Suggestions re Issue 6698
- wandererfan
We have reports of graphics issues on some linux configurations - see issue #6698 for details. I have not been able to figure out why some versions work fine and others have issues.
Does anybody have any suggestions on what the issue might be or where to look further?
Re: Suggestions re Issue 6698
Probably it is not the case, but in ArtixLinux (Arch Linux derivative), I have to downgrade the Mesa version to "21.3.7-2"wandererfan wrote: ↑Thu Apr 07, 2022 6:30 pm Does anybody have any suggestions on what the issue might be or where to look further?
see maybe:
https://forum.freecadweb.org/viewtopic. ... 70#p586570
for the problems I had.
I own an old i3-2100 machine so quite old but working.
It was related to the fact that some "old drivers" were removed from Mesa and probably the focus is not on compatibility, as Ubuntu, is using "Debian testing" as a base when making new versions, maybe this is the case. (I don't know it 22.04 is the latest Ubuntu).
At least in Arch Linux there is a package that use "old drivers", "Mesa-amber" i think, but it is reported as problematic, so only viable solution for me was to downgrade and "pin" Mesa package to old version (hoping it will be fixed soon, 22.0.1 was not a solution)
Hope it could be of some help.
Regards
Carlo D.
- Various other stuffs.
- wandererfan
Not sure I know how to do this, but I will investigate. Thanks for the hint.onekk wrote: ↑Fri Apr 08, 2022 6:30 am At least in Arch Linux there is a package that use "old drivers", "Mesa-amber" i think, but it is reported as problematic, so only viable solution for me was to downgrade and "pin" Mesa package to old version (hoping it will be fixed soon, 22.0.1 was not a solution)
This is a tough issue
Yes, but it is almost normal to have to deal with differents OpenGL implementations.
Mesa is the OpenGl implmentationm used on most Linux distribution, and usally if you are not using a "proprietary graphics driver" you will use Mesa, some infos could be:
https://wiki.archlinux.org/title/OpenGL
Sorry for using Arch Linux, but with Gentoo are the most useful place where to find some explanantion on some Linux internal workings, in a "convenient place".
Gentoo is too complicated as it has to deal with many "flavours" of things, being a source distribution.
Some other infos could be "Linux from Scratch" at least to try to see some "low levels info", at least if you are not a kernel developer or a "Linux graphics expert".
Regards
Carlo D.
Wondering if it is worth trying to compile using the source at https://code.launchpad.net/~freecad-mai ... it/freecad to see if it produces different results.wandererfan wrote: ↑Thu Apr 07, 2022 6:30 pm We have reports of graphics issues on some linux configurations - see issue #6698 for details. I have not been able to figure out why some versions work fine and others have issues.
- wandererfan
Worth a try, I have no better suggestion at this point. Can you do this?mfraz74 wrote: ↑Tue Apr 12, 2022 5:21 pm Wondering if it is worth trying to compile using the source at https://code.launchpad.net/~freecad-mai ... it/freecad to see if it produces different results.
I should be able to. I did look at the packages it wanted to install in tools/build/ubuntu.sh and there are are a few additional packages that aren't mentioned in https://wiki.freecadweb.org/Compile_on_Linux.wandererfan wrote: ↑Tue Apr 12, 2022 6:03 pmWorth a try, I have no better suggestion at this point. Can you do this?mfraz74 wrote: ↑Tue Apr 12, 2022 5:21 pm Wondering if it is worth trying to compile using the source at https://code.launchpad.net/~freecad-mai ... it/freecad to see if it produces different results.
build-essential cmake doxygen git libboost-date-time-dev libboost-dev libboost-filesystem-dev libboost-graph-dev libboost-iostreams-dev libboost-program-options-dev libboost-python-dev libboost-regex-dev libboost-serialization-dev libboost-thread-dev libcoin-dev libeigen3-dev libgtkglext1-dev libgts-dev libkdtree++-dev libkml-dev libmedc-dev libocct-data-exchange-dev libocct-draw-dev libocct-foundation-dev libocct-modeling-algorithms-dev libocct-modeling-data-dev libocct-ocaf-dev libocct-visualization-dev libopencv-dev libproj-dev libpyside2-dev libqt5svg5-dev libqt5webkit5-dev libqt5xmlpatterns5-dev libshiboken2-dev libvtk9-dev libvtk9-qt-dev libvtk-dicom-dev libx11-dev libxerces-c-dev libxmu-dev libxmuu-dev libzipios++-dev netgen netgen-headers pyside2-tools python3-dev python3-matplotlib python3-pivy python3-ply python3-pyside2.qtsvg python3-pyside2.qtuitools qtchooser qttools5-dev shiboken2 swig
[ 55%] Building CXX object src/Gui/CMakeFiles/FreeCADGui.dir/CallTips.cpp.o
during GIMPLE pass: resx
In file included from /usr/include/boost/smart_ptr/shared_ptr.hpp:17,
from /usr/include/boost/shared_ptr.hpp:17,
from /usr/include/boost/signals2/deconstruct.hpp:28,
from /usr/include/boost/signals2.hpp:15,
from /home/mfraser/git/freecad/src/boost_signals2.hpp:6,
from /home/mfraser/git/freecad/src/Base/Tools.h:36,
from /home/mfraser/git/freecad/src/Gui/Tree.cpp:45:
/usr/include/boost/smart_ptr/detail/shared_count.hpp: In constructor ‘boost::detail::shared_count::shared_count(Y*) [with Y = boost::signals2::detail::connection_body<std::pair<boost::signals2::detail::slot_meta_group, boost::optional<int> >, boost::signals2::slot<void(const QString&), boost::function<void(const QString&)> >, boost::signals2::mutex>]’:
/usr/include/boost/smart_ptr/detail/shared_count.hpp:141:32: internal compiler error: Segmentation fault
141 | template<class Y> explicit shared_count( Y * p ): pi_( 0 )
0xb0c67e crash_signal
../../src/gcc/toplev.c:327
0x7f14fb63351f ???
./signal/../sysdeps/unix/sysv/linux/x86_64/libc_sigaction.c:0
0x10deefa sbitmap_free(simple_bitmap_def*)
../../src/gcc/sbitmap.h:237
0x10deefa delete_update_ssa()
../../src/gcc/tree-into-ssa.c:2960
0x10b156d update_ssa(unsigned int)
../../src/gcc/tree-into-ssa.c:3564
0xfb8924 execute_function_todo
../../src/gcc/passes.c:2010
0xf6c3f9 execute_todo
../../src/gcc/passes.c:2096
Please submit a full bug report,
with preprocessed source if appropriate.
Please include the complete backtrace with any bug report.
See <file:///usr/share/doc/gcc-11/README.Bugs> for instructions.
make[2]: *** [src/Gui/CMakeFiles/FreeCADGui.dir/build.make:2403: src/Gui/CMakeFiles/FreeCADGui.dir/Tree.cpp.o] Error 1
make[2]: *** Waiting for unfinished jobs....
make[1]: *** [CMakeFiles/Makefile2:5492: src/Gui/CMakeFiles/FreeCADGui.dir/all] Error 2
make: *** [Makefile:149: all] Error 2
- wandererfan
Netgen <waves fist>
https://forum.freecadweb.org/viewtopic. ... 94#p587894
