel settings have changed. I didn't see anything like this happening for me for a long time.
If you have added the channels to the config, the FreeCAD/label/dev channel should appear on top of the conda-forge channel. If you haven't got the freecad/label/dev channel in your config you can add it via:
conda config --add channels freecad/label/dev
to check your channels you can use (iicrc)
conda config --show channels
this should result in
channels:
  - freecad/label/dev
  - conda-forge
or similar.
to update all I use:
conda activate fcenv-dev
conda update --all
You can also add the channel in the update command like
conda update --all -c freecad/label/dev
if you do not have them in the config.
