OpenSuse Leap 15.4 && FreeCAD 0.19
AGChigisheff
Post by AGChigisheff »
Собственно вот:
FreeCAD 0.19, Libs: 0.19RUnknown
© Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2021
FreeCAD is free and open-source software licensed under the terms of LGPL2+ license.
FreeCAD wouldn't be possible without FreeCAD community.
connect failed: Нет такого файла или каталога (no file ...)
#0 /lib64/libc.so.6(+0x4ad70) [0x7efdee92dd70]
Возникает при file->create
Re: OpenSuse Leap 15.4 && FreeCAD 0.19
Post by Kunda1 »
Full About info please.
Try with the latest dev version (about to be released) https://github.com/FreeCAD/FreeCAD-Bund ... kly-builds or can use the Snap (edge) or the Flatpak (beta)
AGChigisheff
Re: OpenSuse Leap 15.4 && FreeCAD 0.19 || 2.0
FreeCAD_weekly-builds-29045-2022-06-06-conda-Linux-x86_64-py39.AppImage - работает, не ругается
./FreeCAD_weekly-builds-29045-2022-06-06-conda-Linux-x86_64-py39.AppImage
FreeCAD 0.20, Libs: 0.20R29045 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2022
User path has changed to /home/andreych/.local/share/FreeCAD/. Please move user modules and macros
adrianinsaval
Post by adrianinsaval »
Please post in english, at least using google translate (if doing this post original text too). Right now I don't understand what problem you are having if any.
AGChigisheff
It all started after switching from OpenCuse 15.3 to 15.4
File->New
The application crashes.
If run from a terminal
File->Open
Works until you try to open the selected file.
Error opening work interface.
When running version 0.2 everything works fine. But I didn't get far.
onekk
Post by onekk »
It is not clear what version you use, as in one there is a 0.19.something version, in another a 0.20 version.
If you are using an AppImage, it could be possible that there are version mismatch between the libc on your system and the libc on which FC AppImage is compiled.
There are some reports of mismatch especially on some version that use "rather old" libc or "too bleeding edge".
I have had no problem even if I'm using an Arch Linux distribution that is "rather bleeding edge".
Yuor mileage may vary, as some problem are generated also by the OpenGL framework that on some distribution is causing some problems.
But without a proper error report and version info these are only supposition.
Regards
Carlo D.
- Various other stuffs.
Post by Kunda1 »
User has updated OpenSUSE distro and v0.19 has stopped working for them.
adrianinsaval
I'm guessing it's the distro package that doesn't work? Either I wouldn't worry much since 0.20 is working and it's becoming the stable version this friday.
AGChigisheff
From AppImage all versions work. Weird, but they work. They do not recognize their own figures from the workbench. Not always, but strange things happen.
All the time there are errors in the log (Python). But continues to work. This is both 0.19 and 0.20 versions. Worked under both OpenSuse and Debian 11.
AppImage is a perversion. It is necessary to collect more familiar rpm and deb packages. I'll do it when the time comes. I'll do it when the time comes. In any case, I'll try.
TomIGo
Post by TomIGo »
I am having the same issue trying to run FreeCAD under openSUSE 15.4. Just finished upgrading from openSUSE 15.3 to 15.4 last week and am completing install of all the software I use. After a clean install of FreeCAD using the package in the distro, the application starts and looks like it is fine, but sits and does nothing when I try to open an existing file. All I get is the spinning blue and red arrows. This was working fine under 15.3 and many O/S versions prior.
I then ran FreeCAD from within a terminal window, and I see the following:
> FreeCAD
connect failed: No such file or directory
The message above happens before I try to do anything in the application. When I attempt to open any file, even one of the examples, I see:
#0 /lib64/libc.so.6(+0x4ad50) [0x7f7261fc5d50]
To close the application, I have to click the button to close the window, wait for the window to pop that says Application "freecad" is not responding, and click the button to Terminate the application.
